Oracle Financial Analyzer Installation and Upgrade Guide
Release 11i
Part No. A87523-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to beginning of chapter Go the next page
Before You Begin, 2 of 7
Server Requirements
Express Server installation
Before you install Financial Analyzer, you must install, configure, and start up Oracle Express Server (hereinafter referred to as "Express Server") release 6.3.2.1, running as a service on Windows NT or Unix.
Configuring Express Server
For optimal support of Financial Analyzer, follow these guidelines:
For more information about installing, configuring, and starting up Express Server, refer to the Express Installation and Configuration Guide and the Express Installation Help system.
Express Server client support files
You must install client support files from the Express Server CD-ROM.
Important: After installing the client support files, verify that the location of the client support files is included in the ServerDBPath in the Express Server Instance Manager. Refer to Appendix A for more information.
Express Server Administrative Tools
You must install the Express Server Administration Tools from the Express Server CD-ROM.
Server hardware requirements
Refer to the Oracle Financial Analyzer Release Notes for hardware information.
Server disk space requirements
Disk space requirements for installing Financial Analyzer on the server are as follows.
Component
Disk Space Requirements
Code databases
35MB
Shared databases
13MB
Personal databases for thin client workstations
Super administrator
Administrator
Budget
Analyst
Task Processor
Shell EIF files
4MB
4MB
4MB
3MB
1MB
1MB
Important: The disk space requirements for the personal and shared databases are minimum guidelines only. You must consider the additional disk space that you will need as you add database structures and financial data to the system.
Go to previous page Go to beginning of chapter Go to next page
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
