Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Transferring Structures and Data, 4 of 11
Distributing Structures from Administrator Workstations
When to distribute
The following list outlines some of the conditions under which you would need to distribute structures to the shared database and to the users that you support:
Selecting structures, actions, and users
You choose Distribution, Data Structure from the Manage menu to distribute structures. This opens the Data Structure dialog box, where you fill in a selection grid that specifies the structures and their values, the distribution action, and the users who will receive the distribution.
Selecting distribution items
As you complete the Data Structure dialog box, you select the structure items that you want to distribute. You can choose one or more of the following:
Selecting distribution actions
As you complete the Data Structure dialog box, you choose a distribution action for each structure. You can choose one of the following:
Selecting users
As you complete the Data Structure dialog box, you select the users who will receive the distribution.
Example: Distributing structures
The following example illustrates a completed Distribute Structures dialog box. In this example, the selected structures will be distributed to eight users.
This graphic is described in surrounding text.
Limits on document distribution
Do not distribute more than 3000 documents. Also, bear in mind that distributing an extremely large number of documents, such as 1000, might degrade system performance.
Using distribution profiles
You can save the information that you enter in the Distribute Structure dialog box as a distribution profile. A distribution profile captures the information in the selection grid and saves it for reuse. You can apply the profile at a later time -- either exactly as is, or as a template for defining similar distributions.
To name and save a distribution profile, complete the grid in the Distribute Structure Dialog box and choose Save Profile.
To retrieve a list of saved profiles, choose Profiles.
Note: Distributing structures for new dimension values
If you distribute new dimension values to your users, you must also redistribute the dimensions with which the values are associated. If you do not redistribute the dimensions along with the new dimension values, users may have trouble contributing data associated with those values back to the shared database.
Note: When structures have the same name
If you distribute a structure to a user who has already created a structure with the same name in their personal database, the new structure will appear in the "DBA Items to Overwrite Personal" column when the user performs a Refresh Preview. When the refresh is performed, the current structure in the user's personal database will be overwritten by the newly distributed structure.
Submitting structure distributions to the Task Processor
After you specify structures for distribution, you must submit the distribution. Submitting a distribution sends it to the Task Processor.
If your system is not set up to continually run the Task Processor as a separate workstation or in the background, you must manually start the Task Processor so that the task will run.
Related information
For more information about distributing structures, search for the following topics in the Financial Analyzer Help system:
"Creating a Distribution Profile"
"Distributing Structures"
"Using a Distribution Profile"
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
