Oracle interMedia User's Guide and Reference
Release 9.0.1
Part Number A88786-01
Go To Documentation Library
Library
Go To Product List
Product
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
4
Ensuring Future Compatibility with Evolving interMedia Object Types
The interMedia object types may evolve by adding new object attributes in a future release. Client-side applications that want to maintain compatibility with the current release of the interMedia object types (ORDAudio, ORDImage, ORDVideo, and ORDSource), even after a server upgrade that includes evolved object types, are advised to do the following:
4.1 When and How to Call the Compatibility Initialization Function
Only client-side applications that statically recognize the structure of the interMedia object types need to make a call to the compatibility initialization function. Server-side stored procedures will automatically use the newly installed (potentially changed) interMedia object types after an upgrade, so you do not need to call the compatibility initialization function from server-side stored procedures.
Client-side applications that do not statically (at compile time) recognize the structure of interMedia object types do not need to call the compatibility initialization function. OCI applications that determine the structure of the interMedia object types at runtime, through the OCIDescribeAny call, do not need to call the compatibility initialization function.
Client-side applications written in OCI that have been compiled with the C structure of interMedia object types (generated by OTT) should make a call to the server-side PL/SQL function, ORDSYS.IM.compatibilityInit( ), at the beginning of the application. See the compatibilityInit( ) method description of this function in this section.
Client-side applications written in Java using the interMedia Java Classes for release 8.1.7 or higher, should call the OrdMediaUtil.imCompatibilityInit( ) function after connecting to the Oracle database server.
public static void imCompatibilityInit(OracleConnection con)
    throws Exception
This Java function takes OracleConnection as an argument. The included interMedia release 8.1.7 or higher Java API will ensure that your 8.1.7 or higher application will work (without upgrading) with a potential future release of interMedia with evolved object types.
There is not yet a way for client-side PL/SQL applications to maintain compatibility with the current release of the interMedia object types if the objects add new attributes in a future release.
See the compatibilityInit( ) method in this section, and Oracle interMedia Java Classes User's Guide and Reference for further information, and detailed descriptions and examples. This guide is on the Oracle Technology Network, http://otn.oracle.com/.
Format
compatibilityInit(release IN VARCHAR2,
errmsg OUT VARCHAR2)
RETURN NUMBER;
Description
Allows for compatibly evolving the interMedia object types in a future release.
Parameters
release
The release number. This string should be set to '9.0.1' to allow a 9.0.1 application to work (without upgrading) with a potential future release of the Oracle database and interMedia with evolved object types.
errmsg
String output parameter. If the function returns a status other than 0, this errmsg string contains the reason for the failure.
Pragmas
None.
Exceptions
None.
Usage Notes
You should begin using the compatibilityInit( ) method as soon as possible to ensure you will not have to upgrade the Oracle software on your client node, or recompile your client application in order to work with a future release of the Oracle database server if the interMedia object types change in a future release. See Section 4.1 to determine if you need to call this function.
The compatibility initialization function for interMedia is located in the ORDSYS.IM package.
Examples
Using OCI and setting the compatibilityInit( ) method release parameter to release 9.0.1 to allow a 9.0.1 application to work with a future release of the Oracle database and interMedia with changed object types; note, that this is not a standalone program in that it assumes that you have allocated handles beforehand:
void prepareExecuteStmt( OCIEnv *envHndl,
             OCIStmt **stmtHndl,
             OCIError *errorHndl,
             OCISvcCtx *serviceCtx,
             OCIBind *bindhp[] )
   text *statement = (text *)
      "begin :sts := ORDSYS.IM.compatibilityInit( :vers, :errText );
end;";
  sword sts = 0;
  text *vers = (text *)"9.0.1";
  text errText[512];
  sb2 nullInd;
  printf( " Preparing statement\n" );
  OCIHandleAlloc( envHndl, (void **) stmtHndl, OCI_HTYPE_STMT, 0, NULL
  OCIStmtPrepare( *stmtHndl, errorHndl, (text *)statement,
         (ub4)strlen( (char *)statement ), OCI_NTV_SYNTAX,
         OCI_DEFAULT );
  printf( " Executing statement\n" );
  OCIBindByPos( *stmtHndl, &bindhp[ 0 ], errorHndl, 1, (void *)&sts,
        sizeof( sts ), SQLT_INT, (void *)0, NULL, 0, 0,
        NULL, OCI_DEFAULT );
  OCIBindByPos( *stmtHndl, &bindhp[ 1 ], errorHndl, 2, vers,
        strlen((char *)vers) + 1, SQLT_STR, (void *)0, NULL,
        0, 0, NULL, OCI_DEFAULT );
  OCIBindByPos( *stmtHndl, &bindhp[ 2 ], errorHndl, 3, errText,
        sizeof( errText ), SQLT_STR, &nullInd, NULL, 0, 0,
        NULL, OCI_DEFAULT);
  OCIStmtExecute( serviceCtx, *stmtHndl, errorHndl, 1, 0,
        (OCISnapshot *)NULL, (OCISnapshot *)NULL, OCI_DEFAULT );
  printf( " Statement executed\n" );
  if (sts != 0)
    printf( "CompatibilityInit failed with Sts = %d\n", sts );
    printf( "%s\n", errText );
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Library
Go To Product List
Product
Contents
Go To Index
Index
