Oracle financial Analyzer User's Guide
Release 11i
Part No. A87522-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Express Spreadsheet Add-In , 7 of 7
Data Collection Toolkit Technical Reference
Introduction
This topic describes Financial Analyzer API calls that are used by the routines defined in the macro module of the sample workbook template.
The following table describes the API call that attaches the Financial Analyzer code and shared databases.
Characteristic
Description
Routine name
OFA.EXT.INIT
Purpose
Runs the Financial Analyzer startup routine. Attaches code databases and populated temporary catalogs. Attaches the shared databases and establishes permit security based on the operating system user id.
Input
Blank
Path to the OFASYSCF.CFG file
Returns
The following table describes the API call that checks the Task Queue for any waiting task for a particular user.
Characteristic
Description
Routine name
TK.CHK.UNPROC
Description:
This routine takes as input an internal Financial Analyzer user name and then uses it to limit TK.PROP value USER. It then checks the TK.CATALOG for TK.PROP value STATUS of WAITING or IN PROGRESS.
Input:
Financial Analyzer internal user name (i.e., 'AA' for super user)
Returns:
YES -- Tasks are waiting to be processed for this user
NO -- No tasks are waiting
The following table describes the API call that runs a solve definition on a particular financial data item.
Characteristic
Description
Routine name:
SO.RUN.DFN
Description:
This routine sets the status of a financial data item using user defined valuesets and runs a solve definition of that financial data item.
Input:
Solve definition name (SO.ENTRY)
Multiline text variable containing valueset names with which to limit the financial data item's dimensions
Returns:
YES -- If successful
NO -- If unsuccessful
The following table describes the API call that submits data to the shared database.
Characteristic
Description
Routine name:
SB.DATA.SHR
Description
This routine sets the status of data for the financial data item using user defined valuesets. It also submits data for the financial data item to the task queue to update the shared database
Input
Financial Analyzer financial data item
Returns
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
