Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Data Entry Forms, 6 of 7
Distributing Data Entry Forms
About distributing data entry forms
You must distribute a data entry form to all users who will use the form to enter data. You can distribute data entry forms to any type of user: administrator, budget, analyst, or external.
Distributing associated objects
When you distribute a data entry form, its dimension values, hierarchies, and model must also be explicitly distributed. If only a subset of the dimension values are distributed, then only that subset will appear when the form is viewed in the Web interface.
If the data entry form includes a solve definition, the solve is automatically distributed with the form. However, if the solve includes a model, you must also distribute the models or hierarchies associated with the solve.
If you have added the form to a folder, you must distribute the folder.
Procedure: Distributing a data entry form
To distribute a data entry form, select Distribution, Distribute Structures from the Manage menu. Then choose Data Entry Form as the structure to distribute.
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
