Oracle8i Administrator's Reference
Release 3 (8.1.7) 64 Bit for SGI IRIX
Part Number A87435_01
Go To Documentation Library
Library
Go To Product List
Product
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
3
Administering SQL*Plus
This chapter describes how to use and administer SQL*Plus on Oracle8i. It contains the following sections:
This section describes how to administer SQL*Plus.
Using Setup Files
When you start SQL*Plus, it executes the glogin.sql site profile setup file and then executes the login.sql user profile setup file.
Using the Site Profile File
The global site profile file is the $ORACLE_HOME/sqlplus/admin/glogin.sql directory. The default site profile is placed in the $ORACLE_HOME/sqlplus/admin directory when SQL*Plus is installed. If a site profile already exists, it is overwritten. If SQL*Plus is de-installed, the site profile file is deleted.
Using the User Profile File
The user profile file is login.sql. SQL*Plus looks in the current directory, and then in the directories you specify until it finds the login.sql file. You can specify the directories to search by setting the SQLPATH environment variable to a colon-separated list of directories.
For example, if the current directory is /u02/oracle and SQLPATH is set to /home:/home/oracle:/u01/oracle, SQL*Plus looks for the login.sql file in the following order:
  1. /u02/oracle (the current directory)
  2. /home
  3. /home/oracle
  4. /u01/oracle
The options set in the login.sql file override those set in the glogin.sql file.
See Also:
For more information on profile files, see the SQL*Plus User's Guide and Reference
Using the PRODUCT_USER_PROFILE Table
During a Typical installation, the PRODUCT_USER_PROFILE table is created automatically. This table is used to disable the SQL and SQL*Plus commands you specify. To recreate this table, run the
$ORACLE_HOME/sqlplus/admin/pupbld.sql script in the SYSTEM schema.
For example, enter:
$ sqlplus SYSTEM/MANAGER
SQL> @?/sqlplus/admin/pupbld.sql
SQL*Plus uses the value of the ORACLE_HOME environment variable wherever a question mark ( ? ) appears.
Using Demonstration Tables
SQL*Plus is shipped with demonstration tables that you can use for testing.
Performing a Typical Installation
During a Typical installation, the user SCOTT and the demonstration tables are created automatically.
Creating Demonstration Tables Manually
Use the $ORACLE_HOME/sqlplus/demo/demobld.sql SQL script to create the demonstration tables. In SQL*Plus, you can use any user name to run the demobld.sql file to create the demonstration tables in a schema. For example, enter:
$ sqlplus SCOTT/TIGER
SQL> @?/sqlplus/demo/demobld.sql
You can also use the $ORACLE_HOME/bin/demobld shell script to run the $ORACLE_HOME/sqlplus/demo/demobld.sql script by entering:
$ demobld scott tiger
Deleting Demonstration Tables
Use the $ORACLE_HOME/sqlplus/demo/demodrop.sql script to drop demonstration tables. In SQL*Plus, you can use any user name to drop the demonstration tables in the user's schema. For example, enter:
$ SQLPLUS SCOTT/TIGER
SQL> @?/sqlplus/demo/demodrop.sql
You can also use the $ORACLE_HOME/bin/demodrop shell script to run the $ORACLE_HOME/sqlplus/demo/demodrop.sql script by entering:
$ demodrop scott tiger
Both the demobld.sql and demodrop.sql scripts drop the EMP, DEPT, BONUS, SALGRADE, and DUMMY tables. Before to running either script, make sure that no table with one of these names exists in the desired schema, or the table data is lost.
Installing and Removing the Help Facility
This section describes how to install and remove the help facility.
When you copy a starter database with pre-built datafiles as part of the Typical installation or as an option in Oracle Database Configuration Assistant, SQL*Plus automatically installs the Help Facility.
Using the Database Configuration Assistant
You can use the Oracle Database Configuration Assistant to create help tables when creating a database.
Installing the Help Facility Manually
You can use the $ORACLE_HOME/bin/helpins shell script to manually install the help facility. Before you run the script, set the SYSTEM_PASS environment variable to the SYSTEM schema name and password. For example, enter:
$ setenv SYSTEM_PASS SYSTEM/MANAGER
$ helpins
If the SYSTEM_PASS variable is not set, the helpins scripts prompt you for the SYSTEM password and load the help data into the SYSTEM schema. Run the $ORACLE_HOME/sqlplus/help/helpbld.sql script with the helpus.sql script to create the help facility tables. Enter the following:
SQL> @?/sqlplus/admin/help/helpbld.sql
Both the helpins shell script and the helpbld.sql SQL*Plus script drop existing help facility tables before creating new tables.
For example, enter:
You can also run $ORACLE_HOME/sqlplus/help/helpdrop.sql in SQL*Plus to manually drop the help facility tables in a schema. For example, enter:
SQL> @?/sqlplus/admin/help/helpdrop.sql
See Also:
For more information on the help facility, see the SQL*Plus User's Guide and Reference
Using SQL*Plus
This section describes how to use SQL*Plus.
Using a System Editor from SQL*Plus
If you enter an ED or EDIT command at the SQL*Plus prompt, the system starts an operating system editor, such as ed, emacs, ned, or vi. Your PATH variable must include the directory of the editor.
When you start the editor, the current SQL buffer is placed in the editor. When you exit the editor, the changed SQL buffer is returned to SQL*Plus.
You can specify which editor starts by defining the SQL*Plus _editor variable. This variable can be set in glogin.sql, in login.sql, or entered during a SQL*Plus session. For example, to set the default editor to vi, enter:
SQL> DEFINE_EDITOR=VI
If you do not set the _editor variable, the value of either the EDITOR or VISUAL environment variable is used. If both are set, the EDITOR variable value is used. When _editor, EDITOR, and VISUAL are not specified, the default editor is ed.
If you run the editor, SQL*Plus uses the afiedt.buf temporary file to pass text to the editor. You can use the SET EDITFILE command to rename this file. For example, enter:
SQL> SET EDITFILE /tmp/myfile.sql
SQL*Plus does not delete the temporary file.
Running Operating System Commands from SQL*Plus
Using the HOST command or an exclamation point (!) as the first character after the SQL*Plus prompt causes subsequent characters to be passed to a sub-shell. The SHELL environment variable sets the shell used to execute operating system commands. The default shell is /bin/sh. If the shell cannot be executed, an error message is displayed.
To return to SQL*Plus, enter exit or press Ctrl+D.
For example, to enter one command, enter:
SQL>! COMMAND
In the preceding example, command  represents the operating system command you want to execute.
To enter multiple operating system commands from SQL*Plus, enter the HOST or ! command then press return. SQL*Plus returns you to the operating system prompt.
Interrupting SQL*Plus
While running SQL*Plus, you can stop the scrolling record display and terminate a SQL statement by pressing [Ctrl]+[c].
Using the SPOOL Command
The default extension name of files generated by the SPOOL command is .lst. To change this extension, specify a spool file containing a period (.). For example, enter:
SQL> SPOOL query.txt
Restrictions of SQL*Plus
This section describes SQL*Plus restrictions.
Resizing Windows
The default values for SQL*Plus LINESIZE and PAGESIZE do not automatically adjust for window size.
Return Codes
UNIX return codes use only one byte, which is not enough space to return an Oracle error code. The range for a return code is 0 to 255.
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Library
Go To Product List
Product
Contents
Go To Index
Index
