| Oracle Financial Analyzer Installation and Upgrade Guide Release 11i Part No. A87523-01 |
Troubleshooting the Initial Startup Process, 2 of 4
If there is an error in connecting to Express, you may receive the following message: "Cannot connect to Express."
The message "Cannot connect to Express" indicates that you are not able to make a connection to an Express Server session for one of the following reasons:
Username
Password
Domain, if required
Server, if required
UUID or EndPoint, if required
xpdb.db file is located in the oracle_home/OLAP/OES630/SERVICE/OEC630 directory. If the directory and file do not exist, they have not been installed. Install them. If the file exists, check the File I/O option in the Express Service Configuration Manager to verify that the ServerDBPath setting contains the oracle_home/OLAP/OES630/SERVICE/OEC630 directory. If it does not, edit the setting.
Log on locally right. Check with your network administrator to verify that this right has been set for the network ID.
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
