| Oracle Financial Analyzer Installation and Upgrade Guide Release 11i Part No. A87523-01 |
Before You Begin, 4 of 7
If you want to use the Oracle Express Spreadsheet Add-In (hereinafter referred to as "Express Spreadsheet Add-In") or allow users to access Financial Analyzer through the Web, you must install and configure additional software. If you think you will want to use these features at any time in the future, you should install the software listed in the following topics before you install Financial Analyzer. You can install the additional software after you install Financial Analyzer if you decide that you need it later, but the installation process will be easier if you install the additional software first.
If users will access Financial Analyzer through the Web, you must install the following components on the same network as Express Server:
For detailed instructions on how to install and configure each of these components, see the documentation for each component.
For information about configuring Financial Analyzer for Web access once you have installed the required components, see "Configuring Financial Analyzer for Web Access".
Users who will access Financial Analyzer through the Web must have one of the following browsers installed on the PC:
Oracle Corporation recommends the following minimums for browser cache settings:
You must install Oracle Express Administrator (hereinafter referred to as "Administrator") release 6.3.2.1 if you want to use it in conjunction with Financial Analyzer. Install Administrator from the Express Client CD-ROM. For detailed instructions about installing and configuring Administrator, refer to the Express Installation and Configuration Guide and the Express Installation Help system.
You must install the Express Spreadsheet Add-In if you want to use it in conjunction with Financial Analyzer. For detailed installation instructions, refer to the Oracle Express Spreadsheet Add-In User's Guide.
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
