| Oracle financial Analyzer User's Guide Release 11i Part No. A87522-01 |
Introducing Financial Analyzer, 2 of 11
Financial Analyzer is a distributed software application that you can use to:
Financial Analyzer runs on a combination of networked personal computers and servers. A variety of software modules, known as workstations, are installed on the personal computers and servers and are set up to access common databases, called shared databases. These shared databases contain data and structures that are used throughout the Financial Analyzer system.
If web listener software has been installed and configured on the server, Financial Analyzer reports, graphs, and data entry forms can also be accessed through a web browser.
The Financial Analyzer environment includes two basic types of workstations, administrator workstations and user workstations.
The following types of administrator workstations are supported:
The following types of user workstations are supported:
The following table describes the types of databases that can be associated with Financial Analyzer workstations.
Using the Super administrator workstation as the starting point, you can build a tiered architecture by creating subordinate administrator workstations, which can in turn be used to create other subordinate administrator workstations.
This tiered approach to system design reduces the size and complexity of the top-level structures and permits greater autonomy and control at lower-level and remote sites.
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
