Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Working with Web Reports and Graphs, 13 of 13
Working with Reports and Graphs in the Navigation List
Navigation list functions for reports and graphs
You use the navigation list to open reports and graphs. If you are an analyst user, you can also use the navigation list to create and maintain personal reports, graphs, and folders.
In addition, you can work with reports and graphs in the navigation list as follows:
Procedure: Deleting a report or graph
To delete a personal report or graph, click the document in the navigation list and click the Delete button on the Navigation toolbar.
Graphic showing Delete button.
Alternatively, you can right-click the document and choose Delete from the popup menu.
In either case you will be prompted to confirm the deletion.
Note: If the document is in more than one folder, it will be deleted only from the specified folder.
Procedure: Renaming a report or graph
To rename a personal report or graph, right-click the document in the navigation list and choose Rename from the popup menu. Then type the new name.
Note: If the document is in more than one folder, it will be renamed in all folders.
Procedure: Viewing the properties of a report or graph
To view the properties for a report or graph, right-click the document in the navigation list and choose Properties from the popup menu.
The following information appears:
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
