| Oracle interMedia User's Guide and Reference Release 9.0.1 Part Number A88786-01 |
The following tables describe the audio file and compression formats and other audio features supported by interMedia.
To use these tables, find the data format you are interested in, and then determine the supported formats. For example, Table A-1 shows that interMedia supports AIFF format for single channel, stereo, 8-bit and 16-bit samples, linear PCM encoding, and uncompressed format.
| Format | Audio Feature |
Format ID `AIFC' |
Single channel |
| Format | Encoding/CompressionType |
Choose one of these compression formatsFoot 1 |
1
Other than "uncompressed (TWOS)", all other codes are the FourCC (uppercased) directly from the compressionType field of Common Chunk of the AIFC file. The table lists only the ones known. |
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
