Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Managing User Access, 6 of 6
Managing Write Access Profiles
Deleting write access profiles
When a write access profile is no longer appropriate, you can delete it. Deleting a write access profile deletes both the write access restriction and the associated data slice definition.
Editing write access profiles
You can modify a write access profile by making new value selections for the data slice. For example, you might update a write access profile that restricts write access to November Actuals, to restrict write access to December Actuals.
You can also modify a write access profile by clearing the Deny function. This removes the write access restriction, but maintains the data slice definition for reuse.
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
