| Oracle financial Analyzer User's Guide Release 11i Part No. A87522-01 |
Transferring Structures and Data, 10 of 11
Super administrators and administrators define structures that are appropriate for their users and distribute those structures to the shared database and to their users. Users must then refresh structures in their personal databases so that their view of the data is consistent with their related shared database.
Budget workstation users can set the Automatic Refresh option in the Options dialog box so that a refresh process is automatically initiated if new structures are available to be refreshed when they log onto their systems. They can also choose not to set this option, which enables them to refresh structures manually.
Analyst and Administrator workstation users must always refresh newly available structures when they log in. For these users, the Automatic Refresh option is always on.
You can set the Show Refresh Preview option in the Options dialog box so that the Refresh Preview dialog box appears when you log onto your system and have structures to refresh. You can use this dialog box to view information about the structures that are available for refresh before you apply them to your database.
Depending on the type of workstation that you are using, one of the following types of refresh processes will take place:
You choose Refresh Structure from the Manage menu to manually refresh data structures. If there are new structures to refresh, the Refresh Preview dialog box appears. You can use this dialog box to view information about the structures that are available for refresh before you apply them to your database. When you choose Refresh, the structures are refreshed.
For more information about refreshing structures, search for the following topic in the Financial Analyzer Help system: "Refreshing Structures."
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
