| Oracle Financial Analyzer Installation and Upgrade Guide Release 11i Part No. A87523-01 |
Installing the Software, 11 of 14
Follow these general steps to configure Financial Analyzer for Web access:
Follow these steps to enable Web Agent security:
WebAuthenticationType=BASIC
or
WebAuthenticationType=FORM
Leave all other settings as the default.
RequirePasswordEncryption=NO
Note: After you complete the above procedure, you must restart Express Server to enable Web Agent security.
Follow these steps to modify the Web listener.
Important: You can change the name of the ofastart directory, but you cannot change the name of the ofaweb directory.
Notes: If you an enabling more than one shared database for Web access with one Web listener you will need to specify unique ofastart virtual directories for each shared database.
Unix is case sensitive, so you must use the correct case when you enter the virtual directories. NT is not case sensitive.
The virtdirs.txt text file describes the virtual directory structures that you must create. It is located in the ofaweb directory on the Web Agent server.
The Web listener checks that the directories that you entered exist. If any directories are not present, you receive an error message.
Important: If you move or delete any of the files or directories on the server that are referenced in the Web listener directory mappings, you must update the mappings to refer to the new locations.
To complete the configuration of Financial Analyzer for Web access, provide users who are to have Web access to a shared database with a URL that consists of the name of the Web server and the name of the virtual directory for the shared database (ofastart).
For example, assume that the name of the Web server is servername. Users can access the shared database on the Web by specifying the following URL in their browsers:
http://servername/ofastart
Notify your users that they must accept cookies if they are prompted to do so. Also alert them that the Netscape browser will prompt them to download Java classes the first time that they access Financial Analyzer on the Web. If they have chosen Smart Update, they will be asked to specify a location for downloading these files.
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
