Performing a Shared Installation on a Client PC
Procedure: Beginning a shared installation
Follow these steps to begin the installation of Financial Analyzer on a client PC from a staging area on the network:
- For a workstation that will access the server in thick client mode, ensure that Personal Express Server 6.3.2 has been installed on the workstation.
- Run the the
setup.exe file that performs the shared installation, as instructed by your database administrator. The setup.exe file is located in the shared OLAP home on the network.
Note: The shared OLAP home is the area on the network in which the staging area for the shared installation has been established, as described in "Procedure: Setting up a shared OLAP home on the network".
- On the Welcome screen, choose Next.
- On the File Locations screen under Destination, specify the Oracle Home that you want to use, then choose Next.
- The Available Products screen appears. This screen allows you to choose whether to perform a thinner client, thin client, or thick client installation. Select the desired client mode, then choose Next.
Note: If you choose the thick client installation and you have not yet installed Personal Express Server, Installer issues a prompt that reminds you to install Personal Express Server after you have completed the Financial Analyzer installation. Choose Next on the prompt screen to continue with the Financial Analyzer installation.
- Depending on the client mode that you have chosen to install, do one of the following.
Procedure: Completing a thinner client shared installation
The following procedure describes the additional steps to follow if you are performing a thinner client installation.
- On the Thinner Client Installation: Location screen, specify the path for the application initialization file (
OFA.INI). You can use the default path, you can use the Browse button to choose a different path, or you can type a path name. After you have specified the path information, choose Next.
- On the Thin Client Installation: Server Type screen, select the operating system for the server where the personal database is to run, then choose Next.
- On the Summary screen, make sure that all of the specifications for the installation are correct, then choose Install.
Installer installs the products that you have selected.
- On the End of Installation screen, choose Exit to close Installer or choose Next Install to install additional Oracle products.
Procedure: Completing a thin client shared installation
The following procedure describes the additional steps to follow if you are performing a thin client installation.
- On the Thin Client Installation: Location screen, specify the path for the application initialization file (
Procedure: Completing a thick client shared installation
The following procedure describes the additional steps to follow if you are performing a thick client installation.
- On the Thick Client Installation: Location screen, specify the path for the location of the Budget workstation personal database file. You can use the default path, you can use the Browse button to choose a different path, or you can type a path name. After you have specified the path information, choose Next.
- On the Thick Client Installation: Shared Database Information screen, specify the following information for the shared database that the Budget workstation is to access on the server.
- The path for the shared database
- The server name
- The Express port number
After you have specified the above information, choose Next.
- On the Thick Client Installation: Server Type screen, select the operating system for the server where Express Server is running.
