| Oracle financial Analyzer User's Guide Release 11i Part No. A87522-01 |
The Financial Analyzer Web Interface, 2 of 7
The Financial Analyzer Web interface provides access to reports, graphs, and data entry forms through a Web browser.
In addition to the standard Financial Analyzer server components, the following server components must be installed:
For more information, refer to the Oracle Financial Analyzer Installation and Upgrade Guide.
Users must have the appropriate browser installed on the PC. For information about Web browser requirements, refer to the release notes for Oracle Express Web Agent.
To access Financial Analyzer through the Web interface, you must have a valid user ID. You must also be set up as a user in Financial Analyzer.
Financial Analyzer can be configured for direct access, or for access through Oracle Applications. You administrator will tell you which method to use and will provide the required URL and login information.
Following are some guidelines for logging in:
Note: Login sessions have a maximum idle time. A session will terminate automatically if it is idle for this time period.
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
