| Oracle financial Analyzer User's Guide Release 11i Part No. A87522-01 |
Data Loaders, 5 of 5
This topic contains two sample data files, one that loads information into Express database and metadata objects, and one that loads financial data into a financial data item. Both files have fixed-length fields.
In this example, the data file loads values into the Express database and metadata objects associated with the Organization dimension. The Oracle Express Administrator Database Browser displays information for the Express dimension objects and for the Express variable that stores the Actual financial data item.
Note: These are the objects that you drag from the Database Browser window to the Express Object column in the Import Text Dialog box when you create the data loader program for this sample data file.
The following is the name and description of the dimension into which dimension values will be loaded.
The following is the dimension value name variable into which dimension value names will be loaded.
The following is the row label variable into which dimension value row labels will be loaded.
The following is the column label variable into which dimension value column labels will be loaded.
The following is the self-relation into which the parent and child relationships between values of the Org dimension, which create the structure of a hierarchy, will be loaded.
The following is the name and description of the relation into which the one-to-many relationships between values of the Org dimension and another Financial Analyzer dimension, which create the structure of an attribute, will be loaded.
The following is the sample data file.
In this example, the data file references the values in the Express database associated with the Organization, Line, Product, and Time dimensions. It then loads financial data into a financial data item called Actuals.
Note: These are the objects that you drag from the Database Browser window to the Express Object column in the Import Text dialog box when you create the data loader program for this sample data file.
The Oracle Express Administrator Database Browser displays information for the Express dimension objects and for the Express variable that stores the Actuals financial data item.
The following is the object name and description of the Organization dimension, which is referenced when data is loaded into the Actuals financial data item.
The following is the object name and description of the Line dimension, which is referenced when data is loaded into the Actuals financial data item.
The following is the object name and description of the Product dimension, which is referenced when data is loaded into the Actuals financial data item.
The following is the object name and description of the Time dimension, which is referenced when data is loaded into the Actuals financial data item.
The following is the object name and description of the Actuals variable, into which financial data for the Actuals financial data item will be loaded.
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
