Advanced Queueing |
8.1.7 |
Provides support for the Advanced Queueing API. |
Oracle8i Application Developer's Guide - Advanced Queueing |
Advanced Replication |
8.1.7 |
Provides support for the Advanced Replication API. |
Oracle8i Replication |
Assistant Common Files
(installed with Oracle assistants, such as Oracle Database Configuration Assistant and Net8 Assistant) |
8.1.7 |
A collection of automatically installed files required by Oracle assistants. These files include:
- BaliShare 1.0.8 (compressed)
- DBUI 1.1.2
- EWT 3.3.6 (compressed)
- ICE Browser 4.06.6 (compressed)
- Java Swing Components 1.1.1 (compressed)
- Kodiak 1.1.2
- Oracle Help for Java 3.1.3 (compressed)
- SMUI 1.0.7
Not applicable |
Data Collection Services
(installed with Oracle Intelligent Agent) |
2.2 |
Works as an extension of Oracle Intelligent Agent to collect system performance data (for example, file I/O or CPU usage data) for Capacity Planner and Performance Manager, which are data-collecting applications in the Oracle Diagnostics Pack. |
Oracle Enterprise Manager Administrator's Guide
Oracle Enterprise Manager Concepts Guide |
Enterprise JavaBeans |
8.1.7 |
An architecture used for developing transactional applications as distributed components in Java. |
Oracle8i Enterprise JavaBeans and CORBA Developer's Guide |
Java Runtime Environment (Oracle version) |
1.1.8 |
Required for running Java applications, such as Oracle Universal Installer. SGI IRIX JRE Version 1.1.8 is the minimum standard Java platform for running Java programs. |
Not applicable |
Net8 Assistant
(Installed with Net8 Client) |
8.1.7 |
Used by network administrators and DBAs to configure Net8. |
Net8 Administrator's Guide |
Net8 Client |
8.1.7 |
Provides products that enable client connections to databases across a network. A client-side application sends a request to Net8 to be transported across the network to the server.
Net8 Client (and not Oracle Universal Installer) installs TCP/IP and Named Pipes. |
Net8 Configuration Assistant
8.1.7 |
Automatically started during installation to configure directory service access and Net8 client and server components. Net8 Configuration Assistant can also be run in stand-alone mode to configure Net8 after its installation. |
Net8 Server |
8.1.7 |
Provides products that allow the listener, through a protocol, to accept connections from client applications on the network.
Note: Net8 Server cannot be installed using any Oracle8i Client installation types.
Net8 clients communicate with Oracle servers by using network service names. Net8 uses the following naming methods:
- Host Names
- Local Names
- Oracle Names
- Directory Names
Object Type Translator |
8.1.7 |
Used to create C-struct representations of Abstract Data Types (ADTs) that have been created and stored in an Oracle database. To take advantage of objects, run Object Type Translator against the database. A header file is generated that includes the C-structs. |
Oracle Call Interface Programmer's Guide |
Oracle Advanced Security |
8.1.7 |
Oracle Advanced Security provides the following comprehensive suite of security services for Oracle8i.
This multicomponent product requires a separate license.
Oracle Advanced Security Administrator's Guide |
Authentication support |
8.1.7 |
Oracle Advanced Security provides strong authentication support using a variety of authentication modules. |
Authorization support |
8.1.7 |
Authorization solutions are provided with the enterprise role management functionality in Oracle Advanced Security. |
Encryption and Integrity support |
8.1.7 |
Oracle Advanced Security ensures data confidentiality during transmission using the encryption and data integrity types listed in the preceding installable products tables. It enables a variety of public-key solutions, including native encryption, Secure Sockets Layer (SSL), X.509 certificates, passwords, smartcards and biometrics.
Note: Recent changes in the United States Export Administration Regulations (EAR) have made it possible for Oracle Corporation to ship a single edition of Oracle Advanced Security worldwide. Oracle Advanced Security includes strong encryption for protocols into the Oracle database that were previously available only to the U.S. and Canadian markets. |
Enterprise User Security support
8.1.7 |
Oracle Advanced Security integrates with Lightweight Directory Access Protocol (LDAP) v3 directory services, such as Oracle Internet Directory, for centralized enterprise user management, enterprise role management, and single sign-on. |
Single Sign On support |
8.1.7 |
Oracle Advanced Security provides single sign-on to multiple accounts and applications using a single password. Strong authentication occurs transparently in subsequent connections. Oracle Advanced Security supports Kerberos and SSL-based single sign-on. |
Oracle Call Interface |
8.1.7 |
An interface for accessing an Oracle database from a C or C++ program. |
Oracle Connection Manager
8.1.7 |
Acts like a router through which client connection requests can either be sent to the next hop or directly to a server. Clients can take advantage of the connection concentration, Net8 access control, or multi-protocol support features configured on the Connection Manager. |
Oracle Data Migration Assistant |
8.1.7 |
Migrates existing Oracle7 databases (release 7.1.3.3.6 or later) to an Oracle8i database and upgrades Oracle8 databases to the current database release. |
Oracle8i Migration |
Oracle Database Configuration Assistant |
8.1.7 |
Automates the process of creating, modifying, and deleting an Oracle database. |
Oracle8i Administrator's Guide |
Oracle Documentation |
8.1.7 |
Online version of Oracle8i documentation available in HTML and PDF format. |
"Accessing Installed Documentation" |
Oracle Enterprise Login Assistant |
1.1 |
Enables single sign on, which implements a subset of Wallet Manager for opening a user wallet and enabling applications to use it. |
Oracle Intelligent Agent |
8.1.7 |
Monitors services on the managed node for registered events and scheduled jobs sent by the console. |
Oracle Intelligent Agent User's Guide |
Oracle interMedia |
8.1.7 |
Enables file management in a variety of media, including text, audio, and video through a specific component of interMedia.
This multi-component product requires a separate license. |
Oracle8i interMedia Text Reference |
Oracle interMedia Audio
(installed with Oracle interMedia, formerly called Oracle Audio Cartridge) |
8.1.7 |
Enables the storage, retrieval and management of digitized audio data within an Oracle database. |
Oracle8i interMedia Audio, Image, and Video User's Guide and Reference |
Oracle interMedia Client
(part of Oracle interMedia) |
8.1.7 |
Enables a Java interface for Oracle8i interMedia Audio, Image, and Video that lets you use client-side applications to manipulate or modify multimedia data stored in a network accessible database on the server. |
Oracle interMedia Common Files
(installed with Oracle interMedia) |
8.1.7 |
A set of files used by Oracle interMedia components. |
Not applicable |
Oracle interMedia Image
(installed with Oracle interMedia, formerly called Oracle Image Cartridge) |
8.1.7 |
Enables the storage, retrieval, and processing of two-dimensional, static bitmapped images. Images are stored efficiently using popular compression schemes in industry-standard desktop publishing image interchange formats. |
Oracle interMedia Locator Service
8.1.7 |
Enables Oracle8i to support online internet-based geocoding facilities for locator applications and proximity queries. |
Oracle8i interMedia Locator User's Guide and Reference |
Oracle interMedia Text
(installed with Oracle interMedia, formerly called Oracle ConText Cartridge) |
8.1.7 |
Enables you to search for text in the database as quickly and easily as any other type of data. Oracle interMedia Text also supports basic full-text searches in most languages supported by the Oracle database. |
Oracle interMedia Video
(installed with Oracle interMedia, formerly called Oracle Video Cartridge) |
8.1.7 |
Enables the storage, retrieval, and management of digitized video data within an Oracle database. |
Oracle Java Database Connectivity (JDBC) Drivers |
8.1.7 |
A standard set of Java classes, specified by JavaSoft, that provides vendor-independent access to relational data using Java. |
Oracle8i JDBC Developer's Guide and Reference |
Oracle8i JVM Enterprise Edition |
8.1.7 |
Provides the Oracle Java Virtual Machine, CORBA 2.0 Object Request Broker, embedded JDBC drivers, SQLJ translator, and an Enterprise JavaBeans transaction server. |
Oracle8i Java Developer's Guide |
Oracle8i JVM Accelerator |
8.1.7 |
Eliminates interpreter overhead by translating standard Java class files into specialized C source files. A platform-dependent C compiler then processes the C source files into native libraries, which can be loaded dynamically. The Oracle8i JVM Accelerator is portable to all operating system and hardware platforms. |
Oracle8i Java Stored Procedures Development Guide; Oracle8i Java Developer's Guide |
Oracle8i JVM Servlet Container (JSC) |
8.1.7 |
The Oracle8i JVM Servlet Container is a built-in web server running inside the database. It is a servlet runner that works with the Apache server and with Oracle8i JVM to enable distribution of Java Server Pages (JSPs) and to enable servlets to run directly on the database. |
Oracle8i JVM Servlet Container User's Guide; Oracle8i Java Developer's Guide |
Oracle Java Tools |
8.1.7 |
Provides Java tools to build and deploy Java stored procedures, CORBA objects, and Enterprise JavaBeans with the Oracle Java Virtual Machine. |
Oracle8i SQLJ Developer's Guide and Reference |
Oracle Names |
8.1.7 |
A distributed naming service developed for Oracle environments to help simplify the setup and administration of global, client/server computing networks. Oracle Names does this by establishing and maintaining an integrated system of Names servers. Oracle Names servers work like a directory service storing addresses for all the database services on a network and making them available to clients that want to make a connection. |
Oracle Objects Functionality |
8.1.7 |
Lets you create and manipulate objects, and integrate objects with standard relational functionality. |
Oracle Partitioning |
8.1.7 |
Provides more control in managing tables and indexes by directing all maintenance operations to individual partitions rather than to tables and index names.
This product requires a separate license. |
Oracle PL/SQL Embedded Gateway |
8.1.7 |
A Java module gateway that authenticates user roles and enables secured access to build and run PL/SQL procedures. These procedures can retrieve data from database tables and generate HTTP responses. Use the mod_plsql module to do this. This module runs as a servlet on the HTTP Server middle tier. It creates "stateless" sessions, meaning information about requests is not maintained between client sessions. |
Oracle Internet Application Server Release: Using mod_plsql
Oracle8i Administrator's Reference release 3 (8.1.7) |
Oracle Servlet Engine |
8.1.7 |
A Web server built directly into the Oracle8i database. Oracle Servlet Engine includes an HTTP listener and the ability to distribute Java Server Pages (JSP's) and run servlets directly on the database. |
Oracle8i JVM Servlet Container |
Oracle Spatial
(formerly called Oracle Spatial Data Cartridge) |
8.1.7 |
Oracle Spatial makes the storage, retrieval, and manipulation of spatial data easier and more intuitive to users.
Oracle8i Spatial User's Guide and Reference |
Oracle Time Series
(formerly called Oracle8i Time Series Cartridge) |
8.1.7 |
Stores and retrieves time-stamped data using object data types.
Oracle8i Time Series User's Guide |
Oracle Universal Installer |
1.7.9.0 |
A Java-based application that lets you quickly install, update, and remove Oracle products. |
Oracle8i Installation Guide |
Oracle Utilities |
8.1.7 |
A suite of products used for database administration, including:
- DBVERIFY
- Export Utility
- Import Utility
- Migration Utility
- Password UtilityRecovery Manager
- Server Manager
- SQL*Loader
- TKPROF
Oracle8i Utilities |
Oracle Visual Information Retrieval
(formerly called Oracle8i Visual Information Retrieval) |
8.1.7 |
Provides image storage, content-based retrieval, and format conversion capabilities through an object data type. This option is a building block for various imaging applications, rather than being an end-user application. |
Oracle8i Visual Information Retrieval User's Guide and Reference |
Oracle8i Server |
8.1.7 |
The database component of the Oracle8i Enterprise Edition or Oracle8i software |
Getting to Know Oracle8i |
Oracle XML Developer's Kit |
8.1.7 |
This kit consists of a set of APIs for parsing and generating XML data. These interfaces have been written for Java, C, C++, and PL/SQL. This kit consists of the following components:
- XML Parser for Java
- XML Parser for C
- XML Parser for C++
- XML Parser for PL/SQL
- XML Class Generator for Java
- XML Class Generator for C++
- XML Transviewer Beans
- XSQL Servlet
Oracle8i Application Developer's Guide - XML
Oracle8i XML Reference |
Oracle XML SQL Utility |
2.0 |
This utility is a set of Java classes and PL/SQL wrappers that permit queries to return result sets or objects wrapped in XML. |
8.1.7 |
Enables users to use their browsers to run PL/SQL procedures stored in an Oracle database. The stored procedures can retrieve data from tables in the database, and generate HTTP responses to return to client browsers. The PL/SQL Embedded Gateway also includes the PL/SQL Web Toolkit. This toolkit is a set of PL/SQL packages that enables users to retrieve information about the HTTP request, specify values for HTTP headers, set cookies, and generate HTML pages. |
Oracle Internet Application Server Release: Using mod_plsql |
Pro*C/C++ |
8.1.7 |
Takes SQL statements embedded in C and C++ programs and converts them to standard C code. When you precompile this code, the result is a C or C++ program that you can compile and use to build applications that access an Oracle database.
This product requires a separate license as a part of Oracle Programmer. |
Pro*C/C++ Precompiler Programmer's Guide |
Pro*FORTRAN |
1.8.52 |
The Pro*FORTRAN precompiler) takes SQL statements embedded in your FORTRAN program and converts them to standard FORTRAN code. When you precompile this code, the result is a FORTRAN program that you can compile and use to build applications that access an Oracle database.
Pro*Fortran Supplement to the Oracle Precompilers Guide |
SQL*Plus |
8.1.7 |
Command line interface that allows SQL and PL/SQL database languages to be used with an Oracle database |
SQL*Plus User's Guide and Reference |
SQLJ |
8.1.7 |
A standard way to embed SQL statements in Java programs. |
SQLJ Runtime
(installed with SQLJ) |
8.1.7 |
A thin layer of pure Java code that runs above the JDBC driver. When Oracle SQLJ translates a SQLJ source code, embedded SQL commands in a Java application are replaced by calls to the SQLJ runtime. |
SQLJ Translator
8.1.7 |
A preprocessor for Java programs that contain embedded SQL statements. Oracle SQLJ Translator converts the SQL statements to JDBC calls. |
TCP/IP Protocol Support |
8.1.7 |
Enables client/server conversation over a network using TCP/IP and Net8. This combination of Oracle products enables an Oracle application on a client to communicate with remote Oracle databases through TCP/IP (if the Oracle database is running on a host system that supports network communication using TCP/IP).
Multi-Threaded Server Support (MTS) is available in TCP/IP networks.
Connection Pooling is available only with MTS on TCP/IP networks. |
XML Development Kit (the Oracle version) |
8.1.7 |
Required for integrating and running XML applications with the database. |
Not applicable |
