Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Dimensions and Dimension Values, 4 of 5
Suggested Ways to Set Up Dimensions
Using dimensions in models
When the data associated with a financial data item needs to be calculated, a model is defined using one or more of the dimensions that make up the financial data item. For example, models might be based on dimensions such as Line Item and Account. Dimensions that are used in models typically aggregate over time and do not require hierarchies because Financial Analyzer provides a Time hierarchy.
Using dimensions in hierarchies
When the data associated with a financial data item needs to be aggregated into higher and lower levels of detail, a hierarchy is defined using one or more of the dimensions that make up the financial data item. For example, hierarchies might be based on dimensions such as Organization and Product. Dimensions that are used in hierarchies typically do not aggregate over time and are not used in models.
Using dimensions as attributes
When you need to establish a relationship between two dimensions for the purpose of selecting values of one dimension by their association with another dimension, an attribute can be defined to link them. Typically, the grouping dimension of an attribute is not used to dimension any financial data item, does not aggregate over time, is not used in a model, and does not require hierarchies.
Using custom time dimensions
You can set up time periods using either the Standard Time dimension, or you can create a custom time dimension. A custom time dimension requires hierarchies to build time relationships.
Suggested properties to assign when creating dimensions
The following table recommends the properties to assign to dimensions used in models, hierarchies, attributes, and custom time dimensions.
Property
Dimension used in model
Dimension used in hierarchy
Dimension used as attribute
Custom time dimension
Dimension Type
Text
Text
Text
Time
Dimension Options
  • Time Aggregations
  • B/W Variance Indicators
  • Maintain DBA Sort Order
  • Control Dimension Value Scaling
Users Who Can Define Hierarchies
  • DBA
  • EveryOne
  • NoOne
  • DBA
  • EveryOne
NoOne
  • DBA
  • EveryOne
Users Who Can Define Models
  • DBA
  • EveryOne
NoOne
NoOne
NoOne
Users Who Can Define Attributes
  • DBA
  • EveryOne
  • NoOne
  • DBA
  • EveryOne
  • DBA
  • EveryOne
NoOne
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
