| Oracle interMedia Audio, Image, and Video Java Classes User's Guide and Reference Release 8.1.7 Part Number A85374-01 |
This appendix contains information on the exceptions and errors that can be raised by interMedia Java Classes.
The Exception class (and its subclasses, including SQLException) indicates conditions of interest to the user.
public class java.lang.Exception extends java.lang.Throwable { //Constructs an Exception with no detailed message public Exception(); //Constructs an Exception with a detailed message public Exception(String s); }
The IOException class signals that an I/O exception of some sort has occurred.
public class java.io.IOException extends java.lang.Exception { //Constructs a FileNotFoundException with no detailed message public IOException(); //Constructs a FileNotFoundException with the specified detailed message public IOException(String s); }
The OutOfMemoryError class signals that the Java Virtual Machine cannot allocate an object because it is both out of memory and unable to make more memory available through garbage collecting (that is, through deleting objects that are no longer being used).
public class java.lang.OutOfMemoryError extends java.lang.VirtualMachineError { //Constructs an OutOfMemoryError with no detailed message public OutOfMemoryError(); //Constructs an OutOfMemoryError with a detailed message public OutOfMemoryError(string s); }
The SQLException class provides information on a database access error.
public class java.sql.SQLException extends java.lang.Exception { //The following four methods are public constructors: //Constructs a fully specified SQLException public SQLException(String reason, String SQLState, int vendorCode); //Constructs a SQLException with venderCode value of 0 public SQLException(String reason, String SQLState); //Constructs a SQLException with vendorCode value of 0 and a null SQLState public SQLException(String reason); //Constructs a SQLException with vendorCode of 0, a null SQLState. and a //null reason public SQLException(); //The following four methods are public instance methods: //Gets the vendor-specific exception code public int getErrorCode(); //Gets the exception connected to this one public SQLException getNextException(); //Gets the SQL state public String getSQLState(); //Adds a SQLException to the end public synchronized void setNextException(SQLException ex); }
![]() Copyright © 2000 Oracle Corporation. All Rights Reserved. |
