Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Getting Started, 5 of 10
The Financial Analyzer Toolbar
Definition: Toolbar
The toolbar provides quick access to frequently used commands.
Toolbar buttons
The following table shows each button on the toolbar and describes its function.
Button
Function
Graphic showing the New button.
Opens the New dialog box, which enables you to create a new document.
Graphic showing Open button.
Opens the Open dialog box, from which you can open a saved document.
Graphic showing Save button.
Enables you to save the active document.
Graphic showing Select button.
Opens the Selector dialog box, where you can specify the data with which you want to work.
Graphic showing Font button.
Displays the Font dialog box, which enables you to specify font, style, and size of text or data in a document.
Graphic showing Pattern button.
Opens the Patterns dialog box, which enables you to specify characteristics, such as color, pattern, line style, and width, in the current report, graph, or worksheet.
Graphic showing Format Number button.
Opens the Format Number dialog box, which enables you to change the format for numeric values and dates.
Graphic showing Save Data button.
The Save Data button saves the data in the current worksheet.
Graphic showing Graph Type button.
Opens the Graph Type dialog box, where you can choose the type of graph that you want to view.
Graphic showing Print button
Opens the Print dialog box, which enables you to print the active document.
Graphic showing Help button.
Enables you to access online information that explains how to perform a task or describes what is currently displayed on your screen.
Toolbar display options
You can control the following toolbar display options:
To specify toolbar options, choose Options from the Toolbar menu. This activates the Options dialog box, where you can make your selections.
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
