Starting Financial Analyzer
Logging in
You must connect to an Express Server session to start Financial Analyzer. After the first time you log in, the system saves the information that you enter in the Connect to Express Server dialog box. You only have to enter your password in subsequent sessions.
How to log into Express Server
Follow this procedure to log into Express Server.
- Double-click on the Financial Analyzer icon.
The Connect to Express Session dialog box appears.
- Complete the fields in the dialog box as follows:
- In the Username box, enter your username for the system on which the Express Server session you are logging into is located.
- In the Password box, enter your password.
- In the Domain box, enter the domain name for your PC, if required.
- In the Name box, enter the name of the personal database to which you want to connect.
- In the Path box, enter the full path for the database to which you want to connect.
- If you want to work in a stand-alone session, select Express installed on local workstation.
- In the Server box, enter the name of the server to which you want to connect.
- If multiple instances of Express Server are running on the server, enter the unique universal identifier (UUID) for the Express Server instance to which you want to connect.
- Select OK.
The Financial Analyzer main window appears.
Note: Contact your system administrator to obtain the correct login information for your system.
