Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Working with Web Reports and Graphs, 12 of 13
Using Folders to Manage Web Reports and Graphs
Folders organize personal documents for analyst users
If you are an analyst user, you can create personal folders to organize the reports and graphs that you create. You can populate a folder with saved documents. You can also add documents to a folder, delete documents from a folder, and copy and move documents between folders.
Procedure: Creating a folder
To create a new folder, follow these steps:
  1. On the Navigation toolbar, click the New button,
    Graphic showing New button
    and choose New Folder from the popup menu.
    Alternatively, you can right-click Documents in the navigation list and choose New Folder from the popup menu.
    Result: The New Folder dialog box appears.
  2. Enter a name for the folder and choose OK.
    Result: The new folder is displayed as a personal object in the navigation list.
Adding a document to a folder
When you save a personal report or graph, you have the option to add it to a folder that you have previously created.
For a Web report or graph, you specify the folder in the Save As dialog box, as shown following.
This graphic is described in surrounding text.
If you choose (none), the document will be saved in the main Documents folder.
Moving or copying documents between folders
If you are an analyst user, you can move a personal report or graph from one folder to another in the navigation list. You can also copy a personal report or graph to another folder.
Selecting documents to move or copy
Select documents to move or copy as follows:
Moving reports and graphs
You can use the following methods to move personal reports and graphs within the navigation list:
Copying reports and graphs
You can use the following methods to copy reports and graphs within the navigation list:
Removing a document from a folder
If you are an analyst user, you can remove a personal document from a folder in the navigation list.
To remove a document from a folder, open the folder, select the document, and click the Delete button on the Navigation toolbar.
Graphic showing Delete button.
Alternatively, you can right-click the document and choose Delete from the popup menu.
In either case, the system will prompt you to confirm the deletion.
Result: The document is removed from the specified folder. If there is a copy of the document in another folder, it is not removed.
Changing the order of documents in a folder
If you are an analyst user, you can change the current order of personal documents in a folder by dragging a document from its current position to a new position. Proceed as follows:
  1. Open the folder.
  2. Select one or more documents.
  3. Drag the selection to a new location in the folder. As you move the cursor, a black bar appears to help you identify the new position.
  4. When the black bar is below the desired position, release the selection.
Note: You cannot change the order of documents in the main Documents folder
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
