Oracle interMedia Audio, Image, and Video Java Classes User's Guide and Reference
Release 8.1.7
Part Number A85374-01
Library
Product
Contents
Index
Go to previous page Go to next page
3
ORDAudio Reference Information
interMedia Java Classes describes the ORDAudio object type, which supports the storage and management of audio data.
Methods invoked at the ORDAudio level that are handed off for processing to the database source plug-in or database format plug-in have byte[ ] ctx[ ] as a context parameter. In cases where a client system is connecting to a database server, the space for the parameter is created by the client (in the reference examples, 4000 bytes of space), but the content of the context parameter is generated by the server. The context parameter is passed from the client to the server for the processing of context information.
In the current release, not all source plug-ins or format plug-ins will use or generate the context parameter, but if you include the parameter as previously described, your application should work with any current or future source plug-ins or format plug-ins.
3.1 Prerequisites
You will need to include the following import statements in your Java file in order to run interMedia methods:
import java.sql.*;
import java.io.*;
import oracle.jdbc.driver.*;
import oracle.sql.*;
import oracle.ord.im.*;
The examples in this reference chapter are based on the assumption that the following operations have already been performed:
For examples of making a connection and populating a local object, see Section 2.1.2.
3.2 Reference Information
This section presents reference information on the methods that operate on ORDAudio objects.
checkProperties( )
Format
public boolean checkProperties(byte[ ] ctx[ ])
Description
Checks if the properties stored in the media data of the local object are consistent with the attributes of the local object.
Parameters
ctx[ ]
The format plug-in context information. It is set to NULL if there is no context information.
Return Value
This method returns TRUE if the attribute values stored in the object attributes are the same as the properties stored in the BLOB data; FALSE otherwise.
Exceptions
java.sql.SQLException
Example
byte[ ] ctx[ ] = new byte[4000][1];
if(audObj.checkProperties(ctx))
     System.out.println("checkProperties successful");
where:
clearLocal( )
Format
public void clearLocal( )
Description
Clears the source local field of the application ORDAudio object.
Parameters
None.
Return Value
None.
Exceptions
Example
audObj.clearLocal( )
closeSource( )
Format
public int closeSource(byte[ ] ctx[ ])
Description
Closes the ORDAudio file source.
Parameters
ctx[ ]
The source plug-in context information. It is set to NULL if there is no context information.
Return Value
This method returns 0 if the operation is successful, or an integer greater than 0 in case of failure.
Exceptions
Example
int i = audObj.closeSource(ctx);
if(i == 0)
     System.out.println("Source close successful");
else
     System.out.println("Source close unsuccessful");
where:
deleteContent( )
Format
public void deleteContent( )
Description
Deletes the media data in the BLOB in the application ORDAudio object.
Parameters
None.
Return Value
None.
Exceptions
Example
audObj.deleteContent( );
export( )
Format
public void export (byte[ ] ctx[ ], String sourceType, String sourceLocation, String sourceName)
Description
Exports the data from the application ORDAudio object BLOB to the location specified in the parameters. The location is of the form:
sourceType://sourceLocation/sourceName
This method will only work if you are running Oracle8i database server version 8.1.7 or later.
See Chapter 4 of Oracle8i interMedia Audio, Image, and Video User's Guide and Reference for more information.
Parameters
ctx[ ]
sourceType
The source type to which the content will be exported. Only FILE is natively supported.
sourceLocation
The location on the database server to which the content will be exported.
sourceName
The name of the source to which the content will be exported.
Return Value
None.
Exceptions
Example
audObj.export(ctx,"FILE","AUDIODIR","complete.wav");
where:
getAllAttributes( )
Format
public CLOB getAllAttributes(byte[ ] ctx[ ])
Description
Gets all the attributes from the application ORDAudio object and puts them in a CLOB.
Parameters
ctx[ ]
Return Value
This method returns a CLOB that contains the attribute values of the ORDAudio object.
Exceptions
Example
CLOB attributes = audObj.getAllAttributes(ctx);
where:
getAttribute( )
Format
public String getAttribute(byte[ ] ctx[ ], String name)
Description
Gets the value of a specified attribute from the application ORDAudio object as a String.
Parameters
ctx[ ]
name
The name of the attribute.
Return Value
This method returns the value of the specified attribute, as a String.
Exceptions
Example
int attribute = audObj.getAttribute(ctx,"numberOfChannels")
where:
getAudioDuration( )
Format
public int getAudioDuration( )
Description
Gets the audio duration of the application ORDAudio object.
Parameters
None.
Return Value
This method returns the audio duration of the ORDAudio object, in seconds.
Exceptions
Example
int audioDuration = audObj.getAudioDuration( );
getBFILE( )
Format
public oracle.sql.BFILE getBFILE( )
Description
Gets the BFILE attribute of the application ORDAudio object.
Parameters
None.
Return Value
This method returns the BFILE.
Exceptions
Example
BFILE audioBFILE = audObj.getBFILE( );
getComments( )
Format
public oracle.sql.CLOB getComments( )
Description
Gets the comments from the application ORDAudio object and puts them in a CLOB.
Parameters
None.
Return Value
This method returns a CLOB that contains the comments from the ORDAudio object.
Exceptions
Example
CLOB comments = audObj.getComments( )
getCompressionType( )
Format
public String getCompressionType( )
Description
Gets the compression type of the application ORDAudio object as a String.
Parameters
None.
Return Value
This method returns the compression type of the ORDAudio object, as a String.
Exceptions
Example
String compressionType = audObj.getComressionType( );
getContent( )
Format
public oracle.sql.BLOB getContent( )
Description
Gets the LOB locator from the application ORDAudio object.
Parameters
None.
Return Value
This method returns the LOB locator of the application ORDAudio object.
Exceptions
Example
BLOB localContent = audObj.getContent( );
getContentInLob( )
Format
public BLOB getContentInLob(byte[ ] ctx[ ], String mimetype[ ], String format[ ])
Description
Gets the content of the application ORDAudio object and puts it in a BLOB.
Parameters
ctx[ ]
mimetype[ ]
The MIME type of the content returned, stored in mimetype[0].
format[ ]
The format of the content returned, stored in format[0].
Return Value
This method returns the LOB content of the application ORDAudio object in a LOB locator.
Exceptions
Example
String mimeType[ ] = new String[1];
mimeType[0] = "video/x-msvideo"
String format[ ] = new String[1];
format[0] = "RIFF"
BLOB localContent = audObj.getContentInLob(ctx,mimeType,format);
where:
getContentLength( )
Format
public int getContentLength( )
Description
Gets the content length of the media data in the application ORDAudio object.
Parameters
None.
Return Value
This method returns the content length of the media data.
Exceptions
Example
int contentLength = audObj.getContentLength( );
getContentLength(byte[ ][ ])
Format
public int getContentLength(byte[ ] ctx[ ])
Description
Parameters
ctx[ ]
Return Value
Exceptions
Example
int contentLength = audObj.getContentLength(ctx);
where:
getDataInByteArray( )
Format
public byte[ ] getDataInByteArray( )
Description
Gets data from the LOB locator of the application ORDAudio object and puts it in a local byte array.
Parameters
None.
Return Value
This method returns the byte array from which the data will be read.
Exceptions
java.io.IOException
java.lang.OutOfMemoryError
Example
byte[ ] byteArr = audObj.getDataInByteArray( );
getDataInFile( )
Format
public boolean getDataInFile(String filename)
Description
Gets data from the LOB locator of the application ORDAudio object and puts it in a local file.
Parameters
filename
The name of the file into which the data will be loaded.
Return Value
This method returns TRUE if loading is successful; FALSE otherwise.
Exceptions
java.io.IOException
Example
boolean load = audObj.getDataInFile("output1.dat");
if(load)
     System.out.println("getDataInFile completed successfully");
else
     System.out.println("Error in getDataInFile");
where:
getDataInStream( )
Format
public InputStream getDataInStream( )
Description
Gets data from the LOB locator of the application ORDAudio object and puts it in a local input stream.
Parameters
None.
Return Value
This method returns the input stream from which the data will be read.
Exceptions
Example
InputStream inpStream = audObj.getDataInStream( );
getDescription( )
Format
public String getDescription( )
Description
Gets the description attribute of the application ORDAudio object.
Parameters
None.
Return Value
This method returns the description attribute as a String.
Exceptions
Example
String desc = audObj.getDescription( );
getEncoding( )
Format
public String getEncoding( )
Description
Gets the encoding of the application ORDAudio object as a String.
Parameters
None.
Return Value
This method returns the encoding of the ORDAudio object as a String.
Exceptions
Example
String encoding = audObj.getEncoding( );
getFormat( )
Format
public String getFormat( )
Description
Gets the format attribute of the application ORDAudio object as a String.
Parameters
None.
Return Value
This method returns the format attribute as a String.
Exceptions
Example
String format = audObj.getFormat( );
getMimeType( )
Format
public String getMimeType( )
Description
Gets the MIME type of the application ORDAudio object as a String.
Parameters
None.
Return Value
This method returns the MIME type of the ORDAudio object as a String.
Exceptions
Example
String mimeType = audObj.getMimeType( );
getNumberOfChannels( )
Format
public int getNumberOfChannels( )
Description
Gets the number of channels in the application ORDAudio object.
Parameters
None.
Return Value
This method returns the number of channels in the ORDAudio object as an integer.
Exceptions
Example
int channels = audObj.getNumberOfChannels( );
getSampleSize( )
Format
public int getSampleSize( )
Description
Gets the sample size of the application ORDAudio object as an integer.
Parameters
None.
Return Value
This method returns the sample size of the ORDAudio object.
Exceptions
Example
int sampleSize = audObj.getSampleSize( );
getSamplingRate( )
Format
public int getSamplingRate( )
Description
Gets the sampling rate of the application ORDAudio object as an integer.
Parameters
None.
Return Value
This method returns the sampling rate of the ORDAudio object in bytes per second.
Exceptions
Example
int samplingRate = audObj.getSamplingRate( );
getSource( )
Format
public String getSource( )
Description
Gets the object source information of the application ORDAudio object, including the source location, name, and type.
Parameters
None.
Return Value
This method returns a String containing the object source information.
Exceptions
Example
String source = audObj.getSource( );
getSourceLocation( )
Format
public String getSourceLocation( )
Description
Gets the source location of the application ORDAudio object as a String.
Parameters
None.
Return Value
This method returns a String containing the object source location.
Exceptions
Example
String location = audObj.getSourceLocation( );
getSourceName( )
Format
public String getSourceName( )
Description
Gets the source name of the application ORDAudio object as a String.
Parameters
None.
Return Value
This method returns a String containing the object source name.
Exceptions
Example
String name = audObj.getSourceName( );
getSourceType( )
Format
public String getSourceType( )
Description
Parameters
None.
Return Value
This method returns a String containing the object source type.
Exceptions
Example
String type = audObj.getSourceType( );
getUpdateTime( )
Format
public java.sql.Timestamp getUpdateTime( )
Description
Gets a Timestamp object that contains information on when the application ORDAudio object was most recently updated.
Parameters
None.
Return Value
This method returns a Timestamp object that contains the time of the most recent update.
Exceptions
Example
Timestamp time = audObj.getUpdateTime( );
importData( )
Format
public void importData(byte[ ] ctx[ ])
Description
Imports data from an external source into the application ORDAudio object.
The srcType, srcLocation, and srcName attributes must all be defined for this method to work.
Parameters
ctx[ ]
Return Value
None.
Exceptions
Example
audObj.importData(ctx);
where:
importFrom( )
Format
public void importFrom(byte[ ] ctx[ ], String sourceType, String sourceLocation, String sourceName)
Description
Imports data from an external source into the application ORDAudio object. The location of the external source is of the form:
Parameters
ctx[ ]
The source plug-in context information. See Chapter 4 of Oracle8i interMedia Audio, Image, and Video User's Guide and Reference for more information.
sourceType
The source type from which the data will be imported.
sourceLocation
The source location on the database server from which the data will be imported.
sourceName
The source name from which the data will be imported.
Return Value
None.
Exceptions
Example
audObj.importFrom("FILE","AUDIODIR","testaud.dat");
where:
isLocal( )
Format
public boolean isLocal( )
Description
Checks if the application ORDAudio object local attribute is set.
Parameters
None.
Return Value
This method returnsTRUE if the ORDAudio object local attribute is set; FALSE otherwise.
Exceptions
Example
if(audObj.isLocal( ))
     System.out.println("local attribute is set to true");
else
     System.out.println("lcoal attribute is set to false");
loadDataFromByteArray( )
Format
public boolean loadDataFromByteArray(byte[ ] byteArr)
Description
Loads data from the local byte buffer into the database ORDAudio object LOB locator and into the application object. It also calls setLocal( ), which sets the local field of the application ORDAudio object, but not the database object, and setUpdateTime(null), which sets the updateTime attribute to the SYSDATE of the database server.
Parameters
byteArr
The name of the local byte array from which the data will be loaded.
Return Value
Exceptions
java.io.IOException
Example
byte[ ] data = new byte[32000];
FileInputStream fStream = new FileInputStream("testaud.dat");
fStream.read(data,0,32300);
boolean success = audObj.loadDataFromByteArray(data);
if(success)
     System.out.println("loadDataFromByteArray was successful");
else
     System.out.println("loadDataFromByteArray was unsuccessful");
where:
loadDataFromFile( )
Format
public boolean loadDataFromFile(String filename)
Description
Loads data from the local file into the database ORDAudio object LOB locator and into the application object. It also calls setLocal( ), which sets the local field of the application ORDAudio object, but not the database object, and setUpdateTime(null), which sets the updateTime attribute to the SYSDATE of the database server.
Parameters
filename
The name of the local file from which to load data.
Return Value
Exceptions
java.io.IOException
Example
audObj.loadDataFromFile("testaud.dat");
where:
loadDataFromInputStream( )
Format
public boolean loadDataFromInputStream(InputStream inpStream)
Description
Loads data from the local input stream into the database ORDAudio object LOB locator and into the application object. It also calls setLocal( ), which sets the local field of the application ORDAudio object, but not the database object, and setUpdateTime(null), which sets the updateTime attribute to the SYSDATE of the database server.
Parameters
inpStream
The name of the local input stream from which to load data.
Return Value
Exceptions
java.io.IOException
Example
audObj.loadDataFromInputStream(fStream);
where:
openSource( )
Format
public int openSource(byte[ ] userarg, byte[ ] ctx[ ])
Description
Opens the ORDAudio file source.
Parameters
userarg
Permission-related parameters that are supplied by the user, such as READONLY. These may be used by user-defined source plug-ins.
ctx[ ]
Return Value
Exceptions
java.lang.Exception
Example
byte[ ] userarg = new byte[4000];
int i = audObj.openSource(userarg,ctx);
if(i == 0)
     System.out.println("openSource successful");
else
     System.out.println("openSource unsuccessful");
where:
OrdAudio( )
Format
public OrdAudio( )
Description
Creates an ORDAudio object.
This method is the default ORDAudio constructor.
Parameters
None.
Return Value
None.
Exceptions
None.
Example
None.
processAudioCommand( )
Format
public byte[ ] processAudioCommand(byte[ ] ctx[ ], String command, String args, byte[ ] result[ ])
Description
Processes the specified command on the application ORDAudio object by calling the database processAudioCommand( ) method.
Parameters
ctx[ ]
command
The command to be executed. The command must be recognized by the database format plug-in.
args
The arguments of the command.
result[ ]
The results of the command.
Return Value
This method returns the results of the execution of the command.
Exceptions
Example
String command;
String arguments;
byte[ ] result;
//assign a command value to command
//assign any arguments to args
byte[ ] commandResults = audObj.processAudioCommand(ctx,command,
     arguments,result);
where:
processSourceCommand( )
Format
public byte[ ] processSourceCommand(byte[ ] ctx[ ], String command, String args, byte[ ] result[ ])
Description
Processes the specified command on the application ORDAudio object by calling the database processSourceCommand( ) method.
Parameters
ctx[ ]
command
The command to be executed. The command must be recognized by the database source plug-in.
args
The arguments of the command to be executed.
result[ ]
Return Value
This method returns the results of executing the command.
Exceptions
Example
String command;
String arguments;
byte[ ] result;
byte[ ] commandResults = audObj.processSourceCommand(ctx,command,
     arguments,result);
where:
readFromSource( )
Format
public int readFromSource(byte[ ] ctx[ ], int startpos, int numbytes, byte[ ] buffer)
Description
Reads data from the comments field of the application ORDAudio object.
Parameters
ctx[ ]
startpos
The initial position in the comments field.
numbytes
The number of bytes to be read.
buffer
The buffer into which to read the content.
Return Value
This method returns the number of bytes read.
Exceptions
Example
byte[ ] commentBuffer = new byte[12];
int i = audObj.readFromSource(ctx,0,12,commentBuffer);
where:
setAudioDuration( )
Format
public void setAudioDuration(int audioDuration)
Description
Sets the audio duration of the application ORDAudio object.
setProperties( ) will automatically set this attribute; use this method only if you are not using setProperties( ). Also, this method will set only the attribute value; it does not change the media file itself.
Parameters
audioDuration
The audio duration (in seconds) to be set in the ORDAudio object.
Return Value
None.
Exceptions
Example
audObj.setAudioDuration(16);
where:
setComments( )
Format
public void setComments(oracle.sql.CLOB comments)
Description
Sets the comments in the application ORDAudio object.
The comments attribute is reserved for use by interMedia. You can set your own value, but it could be overwritten by interMedia Annotator.
Parameters
comments
A CLOB that contains comments for the ORDAudio object.
Return Value
None.
Exceptions
Example
audObj.setComments(commentsData);
where:
setCompressionType( )
Format
public void setCompressionType(String CompressionType)
Description
Sets the compression type of the application ORDAudio object.
Parameters
CompressionType
The compression type of the ORDAudio object, as a String.
Return Value
None.
Exceptions
Example
audObj.setCompressionType("8BITMONOAUDIO");
where:
setDescription( )
Format
public void setDescription(String description)
Description
Sets the description attribute of the application ORDAudio object.
Parameters
description
A String that describes the contents of the ORDAudio object.
Return Value
None.
Exceptions
Example
audObj.setDescription("My audio file");
where:
setEncoding( )
Format
public void setEncoding(String encoding)
Description
Sets the encoding of the application ORDAudio object.
Parameters
encoding
The encoding of the contents of an ORDAudio object, as a String.
Return Value
None.
Exceptions
Example
audObj.setEncoding("MULAW");
where:
setFormat( )
Format
public void setFormat(String format)
Description
Sets the format attribute of the application ORDAudio object.
Parameters
format
The format of the contents of the ORDAudio object, as a String.
Return Value
None.
Exceptions
Example
audObj.setFormat("AUFF");
where:
setKnownAttributes( )
Format
public void setKnownAttributes(String knownformat, String knownencoding,
int knownnumberofchannels, int knownsamplingrate,
int knownsamplesize, String knowncompressiontype,
int knownaudioduration)
Description
Sets the known attributes of the ORDAudio object.
setProperties( ) will automatically set these attributes; use this method only if you are not using setProperties( ). Also, this method will set only the attribute values; it does not change the media file itself.
Parameters
knownformat
The audio data format.
knownencoding
The audio data encoding.
The number of channels.
knownsamplingrate
The sampling rate.
knownsamplesize
The sample size.
The compression type.
knownaudioduration
The audio duration.
Return Value
None.
Exceptions
Example
audObj.setKnownAttributes("AUFF","MULAW",1,8,8,"8BITMONOAUDIO",16);
where:
setLocal( )
Format
public void setLocal( )
Description
Sets the source local field of the application ORDAudio object.
Parameters
None.
Return Value
None.
Exceptions
Example
audObj.setLocal( );
setMimeType( )
Format
public void setMimeType(String MimeType)
Description
Sets the MIME type of the application ORDAudio object.
Parameters
MimeType
The MIME type of the contents of the ORDAudio object, as a String.
Return Value
None.
Exceptions
Example
audObj.setMimeType("audio/basic");
where:
setNumberOfChannels( )
Format
public void setNumberOfChannels(int numberOfChannels)
Description
Sets the number of the channels in the application ORDAudio object.
Parameters
numberOfChannels
The number of channels to be set.
Return Value
None.
Exceptions
Example
audObj.setNumberOfChannels(1);
where:
setProperties(byte[ ][ ])
Format
public void setProperties(byte[ ] ctx[ ])
Description
Reads the audio data, extracts the properties, and sets the properties in the application ORDAudio object.
The properties to be set include format, encoding, number of channels, sampling rate, sample size, compression type, and audio duration.
Parameters
ctx[ ]
Return Value
None.
Exceptions
Example
audObj.setProperties(ctx);
where:
setProperties(byte[ ][ ], boolean)
Format
public void setProperties(byte[ ] ctx[ ], boolean setComments)
Description
Reads the media data, extracts the properties, and sets the properties in the application ORDAudio object.
Parameters
ctx[ ]
setComments
A Boolean value to determine whether or not to set the comments in the ORDAudio object. If TRUE, the comments field is populated with a set of format and application properties of the audio object in XML. If FALSE, the comments field remains unpopulated. The default value is FALSE.
Return Value
None.
Exceptions
Example
audObj.setProperties(ctx,true);
where:
setSampleSize( )
Format
public void setSampleSize(int sampleSize)
Description
Sets the sample size in the application ORDAudio object.
Parameters
sampleSize
The sample size of the ORDAudio object.
Return Value
None.
Exceptions
Example
audObj.setSampleSize(8);
where:
setSamplingRate( )
Format
public void setSamplingRate(int samplingRate)
Description
Sets the sampling rate of the application ORDAudio object.
Parameters
samplingRate
The sampling rate value to be set, in samples per second.
Return Value
None.
Exceptions
Example
audObj.setSamplingRate(8);
where:
setSource( )
Format
public void setSource(String sourceType, String sourceLocation, String sourceName)
Description
Sets the application ORDAudio object source information.
Parameters
sourceType
The type of the source.
sourceLocation
The location of the source.
sourceName
The name of the source.
Return Value
None.
Exceptions
Example
audObj.setSource("FILE","AUDIODIR","audio.au");
where:
setUpdateTime( )
Format
public void setUpdateTime(java.sql.Timestamp currentTime)
Description
Sets the update time in the application ORDAudio object to the current time.
Parameters
currentTime
The current time, which will be set in the ORDAudio object. This value should be NULL; the method will then use the SYSDATE of the database server.
Return Value
None.
Exceptions
Example
audObj.setUpdateTime(null);
trimSource( )
Format
public int trimSource(byte[ ] ctx[ ], int newLen)
Description
Trim the file source of the application ORDAudio object to the given length.
Parameters
ctx[ ]
newLen
The length to which the source will be trimmed.
Return Value
Exceptions
Example
int i = audObj.trimSource(ctx,10);
if (i == 0)
     System.out.println("trimSource successful");
else
     System.out.println("trimSource unsuccessful");
where:
writeToSource( )
Format
public int writeToSource(byte[ ] ctx[ ], int startpos, int numbytes, byte[ ] buffer)
Description
Writes data to the comments field of the application ORDAudio object.
Parameters
ctx[ ]
startpos
numbytes
The number of bytes to be written.
buffer
The buffer containing the content to be written.
Return Value
This method returns the number of bytes written.
Exceptions
Example
byte[ ] data = new byte[20];
//populate data with 20 bytes of content
int i = audObj.writeToSource(ctx,1,20,data);
where:
Oracle
Copyright © 2000 Oracle Corporation.
All Rights Reserved.
Library
Product
Contents
Index
