| Oracle Financial Analyzer Installation and Upgrade Guide Release 11i Part No. A87523-01 |
Before You Begin, 3 of 7
In order to install Financial Analyzer, a PC must meet the following hardware requirements:
The following table lists minimum disk space requirements for installing the Financial Analyzer software on client workstations.
Component |
Thick Client |
Thin Client |
SNAPI |
1.55MB |
1.55MB |
User Interface |
15MB |
15MB |
Code components |
12MB |
Personal databases |
Important: The disk space requirements are minimum guidelines only. For thick client workstations, you must also consider the additional disk space that you will need as you add database structures and financial data to the system.
In order to install Financial Analyzer, a PC must meet the following software requirements:
You must install TCP/IP support on the PC. TCP/IP is the network protocol used to communicate with Personal Express.
In exceptional cases, there may be a problem connecting to Personal Express using a TCP/IP product. If you suspect that your TCP/IP installation is causing a connection problem, notify Oracle Server Technical Support.
A Windows NT workstation requires a 15MB permanent swap file.
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
