Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Selecting Data, 3 of 3
Selecting Values
Selectable objects
Depending on your current context when you access the Selector dialog box, you can select:
Moving values to the Selected box
When you work in the Selector dialog box, you place the values that you want to work with into the Selected box.
In the following illustration, three values for the Product dimension have been placed in the Selected box.
This graphic is described in surrounding text.
Methods for selecting values
In the Selector dialog box you can manually select values. You can also access a set of selection tools that enable you to do the following:
Selecting hierarchical values
If the dimension for which you are selecting values is part of one or more hierarchies and you want to display the values as they relate to a hierarchy, you must select the hierarchy from the Hierarchy box before selecting values. Selecting a hierarchy enables you to drill through levels of data in reports and worksheets.
Maximum amount of selectable values
When selecting values to include in a document, you cannot select more than 5000 values for an across or down edge.
Sorting selected values
You can sort the values that you have selected. Depending on the dimension for which you are selecting values, the following sort options are available:
Related information
For more information about selecting data, search for the following topics in the Financial Analyzer Help system:
"Selecting All Values of a Dimension"
"Selecting Values by Matching Characters"
"Selecting Top and Bottom Values"
"Selecting Values by Attribute"
"Selecting Values by Specifying Numerical Exception Criteria"
"Selecting Values by Specifying Variable Exception Criteria"
"Selecting Values Manually"
"Sorting Selected Values"
"Sorting Selected Values According to Their Order in the Database"
"Sorting Selected Values Alphabetically"
"Sorting Selected Values Manually"
"Sorting Selected Values Numerically by Data Value"
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
