Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Managing User Access, 3 of 6
Maintaining Users
About maintaining users
You choose Users from the Manage menu to maintain users. This opens the Manage Users dialog box, where you can perform the following maintenance functions:
If you remove a user
When you delete a user or remove a user name, that user's database and icon are not automatically deleted. However, if a user that you have deleted attempts to log in, that user will receive an error message stating that they are not a valid Financial Analyzer user and the login process will be discontinued.
Deleting or removing a user, creates a user task and sends it to the Task Processor. If you are not running the Task Processor in the background, you must run it in the foreground to process the user task.
Example: Maintaining users
The following illustrations shows the Manage Users dialog box.
This graphic is described in surrounding text.
Related information
For more information about maintaining users, search for the following topics in the Financial Analyzer Help system:
"Deleting Users"
"Moving Users"
"Renaming Users"
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
