Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Attributes, 4 of 4
Creating and Modifying Attributes
Creating attributes
You choose Attribute from the Maintain menu to create an attribute. This opens the Maintain Attribute dialog box. From this starting point, you can perform the following functions:
When you choose OK, the Edit Attribute dialog box appears. Here, you select dimension values for the dimensions in the attribute definition. You also set the relationships between the dimension values.
Example: Relationships for one-to-many attribute
The following illustration shows an example of the Edit Attribute dialog box with information for a one-to-many attribute, Product by Unit Type.
This graphic is described in surrounding text.
Example: Relationships for many-to-many attribute
The following illustration shows an example of the Edit Attribute dialog box with information for a many-to-many attribute, Product by Monitor Type Availability.
Modifying attributes
You choose Attributes from the Maintain menu to modify information for attributes. This opens the Maintain Attributes dialog box, from which you can perform the following functions:
Related information
For more information about working with attributes, search for the following topics in the Financial Analyzer Help system:
"Creating a Many-to-Many Attribute"
"Creating a One-to-Many Attribute"
"Deleting Attributes"
"Editing Many-to-Many Attributes"
"Editing a One-to-Many Attributes"
"Renaming Attributes"
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
