| Oracle interMedia User's Guide and Reference Release 9.0.1 Part Number A88786-01 |
The following tables describe the video file and compression formats supported by interMedia.
To use these tables, find the data format you are interested in, and then determine the supported formats. For example, Table C-1 shows that interMedia supports Apple QuickTime 3.0 MOOV file format and a variety of compression formats from Cinepak to Sorenson Video.
| Format | |
File Format: `MOOV' |
| Compression Format | |
Choose one of these compression formatsFoot 1: |
1
All codes are the FourCC (uppercased) directly obtained from the dataFormat field of the video sample description entry of 'stsd' Atom of the QuickTime file. The table lists only the ones known. |
| Format | |
File Format: `AVI' |
Choose one of these |
1
All codes are the FourCC (uppercased) directly obtained from the compression field of 'strf' Chunk of the AVI file. The table lists only the ones known. |
| Format |
File Format: `RMFF' |
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
