Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Modeling Data, 5 of 6
Modeling Functions
Uses for functions
Financial Analyzer has many functions that you can use to make calculations and analyze data. You can use functions to perform the following tasks:
To use a function, you type its name and, in parentheses, some additional information. Each piece of information needed by a function is called an argument.
Types of functions
Financial Analyzer includes the following types of numeric functions.
Type of Function
Description
Advanced Mathematical
Functions that perform advanced mathematical calculations
Time-Series
Functions that retrieve values from a previous or future time period and perform calculations on those values
Financial
Functions that perform calculations for financial analysis
Aggregation
Functions that return an aggregate value, generally consisting of a single value for many values of the input expression
Advanced mathematical functions
Advanced mathematical functions operate on each dimension in the expression. The dimensions of the result are the union of the dimensions of the inputs. The following table describes these functions.
Function
Description
ABS
Calculates an absolute value
INTPART
Calculates the integer part of a value
LOG
Calculates the natural logarithm
LOG10
Calculates the logarithm base 10
MAX
Calculates the maximum between 2 expressions
MIN
Calculates the minimum between 2 expressions
RANDOM
Calculates a random number
REM
Calculates the remainder after a division
SQRT
Calculates the square root
Most advanced mathematical functions operate on a single numeric variable, but the MAX and MIN functions make comparisons between the values of two variables. For dimensioned variables, the MAX and MIN functions compare each value of one variable with the corresponding value of the other variable.
Time-series functions
The time-series functions retrieve and perform calculations on values from a previous or future time period. The following table describes these functions.
Function
Description
CUMSUM
Calculates cumulative sums over time
LAG
Calculates the value for a previous time period
LAGABSPCT
Calculates the percent difference between current and previous values and indicates the direction of change
LAGDIF
Calculates the difference between current and previous values
LAGPCT
LEAD
Calculates the value for a subsequent time period
MOVINGAVERAGE
Calculates a series of averages over time
MOVINGMAX
Returns a series of maximum values over time
MOVINGMIN
Returns a series of minimum values over time
MOVINGTOTAL
Calculates a series of totals over time
The data you retrieve with a time-series function is usually dimensioned by a time dimension, such as MONTH, PERIOD, or YEAR. LAG and LEAD actually can retrieve data of any type, but the other time-series functions handle numeric data only.
The LAG, LAGDIF, LAGPCT, LAGABSPCT, and LEAD functions let you compare data for the time dimension values in the current status with data from a previous or future time period. You specify the data expression you want to analyze, the number of time periods the function should go back or forward for the comparison, and the time dimension. LAG and LEAD simply return the past or future value.
The LAGDIF and LAGPCT functions make the most commonly used types of comparisons, that is, the difference and the percent difference, between the current data and the comparison value.
The moving functions (such as MOVINGTOTAL or MOVINGMAX) return a value for each time period in the status of a time dimension. The value is based on the data for a range of time periods that precede, include, or follow the period for which the value is being calculated. The range is always relative to the current period, so the range is always moving forward as you process each time value in the current status.
Financial functions
The financial functions provide standard calculations needed for financial analysis. The following table describes these functions.
Function
Description
DEPRDECL
Calculates declining-balance depreciation
DEPRSL
Calculates straight-line depreciation
DEPRSOYD
Calculates sum-of-year's-digits depreciation
FINTSCHED
Calculates the interest on a series of fixed-rate installment loans
FPMTSCHED
Calculates payments for a series of fixed-rate installment loans
IRR
Calculates the internal rate of return for a stream of cash flows
NPV
Calculates the net present value of a stream of cash flows
Aggregation functions
Functions that return an aggregate value ordinarily return one value for many values of the input expression. The following table describes these functions.
Function
Description
ANY
Tests if any values match a criterion (returns Boolean result)
AVERAGE
Calculates an average value
COUNT
Counts values that match a criterion
EVERY
Tests if every value matches a criterion (returns Boolean result)
LARGEST
Calculates the largest value
NONE
Tests if no value matches a criterion (returns Boolean result)
SMALLEST
Calculates the smallest value
STDDEV
Calculates the standard deviation using N-1
TALLY
Counts the number of dimension values corresponding to related dimension values
TCONVERT
Aggregates or allocates data based on time periods
TOTAL
Calculates a total value
Related information
For complete descriptions of modeling functions, refer to the Oracle Express Language Reference Manual or the Oracle Express Language online help.
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
