Oracle interMedia User's Guide and Reference
Release 9.0.1
Part Number A88786-01
Go To Documentation Library
Library
Go To Product List
Product
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
6
ORDAudio Reference Information
Oracle interMedia contains information about the ORDAudio type:
The examples in this chapter assume that the test audio table TAUD has been created and filled with data. This table was created using the SQL statements described in Section 6.3.1.
If you manipulate the audio data itself (by either directly modifying the BLOB or changing the external source), then you must ensure that the object attributes stay synchronized and the update time is modified; otherwise, the object attributes will not match the audio data.
Methods invoked at the ORDSource level that are handed off to the source plug-in for processing have ctx(RAW(4000)) as the first argument. Before calling any of these methods for the first time, the client must allocate the ctx structure, initialize it to NULL, and invoke the openSource( ) method. At this point, the source plug-in can initialize context for this client. When processing is complete, the client should invoke the closeSource( ) method.
Methods invoked from a source plug-in call have the first argument as ctx (RAW(4000)).
Methods invoked at the ORDAudio level that are handed off to the format plug-in for processing have ctx (RAW(4000)) as the first argument. Before calling any of these methods for the first time, the client must allocate the ctx structure and initialize it to NULL.
In the current release, not all source or format plug-ins will use the ctx argument, but if you code as previously described, your application should work with any current or future source or format plug-in.
You should use any of the individual set methods to set the value of the attribute for an object for formats not natively supported; otherwise, for formats natively supported, use the setProperties( ) method to populate the attributes of the object.
6.1 Object Types
Oracle interMedia describes the ORDAudio object type, which supports the storage and management of audio data.
ORDAudio Object Type
The ORDAudio object type supports the storage and management of audio data. This object type is defined as follows:
CREATE OR REPLACE TYPE ORDAudio
AS OBJECT
  -- ATTRIBUTES
description         VARCHAR2(4000),
source              ORDSource,
format              VARCHAR2(31),
mimeType            VARCHAR2(4000),
comments            CLOB,
  -- AUDIO RELATED ATTRIBUTES
encoding            VARCHAR2(256),
numberOfChannels    INTEGER,
samplingRate        INTEGER,
sampleSize          INTEGER,
compressionType     VARCHAR2(4000),
audioDuration       INTEGER,
  -- METHODS
-- CONSTRUCTORS
STATIC FUNCTION init( ) RETURN ORDAudio,
STATIC FUNCTION init(srcType     IN VARCHAR2,
                     srcLocation IN VARCHAR2,
                     srcName     IN VARCHAR2) RETURN ORDAudio,
-- Methods associated with the date attribute
MEMBER FUNCTION getUpdateTime( ) RETURN DATE,
PRAGMA RESTRICT_REFERENCES(getUpdateTime, WNDS, WNPS, RNDS, RNPS),
MEMBER PROCEDURE setUpdateTime(current_time DATE),
-- Methods associated with the description attribute
MEMBER PROCEDURE setDescription(user_description IN VARCHAR2),
MEMBER FUNCTION getDescription( ) RETURN VARCHAR2,
PRAGMA RESTRICT_REFERENCES(getDescription, WNDS, WNPS, RNDS, RNPS),
-- Methods associated with the mimeType attribute
MEMBER PROCEDURE setMimeType(mime IN VARCHAR2),
MEMBER FUNCTION getMimeType( ) RETURN VARCHAR2,
PRAGMA RESTRICT_REFERENCES(getMimeType, WNDS, WNPS, RNDS, RNPS),
-- Methods associated with the source attribute
MEMBER FUNCTION processSourceCommand(
                                     ctx       IN OUT RAW,
                                     cmd       IN VARCHAR2,
                                     arguments IN VARCHAR2,
                                     result    OUT RAW)
                RETURN RAW,
MEMBER FUNCTION  isLocal( ) RETURN BOOLEAN,
PRAGMA RESTRICT_REFERENCES(isLocal, WNDS, WNPS, RNDS, RNPS),
MEMBER PROCEDURE  setLocal( ),
MEMBER PROCEDURE  clearLocal( ),
MEMBER PROCEDURE setSource(
                           source_type     IN VARCHAR2,
                           source_location IN VARCHAR2,
                           source_name     IN VARCHAR2),
MEMBER FUNCTION getSource( ) RETURN VARCHAR2,
PRAGMA RESTRICT_REFERENCES(getSource, WNDS, WNPS, RNDS, RNPS),
MEMBER FUNCTION getSourceType( ) RETURN VARCHAR2,
PRAGMA RESTRICT_REFERENCES(getSourceType, WNDS, WNPS, RNDS, RNPS),
MEMBER FUNCTION getSourceLocation( ) RETURN VARCHAR2,
PRAGMA RESTRICT_REFERENCES(getSourceLocation, WNDS, WNPS, RNDS, RNPS),
MEMBER FUNCTION getSourceName( ) RETURN VARCHAR2,
PRAGMA RESTRICT_REFERENCES(getSourceName, WNDS, WNPS, RNDS, RNPS),
MEMBER PROCEDURE import(ctx IN OUT RAW),
MEMBER PROCEDURE importFrom(
                            ctx             IN OUT RAW,
MEMBER PROCEDURE export(
                        ctx             IN OUT RAW,
MEMBER FUNCTION getContentLength(ctx IN OUT RAW) RETURN INTEGER,
PRAGMA RESTRICT_REFERENCES(getContentLength, WNDS, WNPS, RNDS, RNPS),
MEMBER PROCEDURE getContentInLob(
                                ctx      IN OUT RAW,
                                dest_lob IN OUT NOCOPY BLOB,
                                mimeType OUT VARCHAR2,
                                format   OUT VARCHAR2),
MEMBER FUNCTION getContent( ) RETURN BLOB,
PRAGMA RESTRICT_REFERENCES(getContent, WNDS, WNPS, RNDS, RNPS),
MEMBER PROCEDURE deleteContent( ),
MEMBER FUNCTION getBFILE( ) RETURN BFILE,
PRAGMA RESTRICT_REFERENCES(getBFILE, WNDS, WNPS, RNDS, RNPS),
-- Methods associated with file operations on the source
MEMBER FUNCTION openSource(userArg IN RAW, ctx OUT RAW) RETURN INTEGER,
MEMBER FUNCTION closeSource(ctx IN OUT RAW) RETURN INTEGER,
MEMBER FUNCTION trimSource(ctx     IN OUT RAW,
                           newlen  IN INTEGER) RETURN INTEGER,
MEMBER PROCEDURE readFromSource(
                                ctx      IN OUT RAW,
                                startPos IN INTEGER,
                                numBytes IN OUT INTEGER,
                                buffer   OUT RAW),
MEMBER PROCEDURE writeToSource(
                               ctx      IN OUT RAW,
                               buffer   IN RAW),
-- Methods associated with audio attributes accessors
MEMBER PROCEDURE setFormat(knownformat IN VARCHAR2),
MEMBER FUNCTION getFormat( ) RETURN VARCHAR2,
PRAGMA RESTRICT_REFERENCES(getFormat, WNDS, WNPS, RNDS, RNPS),
MEMBER PROCEDURE setEncoding(knownEncoding IN VARCHAR2),
MEMBER FUNCTION getEncoding( ) RETURN VARCHAR2,
PRAGMA RESTRICT_REFERENCES(getEncoding, WNDS, WNPS, RNDS, RNPS),
MEMBER PROCEDURE setNumberOfChannels(knownNumberOfChannels IN INTEGER),
MEMBER FUNCTION getNumberOfChannels( ) RETURN INTEGER,
PRAGMA RESTRICT_REFERENCES(getNumberOfChannels, WNDS, WNPS, RNDS, RNPS),
MEMBER PROCEDURE setSamplingRate(knownSamplingRate IN INTEGER),
MEMBER FUNCTION getSamplingRate( ) RETURN INTEGER,
PRAGMA RESTRICT_REFERENCES(getSamplingRate, WNDS, WNPS, RNDS, RNPS),
MEMBER PROCEDURE setSampleSize(knownSampleSize IN INTEGER),
MEMBER FUNCTION getSampleSize( ) RETURN INTEGER,
PRAGMA RESTRICT_REFERENCES(getSampleSize, WNDS, WNPS, RNDS, RNPS),
MEMBER PROCEDURE setCompressionType(knownCompressionType IN VARCHAR2),
MEMBER FUNCTION getCompressionType( ) RETURN VARCHAR2,
PRAGMA RESTRICT_REFERENCES(getCompressionType, WNDS, WNPS, RNDS, RNPS),
MEMBER PROCEDURE setAudioDuration(knownAudioDuration IN INTEGER),
MEMBER FUNCTION getAudioDuration( ) RETURN INTEGER,
PRAGMA RESTRICT_REFERENCES(getAudioDuration, WNDS, WNPS, RNDS, RNPS),
MEMBER PROCEDURE setKnownAttributes(
                                    knownFormat IN VARCHAR2,
                                    knownEncoding IN VARCHAR2,
                                    knownNumberOfChannels IN INTEGER,
                                    knownSamplingRate IN INTEGER,
                                    knownSampleSize IN INTEGER,
                                    knownCompressionType IN VARCHAR2,
-- Methods associated with setting all the properties
MEMBER PROCEDURE setProperties(ctx         IN OUT RAW,
                               setComments IN BOOLEAN),
MEMBER FUNCTION checkProperties(ctx IN OUT RAW) RETURN BOOLEAN,
MEMBER FUNCTION getAttribute(
                             ctx  IN OUT RAW,
                             name IN VARCHAR2) RETURN VARCHAR2,
MEMBER PROCEDURE getAllAttributes(
                                  ctx        IN OUT RAW,
                                  attributes IN OUT NOCOPY CLOB),
-- Methods associated with audio processing
MEMBER FUNCTION processAudioCommand(
                                    ctx       IN OUT RAW,
                                    cmd       IN VARCHAR2,
                                    result    OUT RAW)
                RETURN RAW
where:
6.2 Constructors
This section describes the constructor functions.
The interMedia constructor functions are as follows:
init( )
Format
init( ) RETURN ORDAudio;
Description
Allows for easy initialization of instances of the ORDAudio object type.
Parameters
None.
Pragmas
None.
Exceptions
None.
Usage Notes
This static method initializes all the ORDAudio attributes to NULL with the following exceptions:
You should begin using the init( ) method as soon as possible to allow you to more easily initialize the ORDAudio object type, especially if the ORDAudio type evolves and attributes are added in a future release. INSERT statements left unchanged using the default constructor (which initializes each object attribute), will fail under these circumstances.
Examples
Initialize the ORDAudio object attributes:
BEGIN
INSERT INTO taud VALUES (ORDSYS.ORDAudio.init());
END;
init(srcType,srcLocation,srcName)
Format
RETURN ORDAudio;
Description
Parameters
srcType
The source type of the audio data.
srcLocation
The source location of the audio data.
srcName
The source name of the audio data.
Pragmas
None.
Exceptions
None.
Usage Notes
Examples
BEGIN
INSERT INTO taud VALUES (ORDSYS.ORDAudio.init('file','AUDDIR','audio1.au'));
END;
6.3 Methods
This section presents reference information on the Oracle interMedia methods used for audio data manipulation. These methods are described in the following groupings:
ORDAudio Methods Associated with the updateTime Attribute
ORDAudio Methods Associated with the description Attribute
ORDAudio Methods Associated with mimeType Attribute
ORDAudio Methods Associated with the source Attribute
ORDAudio Methods Associated with File Operations
ORDAudio Methods Associated with Audio Attributes Accessors
ORDAudio Methods Associated with Processing Audio Data
For more information on object types and methods, see Oracle9i Database Concepts.
6.3.1 Example Table Definitions
The methods described in this reference chapter show examples based on a test audio table TAUD. Refer to the TAUD table definition that follows when reading through the examples:
TAUD Table Definition
CREATE TABLE TAUD(n NUMBER, aud ORDSYS.ORDAUDIO)
storage (initial 100K next 100K pctincrease 0);
INSERT INTO TAUD VALUES(1, ORDSYS.ORDAudio.init());
INSERT INTO TAUD VALUES(2, ORDSYS.ORDAudio.init());
checkProperties( )
Format
checkProperties(ctx IN OUT RAW) RETURN BOOLEAN;
Description
Checks the properties of the stored audio data, including the following audio attributes: sample size, sample rate, number of channels, format, and encoding type.
Parameters
ctx
The format plug-in context information.
Usage Notes
If the format is set to NULL, then the checkProperties( ) method uses the default format plug-in; otherwise, it uses the plug-in specified by the format.
The checkProperties( ) method does not check the MIME type because a file can have multiple correct MIME types and this is not well defined.
Pragmas
None.
Exceptions
AUDIO_PLUGIN_EXCEPTION
This exception is raised if you call the checkProperties( ) method and the audio plug-in raises an exception.
Examples
Check property information for known audio attributes:
DECLARE
  obj ORDSYS.ORDAudio;
  ctx RAW(4000) :=NULL;
BEGIN
  select aud into obj from TAUD where N =1 for update;
  if( obj.checkProperties(ctx) =  TRUE ) then
  DBMS_OUTPUT.put_line('true');
  else
  DBMS_OUTPUT.put_line('false');
  end if;
  EXCEPTION
   WHEN ORDSYS.ORDAudioExceptions.AUDIO_PLUGIN_EXCEPTION THEN
    DBMS_OUTPUT.put_line('ORDAudioExceptions.AUDIO_PLUGIN_EXCEPTION caught');
   WHEN OTHERS THEN
    DBMS_OUTPUT.put_line('EXCEPTION caught');
END;
getAllAttributes( )
Format
getAllAttributes(
ctx IN OUT RAW,
attributes IN OUT NOCOPY CLOB);
Description
Returns a formatted string for convenient client access. For natively supported formats, the string includes the following list of audio data attributes separated by a comma (,): fileFormat, mimeType, encoding, numberOfChannels, samplingRate, sampleSize, compressionType, and audioDuration. For user-defined formats, the string is defined by the format plug-in.
Parameters
ctx
attributes
The attributes.
Usage Notes
These audio data attributes are available from the header of the formatted audio data.
Pragmas
None.
Exceptions
This exception is raised if you call the getAllAttributes( ) method and the audio plug-in raises an exception.
Examples
Return all audio attributes for audio data stored in the database:
DECLARE
  tempLob   CLOB;
BEGIN
  SELECT aud INTO obj FROM TAUD  WHERE N=1;
  DBMS_OUTPUT.PUT_LINE('getting comma separated list of all attribs');
  DBMS_OUTPUT.PUT_LINE('-------------------------------------------');
  DBMS_LOB.CREATETEMPORARY(tempLob, FALSE, DBMS_LOB.CALL);
  obj.getAllAttributes(ctx,tempLob);
  DBMS_OUTPUT.put_line(DBMS_LOB.substr(tempLob, DBMS_LOB.getLength(tempLob) , 1));
  EXCEPTION
  DBMS_OUTPUT.PUT_LINE('ORDAudioExceptions.AUDIO_PLUGIN_EXCEPTION caught');
END;
getAttribute( )
Format
getAttribute(
ctx IN OUT RAW,
name IN VARCHAR2)
RETURN VARCHAR2;
Description
Returns the value of the requested attribute from audio data for user-defined formats only.
Parameters
ctx
name
The name of the attribute.
Usage Notes
The audio data attributes are available from the header of the formatted audio data.
Audio data attribute information can be extracted from the audio data itself. You can extend support to a format not understood by the ORDAudio object by implementing an ORDPLUGINS.ORDX_<format>_AUDIO package that supports that format. See Section 3.4.13 for more information.
Pragmas
None.
Exceptions
This exception is raised if you call the getAttribute( ) method and the audio plug-in raises an exception.
Examples
Return information for the specified audio attribute for audio data stored in the database:
DECLARE
  res VARCHAR2(4000);
BEGIN
  DBMS_OUTPUT.PUT_LINE('getting audio sample size');
  DBMS_OUTPUT.PUT_LINE('---------------------');
  res := obj.getAttribute(ctx,'sample_size');
  EXCEPTION
        WHEN ORDSYS.ORDSourceExceptions.METHOD_NOT_SUPPORTED THEN
         DBMS_OUTPUT.put_line('Source METHOD_NOT_SUPPORTED caught');
        WHEN ORDSYS.ORDSourceExceptions.SOURCE_PLUGIN_EXCEPTION THEN
         DBMS_OUTPUT.put_line('SOURCE PLUGIN EXCEPTION caught');
        WHEN ORDSYS.ORDAudioExceptions.METHOD_NOT_SUPPORTED THEN
         DBMS_OUTPUT.put_line('AUDIO METHOD_NOT_SUPPORTED EXCEPTION caught');
         DBMS_OUTPUT.put_line('AUDIO PLUGIN EXCEPTION caught');
        WHEN OTHERS THEN
         DBMS_OUTPUT.PUT_LINE('EXCEPTION caught');
END;
getAudioDuration( )
Format
getAudioDuration( ) RETURN INTEGER;
Description
Returns the value of the audioDuration attribute of the audio object.
Parameters
None.
Usage Notes
None.
Pragmas
WNPS, RNDS, RNPS)
Exceptions
None.
Examples
See the example in setProperties( ).
getContentLength( )
Format
getContentLength(ctx IN OUT RAW) RETURN INTEGER;
Description
Returns the length of the audio data content stored in the source.
Parameters
ctx
The source plug-in context information.
Usage Notes
This method is not supported for all source types. For example, HTTP type sources do not support this method. If you want to implement this call for HTTP type sources, you must define your own modified HTTP source type and implement this method on it.
Pragmas
WNPS, RNDS, RNPS)
Exceptions
ORDSourceExceptions.INCOMPLETE_SOURCE_INFORMATION
This exception is raised if you call the getContentLength( ) method and the value of srcType is NULL and data is not stored locally in the BLOB.
This exception is raised if you call the getContentLength( ) method within a source plug-in when any other exception is raised.
See Appendix H for more information about these exceptions.
Examples
See the example in import( ).
Format
getCompressionType( ) RETURN VARCHAR2;
Description
Returns the value of the compressionType attribute of the audio object.
Parameters
None.
Usage Notes
None.
Pragmas
WNPS, RNDS, RNPS)
Exceptions
None.
Examples
getContentInLob( )
Format
getContentInLob(
ctx IN OUT RAW,
format OUT VARCHAR2);
Description
Copies data from a data source into the specified BLOB. The BLOB must not be the BLOB in source.localData.
Parameters
ctx
dest_lob
The LOB in which to receive data.
mimeType
The MIME type of the data; this may or may not be returned.
format
The format of the data; this may or may not be returned.
Usage Notes
None.
Pragmas
None.
Exceptions
This exception is raised if you call the getContentInLob( ) method and the value of srcType is NULL.
This exception is raised if you call the getContentInLob( ) method and this method is not supported by the source plug-in being used.
This exception is raised if you call the getContentInLob( ) method within a source plug-in when any other exception is raised.
Examples
Get data from a data source and put it into the specified BLOB:
DECLARE
 tempBLob BLOB;
 mimeType VARCHAR2(4000);
 format VARCHAR2(4000);
BEGIN
 SELECT aud INTO obj FROM TAUD WHERE N = 1 ;
 if(obj.isLocal) then
   DBMS_OUTPUT.put_line('local is true');
 end if;
 DBMS_LOB.CREATETEMPORARY(tempBLob, true, 10);
 obj.getContentInLob(ctx,tempBLob, mimeType,format);
 DBMS_OUTPUT.PUT_LINE(TO_CHAR(DBMS_LOB.getLength(tempBLob)));
 EXCEPTION
   DBMS_OUTPUT.put_line('ORDSourceExceptions.METHOD_NOT_SUPPORTED caught');
  WHEN OTHERS THEN
END;
getDescription( )
Format
getDescription( ) RETURN VARCHAR2;
Description
Returns the description of the audio data.
Parameters
None.
Usage Notes
None.
Pragmas
Exceptions
DESCRIPTION_IS_NOT_SET
This exception is raised if you call the getDescription( ) method and the description is not set.
Examples
See the example in setDescription( ).
getEncoding( )
Format
getEncoding( ) RETURN VARCHAR2;
Description
Returns the value of the encoding attribute of the audio object.
Parameters
None.
Usage Notes
None.
Pragmas
Exceptions
None.
Examples
getFormat( )
Format
getFormat( ) RETURN VARCHAR2;
Description
Returns the value of the format attribute of the audio object.
Parameters
None.
Usage Notes
None.
Pragmas
Exceptions
AUDIO_FORMAT_IS_NULL
This exception is raised if you call the getFormat( ) method and the value for format is NULL.
Examples
Format
getNumberOfChannels( ) RETURN INTEGER;
Description
Returns the value of the numberOfChannels attribute of the audio object.
Parameters
None.
Usage Notes
None.
Pragmas
WNPS, RNDS, RNPS)
Exceptions
None.
Examples
getSampleSize( )
Format
getSampleSize( ) RETURN INTEGER;
Description
Returns the value of the sampleSize attribute of the audio object.
Parameters
None.
Usage Notes
None.
Pragmas
Exceptions
None.
Examples
getSamplingRate( )
Format
getSamplingRate( ) IN INTEGER;
Description
Returns the value of the samplingRate attribute of the audio object. The unit is Hz.
Parameters
None.
Usage Notes
None.
Pragmas
WNPS, RNDS, RNPS)
Exceptions
None.
Examples
import( )
Format
import(ctx IN OUT RAW);
Description
Transfers audio data from an external audio data source to a local source (localData) within an Oracle database.
Parameters
ctx
The source plug-in context information.This must be allocated. You must call the openSource( ) method; see the introduction to this chapter for more information.
Usage Notes
Use the setSource( ) method to set the external source type, location, and name prior to calling the import( ) method.
You must ensure that the directory exists or is created before you use this method for srcType 'file'.
After importing data from an external audio data source to a local source (within an Oracle database), the source information remains unchanged (that is, pointing to the source from where the data was imported).
Invoking this method implicitly calls the setUpdateTime( ) and setLocal methods.
Pragmas
None.
Exceptions
This exception is raised if you call the import( ) method and the value of srcType is NULL.
ORDSourceExceptions.NULL_SOURCE
This exception is raised if you call the import( ) method and the value of dlob is NULL.
ORDSourceExceptionsMETHOD_NOT_SUPPORTED
This exception is raised if you call the import( ) method and the import( ) method is not supported by the source plug-in being used.
This exception is raised if you call the import( ) method within a source plug-in when any other exception is raised.
Examples
Import audio data from an external audio data source into the local source:
DECLARE
BEGIN
  SELECT aud INTO obj FROM TAUD  WHERE N=1 FOR UPDATE;
  DBMS_OUTPUT.PUT_LINE('setting and getting source');
  DBMS_OUTPUT.PUT_LINE('--------------------------');
  -- set source to a file
  obj.setSource('file','AUDIODIR','testaud.dat');
  -- get source information
  DBMS_OUTPUT.PUT_LINE(obj.getSource());
  -- import data
  obj.import(ctx);
  -- check size
  DBMS_OUTPUT.PUT_LINE(TO_CHAR(obj.getContentLength(ctx)));
  DBMS_OUTPUT.PUT_LINE('deleting contents');
  DBMS_OUTPUT.PUT_LINE('-----------------');
  obj.deleteContent();
  UPDATE TAUD SET aud=obj WHERE N=1;
  COMMIT;
END;
importFrom( )
Format
importFrom(ctx IN OUT RAW,
source_name IN VARCHAR2);
Description
Transfers audio data from the specified external audio data source to a local source (localData) within an Oracle database.
Parameters
ctx
The source plug-in context information. This must be allocated. You must call the openSource( ) method; see the introduction to this chapter for more information.
source_type
source_location
The location from where the audio data is to be imported.
source_name
The name of the audio data.
Usage Notes
This method is similar to the import( ) method except the source information is specified as parameters to the method instead of separately.
After importing data from an external audio data source to a local source (within an Oracle database), the source information (that is, pointing to the source from where the data was imported) is set to the input values.
Pragmas
None.
Exceptions
This exception is raised if you call the importFrom( ) method and the value of dlob is NULL.
This exception is raised if you call the importFrom( ) method and this method is not supported by the source plug-in being used.
This exception is raised if you call the importFrom( ) method within a source plug-in when any other exception is raised.
Examples
Import audio data from the specified external data source into the local source:
DECLARE
BEGIN
  -- import data
  obj.importFrom(ctx,'file','AUDIODIR','testaud.dat');
  -- check size
  DBMS_OUTPUT.PUT_LINE(TO_CHAR(DBMS_LOB.GETLENGTH(obj.getContent())));
  COMMIT;
  EXCEPTION
        DBMS_OUTPUT.PUT_LINE('Source not specified');
END;
processAudioCommand( )
Format
ctx IN OUT RAW,
cmd IN VARCHAR2,
result OUT RAW)
RETURN RAW;
Description
Allows you to send a command and related arguments to the format plug-in for processing.
This method is supported only for user-defined format plug-ins.
Parameters
ctx
cmd
Any command recognized by the format plug-in.
arguments
The arguments of the command.
result
The result of calling this function returned by the format plug-in.
Usage Notes
Use this method to send any audio commands and their respective arguments to the format plug-in. Commands are not interpreted; they are taken and passed through to a format plug-in to be processed.
If the format is set to NULL, then the processAudioCommand( ) method uses the default format plug-in; otherwise, it uses your user-defined format plug-in.
You can extend support to a format that is not understood by the ORDAudio object by preparing an ORDPLUGINS.ORDX_<format>_AUDIO package that supports that format. See Section 3.4.13 for more information.
Pragmas
None.
Exceptions
This exception is raised if you call the processAudioCommand( ) method and the audio plug-in raises an exception.
Examples
Process a set of commands:
DECLARE
  res RAW(4000);
  result RAW(4000);
  command VARCHAR(4000);
  argList VARCHAR(4000);
BEGIN
  select aud into obj from TAUD where N =1 for UPDATE;
  -- assign command
  -- assign argList
  res := obj.processAudioCommand (ctx, command, argList, result);
  UPDATE TAUD SET aud=obj WHERE N=1 ;
  COMMIT;
  EXCEPTION
        WHEN OTHERS THEN
END;
setAudioDuration( )
Format
setAudioDuration(knownAudioDuration IN INTEGER);
Description
Sets the value of the audioDuration attribute of the audio object.
Parameters
knownAudioDuration
A known audio duration.
Usage Notes
Calling this method implicitly calls the setUpdateTime( ) method.
Pragmas
None.
Exceptions
NULL_INPUT_VALUE
This exception is raised if you call the setAudioDuration( ) method and the value for the knownAudioDuration parameter is NULL.
Examples
setCompressionType( )
Format
setCompressionType(knownCompressionType IN VARCHAR2);
Description
Sets the value of the compressionType attribute of the audio object.
Parameters
A known compression type.
Usage Notes
The value of the compressionType always matches that of the encoding value because in many audio formats, encoding and compression type are tightly integrated. See Appendix A for more information.
Pragmas
None.
Exceptions
NULL_INPUT_VALUE
This exception is raised if you call the setCompressionType( ) method and the value for the knownCompressionType parameter is NULL.
Examples
setDescription( )
Format
setDescription (user_description IN VARCHAR2);
Description
Sets the description of the audio data.
Parameters
user_description
The description of the audio data.
Usage Notes
Each audio object may need a description to help some client applications. For example, a Web-based client can show a list of audio descriptions from which a user can select one to access the audio data.
Web-access components and other client components provided with Oracle interMedia make use of this description attribute to present audio data to users.
Pragmas
None.
Exceptions
None.
Examples
Set the description attribute for some audio data:
DECLARE
BEGIN
  DBMS_OUTPUT.PUT_LINE('writing title');
  DBMS_OUTPUT.PUT_LINE('-------------');
  obj.setDescription('audio1.wav');
  DBMS_OUTPUT.PUT_LINE(obj.getDescription());
  COMMIT;
END;
setEncoding( )
Format
setEncoding(knownEncoding IN VARCHAR2);
Description
Sets the value of the encoding attribute of the audio object.
Parameters
knownEncoding
A known encoding type.
Usage Notes
The value of encoding always matches that of the compressionType value because in many audio formats, encoding and compression type are tightly integrated. See Appendix A for more information.
Pragmas
None.
Exceptions
NULL_INPUT_VALUE
This exception is raised if you call the setEncoding( ) method and the value for the knownEncoding parameter is NULL.
Examples
setFormat( )
Format
setFormat(knownFormat IN VARCHAR2);
Description
Sets the format attribute of the audio object.
Parameters
knownFormat
The known format of the audio data to be set in the audio object.
Usage Notes
Pragmas
None.
Exceptions
NULL_INPUT_VALUE
This exception is raised if you call the setFormat( ) method and the value for the knownFormat parameter is NULL.
Examples
Set the format for some audio data:
DECLARE
BEGIN
  obj.setFormat('AUFF');
  obj.setEncoding('MULAW');
  obj.setNumberOfChannels(1);
  obj.setSamplingRate(8);
  obj.setSampleSize(8);
  obj.setCompressionType('8BITMONOAUDIO');
  obj.setAudioDuration(16);
  DBMS_OUTPUT.put_line('format: ' || obj.getformat);
  DBMS_OUTPUT.put_line('encoding: ' || obj.getEncoding);
  DBMS_OUTPUT.put_line('numberOfChannels: ' || TO_CHAR(obj.getNumberOfChannels));
  DBMS_OUTPUT.put_line('samplingRate: ' || TO_CHAR(obj.getSamplingRate));
  DBMS_OUTPUT.put_line('sampleSize: ' || TO_CHAR(obj.getSampleSize));
  DBMS_OUTPUT.put_line('compressionType : ' || obj.getCompressionType);
  DBMS_OUTPUT.put_line('audioDuration: ' || TO_CHAR(obj.getAudioDuration));
  COMMIT;
  EXCEPTION
   WHEN ORDSYS.ORDAudioExceptions.NULL_INPUT_VALUE THEN
    DBMS_OUTPUT.put_line('ORDAudioExceptions.NULL_INPUT_VALUE caught');
   WHEN OTHERS THEN
END;
setKnownAttributes( )
Format
setKnownAttributes(
knownSamleSize IN INTEGER,
Description
Sets the known audio attributes for the audio object.
Parameters
knownFormat
The known format.
knownEncoding
The known encoding type.
The known number of channels.
knownSamplingRate
The known sampling rate.
knownSampleSize
The known sample size.
The known compression type.
knownAudioDuration
The known audio duration.
Usage Notes
Pragmas
None.
Exceptions
None.
Examples
Set the known attributes for the audio data.
DECLARE
BEGIN
  obj.setKnownAttributes('AUFF','MULAW', 1, 8, 8, '8BITMONOAUDIO',16);
  DBMS_OUTPUT.put_line('format: ' || obj.getformat());
  DBMS_OUTPUT.put_line('encoding: ' || obj.getEncoding());
  DBMS_OUTPUT.put_line('numberOfChannels: ' || TO_CHAR(obj.getNumberOfChannels()));
  DBMS_OUTPUT.put_line('samplingRate: ' || TO_CHAR(obj.getSamplingRate()));
  DBMS_OUTPUT.put_line('sampleSize: ' || TO_CHAR(obj.getSampleSize()));
  DBMS_OUTPUT.put_line('compressionType : ' || obj.getCompressionType());
  DBMS_OUTPUT.put_line('audioDuration: ' || TO_CHAR(obj.getAudioDuration()));
  COMMIT;
  EXCEPTION
    DBMS_OUTPUT.put_line('ORDAudioExceptions.METHOD_NOT_SUPPORTED caught');
   WHEN OTHERS THEN
END;
setNumberOfChannels( )
Format
setNumberOfChannels(knownNumberOfChannels IN INTEGER);
Description
Sets the value of the numberOfChannels attribute for the audio object.
Parameters
A known number of channels.
Usage Notes
Pragmas
None.
Exceptions
NULL_INPUT_VALUE
This exception is raised if you call the setNumberOfChannels( ) method and the value for the knownNumberOfChannels parameter is NULL.
Examples
setProperties( )
Format
setComments IN BOOLEAN);
Description
Reads the audio data to get the values of the object attributes and then stores them in the object attributes. This method sets the properties for the following attributes of the audio data: format, encoding type, number of channels, sampling rate, and sample size. It populates the comments field of the object with a rich set of format and application properties in XML form if the value of the setComments parameter is TRUE.
Parameters
ctx
setComments
If the value is TRUE, then the comments field of the object is populated with a rich set of format and application properties of the audio object in XML form, identical to what is provided by the interMedia Annotator utility; otherwise, if the value is FALSE, the comments field of the object remains unpopulated. The default value is FALSE.
Usage Notes
If the property cannot be extracted from the media source, then the respective attribute is set to NULL.
If the format is set to NULL, then the setProperties( ) method uses the default format plug-in; otherwise, it uses the plug-in specified by the format.
Pragmas
None.
Exceptions
This exception is raised if you call the setProperties( ) method and the audio plug-in raises an exception.
Examples
Set the property information for known audio attributes:
DECLARE
BEGIN
  obj.setProperties(ctx,FALSE);
  --DBMS_OUTPUT.put_line('format: ' || obj.getformat());
  update  TAUD set aud = obj where  N =1 ;
  COMMIT;
  EXCEPTION
   WHEN OTHERS THEN
END;
setSamplingRate( )
Format
setSamplingRate(knownSamplingRate IN INTEGER);
Description
Sets the value of the samplingRate attribute of the audio object. The unit is Hz.
Parameters
knownSamplingRate
A known sampling rate.
Usage Notes
Pragmas
None.
Exceptions
NULL_INPUT_VALUE
This exception is raised if you call the setSamplingRate( ) method and the value for the knownSamplingRate parameter is NULL.
Examples
setSampleSize( )
Format
setSampleSize(knownSampleSize IN INTEGER);
Description
Sets the value of the sampleSize attribute of the audio object.
Parameters
knownSampleSize
A known sample size.
Usage Notes
Pragmas
None.
Exceptions
NULL_INPUT_VALUE
This exception is raised if you call the setSampleSize( ) method and the value for the knownSampleSize parameter is NULL.
Examples
6.4 Packages or PL/SQL Plug-ins
This section presents reference information on the packages or PL/SQL plug-ins provided. Table 6-1 describes the PL/SQL plug-in packages provided in the ORDPLUGINS schema.
Table 6-1 PL/SQL Plug-ins Provided in the ORDPLUGINS Schema
PL/SQL Plug-in Packages  Audio Format  MIME Type
ORDPLUGINS.ORDX_DEFAULT_AUDIO
<format>
Dependent on file format
ORDPLUGINS.ORDX_AUFF_AUDIO
AUFF
audio/basic
ORDPLUGINS.ORDX_AIFF_AUDIO
AIFF
audio/x-aiff
ORDPLUGINS.ORDX_AIFC_AUDIO
AIFC
audio/x-aiff
ORDPLUGINS.ORDX_WAVE_AUDIO
WAVE
audio/x-wave
ORDPLUGINS.ORDX_MPGA_AUDIO
MPGA
audio/mpeg
Section 6.4.1 describes the ORDPLUGINS.ORDX_DEFAULT_AUDIO package, the methods supported, and the level of support. Note that the methods supported and the level of support for the other PL/SQL plug-in packages described in Table 6-1 are identical for all plug-in packages, therefore, refer to Section 6.4.1.
6.4.1 ORDPLUGINS.ORDX_DEFAULT_AUDIO Package
Use the following provided ORDPLUGINS.ORDX_DEFAULT_AUDIO package as a guide in developing your own ORDPLUGINS.ORDX_<format>_AUDIO audio format package. This package sets the mimeType field in the setProperties( ) method with a MIME type value that is dependent on the file format.
CREATE OR REPLACE PACKAGE ORDX_DEFAULT_AUDIO
authid current_user
AS
--AUDIO ATTRIBUTES ACCESSORS
--Deprecated Functions Deprecated in Release 8.1.6 Begin Here
FUNCTION getFormat(ctx IN OUT RAW, obj IN ORDSYS.ORDAudio)
                RETURN VARCHAR2;
FUNCTION getEncoding(ctx IN OUT RAW, obj IN ORDSYS.ORDAudio)
                RETURN VARCHAR2;
FUNCTION getNumberOfChannels(ctx IN OUT RAW, obj IN ORDSYS.ORDAudio)
                RETURN INTEGER;
FUNCTION getSamplingRate(ctx IN OUT RAW, obj IN ORDSYS.ORDAudio)
                RETURN INTEGER;
FUNCTION getSampleSize(ctx IN OUT RAW, obj IN ORDSYS.ORDAudio)
                RETURN INTEGER;
FUNCTION getCompressionType(ctx IN OUT RAW, obj IN ORDSYS.ORDAudio)
                RETURN VARCHAR2;
FUNCTION getAudioDuration(ctx IN OUT RAW, obj IN ORDSYS.ORDAudio)
                RETURN INTEGER;
--Deprecated Functions Deprecated in Release 8.1.6 End Here
                        obj IN OUT NOCOPY ORDSYS.ORDAudio,
                        setComments IN NUMBER := 0);
FUNCTION checkProperties(ctx IN OUT RAW, obj IN OUT ORDSYS.ORDAudio)
                RETURN NUMBER;
FUNCTION getAttribute(ctx IN OUT RAW,
                      obj IN ORDSYS.ORDAudio,
                      name IN VARCHAR2) RETURN VARCHAR2;
PROCEDURE getAllAttributes(ctx IN OUT RAW,
--AUDIO PROCESSING METHODS
FUNCTION processCommand(ctx       IN OUT RAW,
                        cmd       IN VARCHAR2,
                        arguments IN VARHAR2,
                        result    OUT RAW)
         RETURN RAW;
PRAGMA RESTRICT_REFERENCES(getFormat, WNDS, WNPS, RNDS, RNPS);
PRAGMA RESTRICT_REFERENCES(getEncoding, WNDS, WNPS, RNDS, RNPS);
PRAGMA RESTRICT_REFERENCES(getNumberOfChennels, WNDS, WNPS, RNDS, RNPS);
PRAGMA RESTRICT_REFERENCES(getSamplingRate, WNDS, WNPS, RNDS, RNPS);
PRAGMA RESTRICT_REFERENCES(getSampleSize, WNDS, WNPS, RNDS, RNPS);
PRAGMA RESTRICT_REFERENCES(getCompressionType, WNDS, WNPS, RNDS, RNPS);
PRAGMA RESTRICT_REFERENCES(getAttribute, WNDS, WNPS, RNDS, RNPS);
PRAGMA RESTRICT_REFERENCES(getAudioDuration, WNDS, WNPS, RNDS, RNPS);
END;
Table 6-2 shows the methods supported in the
ORDPLUGINS.ORDX_DEFAULT_AUDIO package and the exceptions raised if you call a method that is not supported.
Table 6-2 Methods Supported in the ORDPLUGINS.ORDX_DEFAULT_AUDIO Package
Name of Method  Level of Support
getFormat
Supported; if the source is local, get the attribute and return the file format, but if the source is NULL, raise an
ORDSYS.ORDSourceExceptions.EMPTY_SOURCE exception;
otherwise, if the source is external, raise an
ORDSYS.ORDAudioExceptions.LOCAL_DATA_SOURCE_REQUIRED exception.
getEncoding
Supported; if the source is local, get the attribute and return the encoding, but if the source is NULL, raise an
getNumberOfChannels
Supported; if the source is local, get the attribute and return the number of channels, but if the source is NULL, raise an
getSamplingRate
Supported; if the source is local, get the attribute and return the sampling rate, but if the source is NULL, raise an
getSampleSize
Supported; if the source is local, get the attribute and return the sample size, but if the source is NULL, raise an
getCompressionType
Supported; if the source is local, get the attribute and return the compression type, but if the source is NULL, raise an
getAudioDuration
Supported; if the source is local, get the attribute and return the audio duration, but if the source is NULL, raise an
setProperties
Supported; if the source is local, process the local data and set the properties, but if the source is NULL, raise an
ORDSYS.ORDSourceExceptions.EMPTY_SOURCE exception; if the source is a BFILE, then process the BFILE and set the properties; if the source is neither local nor a BFILE, get the media content into a temporary LOB, process the data, and set the properties.
checkProperties
Supported; if the source is local, process the local data and check the properties, but if the source is NULL, raise an
ORDSYS.ORDSourceExceptions.EMPTY_SOURCE exception; if the source is a BFILE, then process the BFILE and check the properties; if the source is neither local nor a BFILE, get the media content into a temporary LOB, process the data, and check the properties.
getAttribute
Not supported - raises exceptions: METHOD_NOT_SUPPORTED and AUDIO_PLUGIN_EXCEPTION.
getAllAttributes
Supported; if the source is local, get the attributes and return them, but if the source is NULL, raise an ORDSYS.ORDSourceExceptions.EMPTY_SOURCE exception; otherwise, if the source is external, raise an
processCommand
6.4.2 Extending interMedia to Support a New Audio Data Format
Extending interMedia to support a new audio data format consists of four steps:
  1. Design your new audio data format.
  2. Implement your new audio data format and name it, for example, ORDX_MY_AUDIO.SQL.
  3. Install your new ORDX_MY_AUDIO.SQL plug-in in the ORDPLUGINS schema.
  4. Grant EXECUTE privileges on your new plug-in, for example, ORDX_MY_AUDIO.SQL plug-in, to PUBLIC.
Section 3.1.12 briefly describes how to extend interMedia to support a new audio data format and describes the interface. A package body listing is provided in Example 6-1 to assist you in this operation. Add your variables to the places that say "--Your variables go here" and add your code to the places that say "--Your code goes here".
See Section F.1 for more information on installing your own audio format plug-in and running the sample scripts provided.
Example 6-1 Show the Package Body for Extending Support to a New Audio
Data Format
CREATE OR REPLACE PACKAGE BODY ORDX_MY_AUDIO
AS
  RETURN VARCHAR2
  IS
  BEGIN
  END;
  RETURN VARCHAR2
  IS
  BEGIN
  END;
  RETURN INTEGER
  IS
  BEGIN
  END;
  RETURN INTEGER
  IS
  BEGIN
  END;
  RETURN INTEGER
  IS
  BEGIN
  END;
  RETURN VARCHAR2
  IS
  BEGIN
  END;
  RETURN INTEGER
  IS
  BEGIN
  END;
                          setComments IN NUMBER :=0)
  IS
  BEGIN
  END;
  RETURN NUMBER
  IS
  BEGIN
  END;
                         name IN VARCHAR2)
  RETURN VARCHAR2
  IS
  BEGIN
  END;
  IS
  BEGIN
  END;
  -- AUDIO PROCESSING METHODS
                                 ctx       IN OUT RAW,
                                 cmd       IN VARCHAR2,
                                 result    OUT RAW)
  RETURN RAW
  IS
  BEGIN
  END;
END;
show errors;
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Library
Go To Product List
Product
Contents
Go To Index
Index
