Oracle interMedia User's Guide and Reference
Release 9.0.1
Part Number A88786-01
Go To Documentation Library
Library
Go To Product List
Product
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
J
Deprecated Methods
J.1 Deprecated Audio and Video Methods
The following ORDAudio and ORDVideo get methods that accept a ctx parameter were deprecated in release 8.1.6:
ORDAudio
    getFormat(ctx IN OUT RAW) RETURN VARCHAR2
    getEncoding(ctx IN OUT RAW) RETURN VARCHAR2
    getNumberOfChannels(ctx IN OUT RAW) RETURN INTEGER
    getSamplingRate(ctx IN OUT RAW) RETURN INTEGER
    getSampleSize(ctx IN OUT RAW) RETURN INTEGER
    getCompressionType(ctx IN OUT RAW) RETURN VARCHAR2
    getAudioDuration(ctx IN OUT RAW) RETURN INTEGER
ORDVideo
    getFrameSize(SELF IN OUT NOCOPY ORDVideo,
                                ctx IN OUT RAW,
                                retWidth OUT INTEGER,
                                retHeight OUT INTEGER)
    getFrameResolution(ctx IN OUT RAW) RETURN INTEGER
    getFrameRate(ctx IN OUT RAW) RETURN INTEGER
    getVideoDuration(ctx IN OUT RAW) RETURN INTEGER
    getNumberOfFrames(ctx IN OUT RAW) RETURN INTEGER
    getNumberOfColors(ctx IN OUT RAW) RETURN INTEGER
    getBitRate(ctx IN OUT RAW) RETURN INTEGER
The following ORDAudio and ORDVideo comments methods were deprecated in release 9.0.1:
ORDAudio
-- Methods associated with the comments attribute
MEMBER PROCEDURE appendToComments(amount IN BINARY_INTEGER,
                                  buffer IN VARCHAR2),
MEMBER PROCEDURE writeToComments(offset IN INTEGER,
MEMBER FUNCTION readFromComments(offset IN INTEGER,
                                 amount IN BINARY_INTEGER := 32767)
                RETURN VARCHAR2,
PRAGMA RESTRICT_REFERENCES(readFromComments, WNDS, WNPS, RNDS, RNPS),
MEMBER FUNCTION locateInComments(pattern    IN VARCHAR2,
                                 offset     IN INTEGER := 1,
                                 occurrence IN INTEGER := 1)
                 RETURN INTEGER,
MEMBER PROCEDURE trimComments(newlen IN INTEGER),
MEMBER PROCEDURE eraseFromComments(amount IN OUT NOCOPY INTEGER,
                                   offset IN INTEGER := 1),
MEMBER PROCEDURE deleteComments,
MEMBER PROCEDURE loadCommentsFromFile(fileobj  IN BFILE,
                                      amount   IN INTEGER,
                                      from_loc IN INTEGER := 1,
                                      to_loc   IN INTEGER := 1),
MEMBER PROCEDURE copyCommentsOut(dest     IN OUT NOCOPY CLOB,
                                 amount   IN INTEGER,
MEMBER FUNCTION compareComments(
                   compare_with_lob        IN CLOB,
                   amount                  IN INTEGER := 4294967295,
                   starting_pos_in_comment IN INTEGER := 1,
                   starting_pos_in_compare IN INTEGER := 1)
                RETURN INTEGER,
PRAGMA RESTRICT_REFERENCES(compareComments, WNDS, WNPS, RNDS, RNPS),
MEMBER FUNCTION getCommentLength RETURN INTEGER,
PRAGMA RESTRICT_REFERENCES(getCommentLength, WNDS, WNPS, RNDS, RNPS),
ORDVideo
                RETURN VARCHAR2,
                 RETURN INTEGER,
                                      amount   IN INTEGER,
                                      from_loc IN INTEGER :=1,
                                      to_loc   IN INTEGER :=1),
                                 amount   IN INTEGER,
                RETURN INTEGER,
The following ORDAudio and ORDVideo accessor methods were deprecated in release 9.0.1:
ORDAudio
MEMBER PROCEDURE setProperties(ctx IN OUT RAW),
ORDVideo
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Library
Go To Product List
Product
Contents
Go To Index
Index
