Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Working with Web Reports and Graphs, 11 of 13
Exporting Data from Web Reports and Graphs
About exporting data from reports and graphs
You can export dimension labels and data values from an open report or graph to a file format that can be used in a spreadsheet.
Note: If a document contains many pages of data, you might have difficulty opening the exported file in certain applications. To avoid this situation, modify the data selections to reduce the number of values before exporting the document.
Procedure: Exporting data from a report or graph
To export data from a report or graph, follow these steps:
  1. With the document open in the workspace, click the Export button on the Document toolbar.
    Graphic showing the Export button
    Result: The Export dialog box appears.
  2. Specify the pages to export: Current or All n pages.
  3. Select an export format:
    • Comma delimited (*.csv) -- Exports the data in Comma Separated Value format, in which labels and data values are separated by commas
    • Tab delimited (*.txt) -- Exports the data in text file format, in which labels and data values are separated by tabs
  4. Choose OK to export the data.
    Result: Depending on your browser configuration, the labels and data from the worksheet may be displayed in a spreadsheet, or you may be prompted to perform additional tasks, such as saving the file to disk or choosing the application in which to display the data.
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
