| Oracle financial Analyzer User's Guide Release 11i Part No. A87522-01 |
Working with Web Data Entry Forms, 7 of 7
You can export dimension labels and data values from a data entry form to a file format that can be used in a spreadsheet.
Note: If the form contains many pages of data, you might have difficulty opening the exported file in certain applications. To avoid this situation, modify the data selections to reduce the number of values before exporting the document.
Follow these steps to export data from a Web data entry form.
Result: The Export dialog box appears.
Result: Depending on your browser configuration, the labels and data from the worksheet may be displayed in a spreadsheet, or you may be prompted to perform additional tasks, such as saving the file to disk or choosing the application in which to display the data.
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
