| Oracle Financial Analyzer Installation and Upgrade Guide Release 11i Part No. A87523-01 |
Reducing the Number of Code Databases on a Server, 3 of 3
This topic describes how to reduce the number of code databases on a single server.
The following procedure explains how to reduce the number of code databases on a single server:
ofasyscf.cfg file associated with the shared database of each workstation or cluster so that the CODECFGPATH entry references that code database.
Note: You can retain the unused copies of the code database, but they will not be accessed when you use your Financial Analyzer system.
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
