| Oracle interMedia User's Guide and Reference Release 9.0.1 Part Number A88786-01 |
Oracle interMedia contains the following information about the ORDVideo type:
The examples in this chapter assume that the test video table TVID has been created and filled with data. This table was created using the SQL statements described in Section 9.3.1.
Methods invoked at the ORDSource level that are handed off to the source plug-in for processing have ctx (RAW(4000)) as the first argument. Before calling any of these methods for the first time, the client must allocate the ctx structure, initialize it to NULL, and invoke the openSource( ) method. At this point, the source plug-in can initialize context for this client. When processing is complete, the client should invoke the closeSource( ) method.
Methods invoked from a source plug-in call have the first argument as ctx (RAW(4000)).
Methods invoked at the ORDVideo level that are handed off to the format plug-in for processing have ctx (RAW(4000)) as the first argument. Before calling any of these methods for the first time, the client must allocate the ctx structure and initialize it to NULL.
You should use any of the individual set methods to set the value of the attribute for an object for formats not natively supported; otherwise, for formats natively supported, use the setProperties( ) method to populate the attributes of the object.
Oracle interMedia describes the ORDVideo object type, which supports the storage and management of video data.
The ORDVideo object type supports the storage and management of video data. This object type is defined as follows:
CREATE OR REPLACE TYPE ORDVideo AS OBJECT ( -- ATTRIBUTES description VARCHAR2(4000), source ORDSource, format VARCHAR2(31), mimeType VARCHAR2(4000), comments CLOB, -- VIDEO RELATED ATTRIBUTES width INTEGER, height INTEGER, frameResolution INTEGER, frameRate INTEGER, videoDuration INTEGER, numberOfFrames INTEGER, compressionType VARCHAR2(4000), numberOfColors INTEGER, bitRate INTEGER, -- METHODS -- CONSTRUCTORS -- STATIC FUNCTION init( ) RETURN ORDVideo, STATIC FUNCTION init(srcType IN VARCHAR2, srcLocation IN VARCHAR2, srcName IN VARCHAR2) RETURN ORDVideo, -- Methods associated with the date attribute MEMBER FUNCTION getUpdateTime RETURN DATE, PRAGMA RESTRICT_REFERENCES(getUpdateTime, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE setUpdateTime(current_time DATE), -- Methods associated with the description attribute MEMBER PROCEDURE setDescription(user_description IN VARCHAR2), MEMBER FUNCTION getDescription RETURN VARCHAR2, PRAGMA RESTRICT_REFERENCES(getDescription, WNDS, WNPS, RNDS, RNPS), -- Methods associated with the mimeType attribute MEMBER PROCEDURE setMimeType(mime IN VARCHAR2), MEMBER FUNCTION getMimeType RETURN VARCHAR2, PRAGMA RESTRICT_REFERENCES(getMimeType, WNDS, WNPS, RNDS, RNPS), -- Methods associated with the source attribute MEMBER FUNCTION processSourceCommand( ctx IN OUT RAW, cmd IN VARCHAR2, arguments IN VARCHAR2, result OUT RAW) RETURN RAW, MEMBER FUNCTION isLocal RETURN BOOLEAN, PRAGMA RESTRICT_REFERENCES(isLocal, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE setLocal, MEMBER PROCEDURE clearLocal, MEMBER PROCEDURE setSource( source_type IN VARCHAR2, source_location IN VARCHAR2, source_name IN VARCHAR2), MEMBER FUNCTION getSource RETURN VARCHAR2, PRAGMA RESTRICT_REFERENCES(getSource, WNDS, WNPS, RNDS, RNPS), MEMBER FUNCTION getSourceType RETURN VARCHAR2, PRAGMA RESTRICT_REFERENCES(getSourceType, WNDS, WNPS, RNDS, RNPS), MEMBER FUNCTION getSourceLocation RETURN VARCHAR2, PRAGMA RESTRICT_REFERENCES(getSourceLocation, WNDS, WNPS, RNDS, RNPS), MEMBER FUNCTION getSourceName RETURN VARCHAR2, PRAGMA RESTRICT_REFERENCES(getSourceName, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE import(ctx IN OUT RAW), MEMBER PROCEDURE importFrom( ctx IN OUT RAW, source_type IN VARCHAR2, source_location IN VARCHAR2, source_name IN VARCHAR2), MEMBER PROCEDURE export( ctx IN OUT RAW, source_type IN VARCHAR2, source_location IN VARCHAR2, source_name IN VARCHAR2), MEMBER FUNCTION getContentLength(ctx IN OUT RAW) RETURN INTEGER, PRAGMA RESTRICT_REFERENCES(getContentLength, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE getContentInLob( ctx IN OUT RAW, dest_lob IN OUT NOCOPY BLOB, mimeType OUT VARCHAR2, format OUT VARCHAR2), MEMBER FUNCTION getContent RETURN BLOB, PRAGMA RESTRICT_REFERENCES(getContent, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE deleteContent, MEMBER FUNCTION getBFILE RETURN BFILE, PRAGMA RESTRICT_REFERENCES(getBFILE, WNDS, WNPS, RNDS, RNPS), -- Methods associated with file operations on the source MEMBER FUNCTION openSource(userArg IN RAW, ctx OUT RAW) RETURN INTEGER, MEMBER FUNCTION closeSource(ctx IN OUT RAW) RETURN INTEGER, MEMBER FUNCTION trimSource(ctx IN OUT RAW, newlen IN INTEGER) RETURN INTEGER, MEMBER PROCEDURE readFromSource( ctx IN OUT RAW, startPos IN INTEGER, numBytes IN OUT INTEGER, buffer OUT RAW), MEMBER PROCEDURE writeToSource( ctx IN OUT RAW, startPos IN INTEGER, numBytes IN OUT INTEGER, buffer IN RAW), -- Methods associated with the video attributes accessors MEMBER PROCEDURE setFormat(knownformat IN VARCHAR2), MEMBER FUNCTION getFormat RETURN VARCHAR2, PRAGMA RESTRICT_REFERENCES(getFormat, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE setFrameSize(knownWidth IN INTEGER, knownHeight IN INTEGER), MEMBER PROCEDURE getFrameSize(retWidth OUT INTEGER, retHeight OUT INTEGER), PRAGMA RESTRICT_REFERENCES(getFrameSize, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE setFrameResolution(knownFrameResolution IN INTEGER), MEMBER FUNCTION getFrameResolution RETURN INTEGER, PRAGMA RESTRICT_REFERENCES(getFrameResolution, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE setFrameRate(knownFrameRate IN INTEGER), MEMBER FUNCTION getFrameRate RETURN INTEGER, PRAGMA RESTRICT_REFERENCES(getFrameRate, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE setVideoDuration(knownVideoDuration IN INTEGER), MEMBER FUNCTION getVideoDuration RETURN INTEGER, PRAGMA RESTRICT_REFERENCES(getVideoDuration, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE setNumberOfFrames(knownNumberOfFrames IN INTEGER), MEMBER FUNCTION getNumberOfFrames RETURN INTEGER, PRAGMA RESTRICT_REFERENCES(getNumberOfFrames, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE setCompressionType(knownCompressionType IN VARCHAR2), MEMBER FUNCTION getCompressionType RETURN VARCHAR2, PRAGMA RESTRICT_REFERENCES(getCompressionType, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE setNumberOfColors(knownNumberOfColors IN INTEGER), MEMBER FUNCTION getNumberOfColors RETURN INTEGER, PRAGMA RESTRICT_REFERENCES(getNumberOfColors, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE setBitRate(knownBitRate IN INTEGER), MEMBER FUNCTION getBitRate RETURN INTEGER, PRAGMA RESTRICT_REFERENCES(getBitRate, WNDS, WNPS, RNDS, RNPS), MEMBER PROCEDURE setKnownAttributes( knownFormat IN VARCHAR2, knownWidth IN INTEGER, knownHeight IN INTEGER, knownFrameResolution IN INTEGER, knownFrameRate IN INTEGER, knownVideoDuration IN INTEGER knownNumberOfFrames IN INTEGER, knownCompressionType IN VARCHAR2, knownNumberOfColors IN INTEGER, knownBitRate IN INTEGER), -- Methods associated with setting all the properties MEMBER PROCEDURE setProperties(ctx IN OUT RAW, setComments IN BOOLEAN), MEMBER FUNCTION checkProperties(ctx IN OUT RAW) RETURN BOOLEAN, MEMBER FUNCTION getAttribute( ctx IN OUT RAW, name IN VARCHAR2) RETURN VARCHAR2, MEMBER PROCEDURE getAllAttributes( ctx IN OUT RAW, attributes IN OUT NOCOPY CLOB), -- Methods associated with video processing MEMBER FUNCTION processVideoCommand( ctx IN OUT RAW, cmd IN VARCHAR2, arguments IN VARCHAR2, result OUT RAW) RETURN RAW );
where:
This section describes the constructor functions.
The interMedia constructor functions are as follows:
init( ) RETURN ORDVideo;
Allows for easy initialization of instances of the ORDVideo object type.
None.
None.
None.
This static method initializes all the ORDVideo attributes to NULL with the following exceptions:
You should begin using the init( ) method as soon as possible to allow you to more easily initialize the ORDVideo object type, especially if the ORDVideo type evolves and attributes are added in a future release. INSERT statements left unchanged using the default constructor (which initializes each object attribute), will fail under these circumstances.
Initialize the ORDVideo object attributes:
BEGIN INSERT INTO tvid VALUES (ORDSYS.ORDVideo.init( )); END; /
RETURN ORDVideo;
The source type of the video data.
The source location of the video data.
The source name of the video data.
None.
None.
BEGIN INSERT INTO tvid VALUES (ORDSYS.ORDVideo.init('file','VIDDIR','video1.rm')); END; /
This section presents reference information on the Oracle interMedia methods used for video data manipulation. These methods are described in the following groupings:
For more information on object types and methods, see Oracle9i Database Concepts.
The methods described in this reference chapter show examples based on a test video table TVID. Refer to the TVID table definition that follows when reading through the examples:
CREATE TABLE TVID(n NUMBER, vid ORDSYS.ORDVideo) storage (initial 100K next 100K pctincrease 0); INSERT INTO TVID VALUES(1, ORDSYS.ORDVideo.init()); INSERT INTO TVID VALUES(2, ORDSYS.ORDVideo.init());
checkProperties(ctx IN OUT RAW) RETURN BOOLEAN;
Checks all the properties of the stored video data, including the following video attributes: format, frame size, frame resolution, frame rate, video duration, number of frames, compression type, number of colors, and bit rate.
The format plug-in context information.
The checkProperties( ) method does not check the MIME type because a file can have multiple correct MIME types and this is not well defined.
None.
VIDEO_PLUGIN_EXCEPTION
This exception is raised if you call the checkProperties( ) method and the video plug-in raises an exception when calling this method.
Check property information for known video attributes:
DECLARE obj ORDSYS.ORDVideo; ctx RAW(4000) :=NULL; BEGIN select vid into obj from TVID where N =1 ; if (obj.checkProperties(ctx)) then DBMS_OUTPUT.put_line('check Properties returned true'); else DBMS_OUTPUT.put_line('check Properties returned false'); end if; EXCEPTION WHEN OTHERS THEN DBMS_OUTPUT.put_line('exception raised'); END; /
getAllAttributes(
ctx IN OUT RAW,
attributes IN OUT NOCOPY CLOB);
Returns a formatted string for convenient client access. For natively supported formats, the string includes the following list of audio data attributes separated by a comma (,): width, height, format, frameResolution, frameRate, videoDuration, numberOfFrames, compressionType, numberOfColors, and bitRate. For user-defined formats, the string is defined by the format plug-in.
The attributes.
These video data attributes are available from the header of the formatted video data.
Video data attribute information can be extracted from the video data itself. You can extend support to a video format that is not understood by the ORDVideo object by implementing an ORDPLUGINS.ORDX_<format>_VIDEO package that supports that format. See Section 3.4.13 for more information.
None.
METHOD_NOT_SUPPORTED
This exception is raised if you call the getAllAttributes( ) method and the video plug-in raises an exception when calling this method.
Return all video attributes for video data stored in the database:
DECLARE obj ORDSYS.ORDVideo; tempLob CLOB; ctx RAW(4000) :=NULL; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1; DBMS_OUTPUT.PUT_LINE('getting comma separated list of all attributes'); DBMS_OUTPUT.PUT_LINE('---------------------------------------------'); DBMS_LOB.CREATETEMPORARY(tempLob, FALSE, DBMS_LOB.CALL); obj.getAllAttributes(ctx,tempLob);
DBMS_OUTPUT.put_line(DBMS_LOB.substr(tempLob, DBMS_LOB.getLength(tempLob), 1));
EXCEPTION WHEN ORDSYS.ORDSourceExceptions.METHOD_NOT_SUPPORTED THEN DBMS_OUTPUT.put_line('Source METHOD_NOT_SUPPORTED caught'); WHEN ORDSYS.ORDSourceExceptions.SOURCE_PLUGIN_EXCEPTION THEN DBMS_OUTPUT.put_line('SOURCE PLUGIN EXCEPTION caught'); WHEN ORDSYS.ORDVideoExceptions.METHOD_NOT_SUPPORTED THEN DBMS_OUTPUT.put_line('VIDEO METHOD_NOT_SUPPORTED EXCEPTION caught'); WHEN ORDSYS.ORDVideoExceptions.VIDEO_PLUGIN_EXCEPTION THEN DBMS_OUTPUT.put_line('VIDEO PLUGIN EXCEPTION caught'); WHEN OTHERS THEN DBMS_OUTPUT.put_line('EXCEPTION CAUGHT'); END; /
getAttribute(
ctx IN OUT RAW,
name IN VARCHAR2)
RETURN VARCHAR2;
Returns the value of the requested attribute from video data for user-defined formats only.
The name of the attribute.
The video data attributes are available from the header of the formatted video data.
None.
This exception is raised if you call the getAttribute( ) method and the video plug-in raises an exception when calling this method.
Return information for the specified video attribute for video data stored in the database:
DECLARE obj ORDSYS.ORDVideo; res VARCHAR2(4000); ctx RAW(4000) :=NULL; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1; DBMS_OUTPUT.PUT_LINE('getting video duration'); DBMS_OUTPUT.PUT_LINE('---------------------'); res := obj.getAttribute(ctx,'video_duration'); EXCEPTION WHEN ORDSYS.ORDSourceExceptions.METHOD_NOT_SUPPORTED THEN DBMS_OUTPUT.put_line('Source METHOD_NOT_SUPPORTED caught'); WHEN ORDSYS.ORDSourceExceptions.SOURCE_PLUGIN_EXCEPTION THEN DBMS_OUTPUT.put_line('SOURCE PLUGIN EXCEPTION caught'); WHEN ORDSYS.ORDVideoExceptions.METHOD_NOT_SUPPORTED THEN DBMS_OUTPUT.put_line('VIDEO METHOD_NOT_SUPPORTED EXCEPTION caught'); WHEN ORDSYS.ORDVideoExceptions.VIDEO_PLUGIN_EXCEPTION THEN DBMS_OUTPUT.put_line('VIDEO PLUGIN EXCEPTION caught'); WHEN OTHERS THEN DBMS_OUTPUT.PUT_LINE('EXCEPTION caught'); END; /
getBitRate RETURN INTEGER;
Returns the value of the bitRate attribute of the video object.
None.
None.
None.
Return the object attribute value of the bitRate attribute of the video object:
DECLARE obj ORDSYS.ORDVideo; res INTEGER; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 ; res := obj.getBitRate(); DBMS_OUTPUT.put_line('bit rate : ' || res ); END; /
getCompressionType RETURN VARCHAR2;
Returns the value of the compressionType attribute of the video object.
None.
None.
None.
Return the object attribute value of the compressionType attribute of the video object:
DECLARE obj ORDSYS.ORDVideo; res VARCHAR2(4000); BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 ; res := obj.getCompressionType(); DBMS_OUTPUT.put_line('compression type: ' ||res); END; /
getContentInLob(
ctx IN OUT RAW,
format OUT VARCHAR2);
Copies data from a data source into the specified BLOB. The BLOB must not be the BLOB in source.localData.
The source plug-in context information.
The LOB in which to receive data.
The MIME type of the data; this may or may not be returned.
The format of the data; this may or may not be returned.
None.
None.
ORDSourceExceptions.INCOMPLETE_SOURCE_INFORMATION
This exception is raised if you call the getContentInLob( ) method and the value of srcType is NULL.
This exception is raised if you call the getContentInLob( ) method and this method is not supported by the source plug-in being used.
This exception is raised if you call the getContentInLob( ) method and within a source plug-in when any other exception is raised.
See Appendix H for more information about these exceptions.
Get data from a data source into the specified BLOB on the local source:
DECLARE obj ORDSYS.ORDVideo; tempBLob BLOB; mimeType VARCHAR2(4000); format VARCHAR2(4000); ctx RAW(4000) :=NULL; BEGIN SELECT vid INTO obj FROM TVID WHERE N = 1 ; if(obj.isLocal) then DBMS_OUTPUT.put_line('local is true'); end if; DBMS_LOB.CREATETEMPORARY(tempBLob, true, 10); obj.getContentInLob(ctx,tempBLob, mimeType,format); DBMS_OUTPUT.PUT_LINE(TO_CHAR(DBMS_LOB.getLength(tempBLob))); EXCEPTION WHEN ORDSYS.ORDSourceExceptions.METHOD_NOT_SUPPORTED THEN DBMS_OUTPUT.put_line('ORDSourceExceptions.METHOD_NOT_SUPPORTED caught'); WHEN OTHERS THEN DBMS_OUTPUT.put_line('EXCEPTION caught'); END; /
getContentLength(ctx IN OUT RAW) RETURN INTEGER;
Returns the length of the video data content stored in the source.
This method is not supported for all source types. For example, HTTP type sources do not support this method. If you want to implement this call for HTTP type sources, you must define your own modified HTTP source type and implement this method on it.
WNPS, RNDS, RNPS)
ORDSourceExceptions.INCOM-PLETE_SOURCE_INFORMATION
This exception is raised if you call the getContentLength( ) method and the value of srcType is NULL and data is not stored locally in the BLOB.
This exception is raised if you call the getContentLength( ) method within a source plug-in when any other exception is raised.
See Appendix H for more information about this exception.
See the example in "import( )".
getDescription RETURN VARCHAR2;
Returns the description of the video data.
None.
None.
DESCRIPTION_IS_NOT_SET
This exception is raised if you call the getDescription method and the description is not set.
See the example in setDescription( ).
getFormat RETURN VARCHAR2;
Returns the value of the format attribute of the video object.
None.
None.
PRAGMA RESTRICT_REFERENCES(getStoredFormat, WNDS,
WNPS, RNDS, RNPS)
VIDEO_FORMAT_IS_NULL
This exception is raised if you call the getFormat( ) method and the value for format is NULL.
Set the format and then get it for some stored video data:
DECLARE obj ORDSYS.ORDVideo; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 FOR UPDATE; DBMS_OUTPUT.PUT_LINE('writing format'); DBMS_OUTPUT.PUT_LINE('--------------'); obj.setFormat('avi'); DBMS_OUTPUT.PUT_LINE(obj.getFormat()); UPDATE TVID SET vid=obj WHERE N=1; COMMIT; END; /
getFrameRate RETURN INTEGER;
Returns the value of the frameRate attribute of the video object.
None.
None.
None.
Return the object attribute value of the frame rate for video data stored in the database:
DECLARE obj ORDSYS.ORDVideo; res INTEGER; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 ; res := obj.getFrameRate(); DBMS_OUTPUT.put_line('frame rate : ' ||res); END; /
getFrameResolution RETURN INTEGER;
Returns the value of the frameResolution attribute of the video object.
None.
None.
WNPS, RNDS, RNPS)
None.
Return the value of the frame resolution for the video data:
DECLARE obj ORDSYS.ORDVideo; res INTEGER; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 ; res := obj.getFrameResolution(); DBMS_OUTPUT.put_line('resolution : ' ||res); END; /
getFrameSize(
retHeight OUT INTEGER);
Returns the value of the height and width attributes of the video object.
The frame width in pixels.
The frame height in pixels.
None.
None.
Return the frame size for video data:
DECLARE obj ORDSYS.ORDVideo; width INTEGER; height INTEGER; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 ; obj.getFrameSize(width, height); DBMS_OUTPUT.put_line('width :' || width); DBMS_OUTPUT.put_line('height :' || height); END; /
getNumberOfColors RETURN INTEGER;
Returns the value of the numberOfColors attribute of the video object.
None.
None.
WNPS, RNDS, RNPS)
None.
Return the object attribute value of the numberOfColors attribute of the video object:
DECLARE obj ORDSYS.ORDVideo; res INTEGER; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 ; res := obj.getNumberOfColors(); DBMS_OUTPUT.put_line('number of colors: ' ||res); END; /
getNumberOfFrames RETURN INTEGER;
Returns the value of the numberOfFrames attribute of the video object.
None.
None.
WNPS, RNDS, RNPS)
None.
Return the object attribute value of the total number of frames in the video data:
DECLARE obj ORDSYS.ORDVideo; res INTEGER; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 ; res := obj.getNumberOfFrames(); DBMS_OUTPUT.put_line('number of frames : ' ||res); END; /
getVideoDuration RETURN INTEGER;
Returns the value of the videoDuration attribute of the video object.
None.
None.
WNPS, RNDS, RNPS)
None.
Return the total time to play the video data:
DECLARE obj ORDSYS.ORDVideo; res INTEGER; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 ; res := obj.getVideoDuration(); DBMS_OUTPUT.put_line('video duration : ' ||res); END; /
import(ctx IN OUT RAW);
Transfers video data from an external video data source to a local source (localData) within an Oracle database.
The source plug-in context information. This must be allocated. You must call the openSource( ) method; see the introduction to this chapter for more information.
Use the setSource( ) method to set the external source type, location, and name prior to calling import.
You must ensure that the directory exists or is created before you use this method for srcType 'file'.
After importing data from an external video data source to a local source (within an Oracle database), the source information remains unchanged (that is, pointing to the source from where the data was imported).
Invoking this method implicitly calls the setUpdateTime( ) and setLocal methods.
None.
This exception is raised if you call the import( ) method and the value of srcType is NULL.
ORDSourceExceptions.NULL_SOURCE
This exception is raised if you call the import( ) method and the value of dlob is NULL.
This exception is raised if you call the import( ) method and this method is not supported by the source plug-in being used.
This exception is raised if you call the import( ) method within a source plug-in when any other exception is raised.
Import video data by first setting the source and then importing it:
DECLARE obj ORDSYS.ORDVideo; ctx RAW(4000) :=NULL; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 FOR UPDATE; DBMS_OUTPUT.PUT_LINE('setting and getting source'); DBMS_OUTPUT.PUT_LINE('--------------------------'); -- set source to a file obj.setSource('file','VIDEODIR','testvid.dat'); -- get source information DBMS_OUTPUT.PUT_LINE(obj.getSource()); -- import data obj.import(ctx); -- check size DBMS_OUTPUT.PUT_LINE(TO_CHAR(obj.getContentLength(ctx))); DBMS_OUTPUT.PUT_LINE(obj.getSource()); DBMS_OUTPUT.PUT_LINE('deleting contents'); DBMS_OUTPUT.PUT_LINE('-----------------'); obj.deleteContent(); DBMS_OUTPUT.PUT_LINE(TO_CHAR(obj.getContentLength(ctx))); UPDATE TVID SET vid=obj WHERE N=1; COMMIT; END; /
importFrom(ctx IN OUT RAW,
source_name IN VARCHAR2);
Transfers video data from the specified external video data source to a local source (localData) within an Oracle database.
The location from where the video data is to be imported.
The name of the video data.
This method is similar to the import( ) method except the source information is specified as parameters to the method instead of separately.
After importing data from an external video data source to a local source (within an Oracle database), the source information (that is, pointing to the source from where the data was imported) is set to the input values.
None.
ORDSourceExceptions.NULL_SOURCE exception
This exception is raised if you call the importFrom( ) method and the value dlob is NULL.
This exception is raised if you call the importFrom( ) method and this method is not supported by the source plug-in being used.
This exception is raised if you call the importFrom( ) method within a source plug-in when any other exception is raised.
Import video data from the specified external data source into the local source:
DECLARE obj ORDSYS.ORDVideo; ctx RAW(4000) :=NULL; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 FOR UPDATE; DBMS_OUTPUT.PUT_LINE('setting and getting source'); DBMS_OUTPUT.PUT_LINE('--------------------------'); -- import data obj.importFrom(ctx,'file','VIDEODIR','MV1.AVI'); -- check size DBMS_OUTPUT.PUT_LINE(TO_CHAR(obj.getContentLength(ctx))); DBMS_OUTPUT.PUT_LINE(TO_CHAR(DBMS_LOB.GETLENGTH(obj.getContent))); DBMS_OUTPUT.PUT_LINE(obj.getSource()); DBMS_OUTPUT.PUT_LINE('deleting contents'); DBMS_OUTPUT.PUT_LINE('-----------------'); obj.deleteContent(); DBMS_OUTPUT.PUT_LINE(TO_CHAR(obj.getContentLength(ctx))); UPDATE TVID SET vid=obj WHERE N=1; COMMIT; EXCEPTION WHEN ORDSYS.ORDSourceExceptions.METHOD_NOT_SUPPORTED THEN DBMS_OUTPUT.put_line('Source METHOD_NOT_SUPPORTED caught'); WHEN ORDSYS.ORDSourceExceptions.SOURCE_PLUGIN_EXCEPTION THEN DBMS_OUTPUT.put_line('SOURCE PLUGIN EXCEPTION caught'); WHEN ORDSYS.ORDVideoExceptions.METHOD_NOT_SUPPORTED THEN DBMS_OUTPUT.put_line('VIDEO METHOD_NOT_SUPPORTED EXCEPTION caught'); WHEN ORDSYS.ORDVideoExceptions.VIDEO_PLUGIN_EXCEPTION THEN DBMS_OUTPUT.put_line('VIDEO PLUGIN EXCEPTION caught'); WHEN OTHERS THEN DBMS_OUTPUT.PUT_LINE('EXCEPTION Caught'); END; /
ctx IN OUT RAW,
cmd IN VARCHAR2,
result OUT RAW)
RETURN RAW;
Allows you to send a command and related arguments to the format plug-in for processing.
Any command recognized by the format plug-in.
The arguments of the command.
The result of calling this function returned by the format plug-in.
Use this method to send any video commands and their respective arguments to the format plug-in. Commands are not interpreted; they are taken and passed through to a format plug-in to be processed.
If the format is set to NULL, then the processVideoCommand( ) method uses the default format plug-in; otherwise, it uses your user-defined format plug-in.
You can extend support to a format that is not understood by the ORDVideo object by preparing an ORDPLUGINS.ORDX_<format>_VIDEO package that supports that format. See Section 3.4.13 for more information.
None.
METHOD_NOT_SUPPORTED or VIDEO_PLUGIN_EXCEPTION
Either exception is raised if you call the ProcessVideoCommand( ) method and the video plug-in raises an exception when calling this method.
Process a set of commands:
DECLARE obj ORDSYS.ORDVideo; res RAW(4000); result RAW(4000); command VARCHAR(4000); argList VARCHAR(4000); ctx RAW(4000) :=NULL; BEGIN select vid into obj from TVID where N =1 for UPDATE; -- assign command -- assign argList res := obj.processVideoCommand(ctx, command, argList, result); UPDATE TVID SET vid=obj WHERE N=1 ; COMMIT; EXCEPTION WHEN ORDSYS.ORDSourceExceptions.METHOD_NOT_SUPPORTED THEN DBMS_OUTPUT.put_line('Source METHOD_NOT_SUPPORTED caught'); WHEN ORDSYS.ORDSourceExceptions.SOURCE_PLUGIN_EXCEPTION THEN DBMS_OUTPUT.put_line('SOURCE PLUGIN EXCEPTION caught'); WHEN ORDSYS.ORDVideoExceptions.METHOD_NOT_SUPPORTED THEN DBMS_OUTPUT.put_line('VIDEO METHOD_NOT_SUPPORTED EXCEPTION caught'); WHEN ORDSYS.ORDVideoExceptions.VIDEO_PLUGIN_EXCEPTION THEN DBMS_OUTPUT.put_line('VIDEO PLUGIN EXCEPTION caught'); WHEN OTHERS THEN DBMS_OUTPUT.put_line('EXCEPTION caught'); END; /
setBitRate(knownBitRate IN INTEGER);
Sets the value of the bitRate attribute of the video object.
The bit rate.
Calling this method implicitly calls the setUpdateTime( ) method.
None.
NULL_INPUT_VALUE
This exception is raised if you call the setBitRate( ) method and the value for the knownBitRate parameter is NULL.
See the example in "setFrameSize( )".
setCompressionType(knownCompressionType IN VARCHAR2);
Sets the value of the compressionType attribute of the video object.
A known compression type.
None.
NULL_INPUT_VALUE
This exception is raised if you call the setCompressionType( ) method and the value for the knownCompressionType parameter is NULL.
setDescription (user_description IN VARCHAR2);
Sets the description of the video data.
The description of the video data.
Each video object may need a description to help some client applications. For example, a Web-based client can show a list of video descriptions from which a user can select one to access the video data.
Web access components and other client components provided with Oracle interMedia make use of this description attribute to present video data to users.
None.
None.
Set the description attribute for some video data:
DECLARE obj ORDSYS.ORDVideo; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 FOR UPDATE; DBMS_OUTPUT.PUT_LINE('writing description'); DBMS_OUTPUT.PUT_LINE('-------------'); obj.setDescription('video1'); DBMS_OUTPUT.PUT_LINE(obj.getDescription()); UPDATE TVID SET vid=obj WHERE N=1; COMMIT; END; /
setFormat(knownFormat IN VARCHAR2);
Sets the format attribute of the video object.
The known format of the video data to be set in the video object.
None.
NULL_INPUT_VALUE
This exception is raised if you call the setFormat( ) method and the value for the knownFormat parameter is NULL.
Set the format for some stored video data:
DECLARE obj ORDSYS.ORDVideo; BEGIN SELECT vid INTO obj FROM TVID WHERE N=1 FOR UPDATE; DBMS_OUTPUT.PUT_LINE('writing format'); DBMS_OUTPUT.PUT_LINE('--------------'); obj.setFormat('avi'); DBMS_OUTPUT.PUT_LINE(obj.getFormat); UPDATE TVID SET vid=obj WHERE N=1; COMMIT; EXCEPTION WHEN ORDSYS.ORDVideoExceptions.NULL_INPUT_VALUE THEN DBMS_OUTPUT.put_line('ORDVideoExceptions.NULL_INPUT_VALUE caught'); WHEN OTHERS THEN DBMS_OUTPUT.put_line('EXCEPTION caught'); END; /
setFrameRate(knownFrameRate IN INTEGER);
Sets the value of the frameRate attribute of the video object.
The frame rate.
None.
NULL_INPUT_VALUE
This exception is raised if you call the setFrameRate( ) method and the value for the knownFrameRate parameter is NULL.
setFrameResolution(knownFrameResolution IN INTEGER);
Sets the value of the frameResolution attribute of the video object.
The known frame resolution in pixels per inch.
None.
NULL_INPUT_VALUE
This exception is raised if you call the setFrameResolution( ) method and the value for the knownFrameResolution parameter is NULL.
setFrameSize(
knownHeight IN INTEGER);
Sets the value of the height and width attributes of the video object.
None.
NULL_INPUT_VALUE
This exception is raised if you call the setFrameSize( ) method and the value for either the knownWidth or knownHeight parameter is NULL.
Set the frame size for video data:
DECLARE obj ORDSYS.ORDVideo; BEGIN select vid into obj from TVID where N =1 for update; obj.setFrameSize(1,2); obj.setFrameResolution(4); obj.setFrameRate(5); obj.setVideoDuration(20); obj.setNumberOfFrames(8); obj.setCompressionType('Cinepak'); obj.setBitRate(1500); obj.setNumberOfColors(256); update TVID set vid = obj where N = 1; COMMIT; END; /
setKnownAttributes(
knownVideoDuration IN INTEGER,
Sets the known video attributes for the video data.
The known format.
The known width.
The known height.
The known frame resolution.
The known frame rate.
The known video duration.
The known number of frames.
The known compression type.
The known number of colors.
The known bit rate.
None.
None.
Set the property information for all known attributes for video data:
DECLARE obj ORDSYS.ORDVideo; width integer; height integer; BEGIN select vid into obj from TVID where N =1 for update; obj.setKnownAttributes('MOOV',1,2,4,5,20,8,'Cinepak', 256, 1500); obj.getFrameSize(width, height); DBMS_OUTPUT.put_line('width: ' || TO_CHAR(width)); DBMS_OUTPUT.put_line('height: ' || TO_CHAR(height)); DBMS_OUTPUT.put_line('format: ' || obj.getFormat()); DBMS_OUTPUT.put_line('frame resolution: ' ||TO_CHAR(obj.getFrameResolution())); DBMS_OUTPUT.put_line('frame rate: ' || TO_CHAR(obj.getFrameRate())); DBMS_OUTPUT.put_line('video duration: ' || TO_CHAR(obj.getVideoDuration())); DBMS_OUTPUT.put_line('number of frames: ' || TO_CHAR(obj.getNumberOfFrames())); DBMS_OUTPUT.put_line('compression type: ' || obj.getCompressionType()); DBMS_OUTPUT.put_line('bite rate: ' || TO_CHAR(obj.getBitRate())); DBMS_OUTPUT.put_line('number of colors: ' || TO_CHAR(obj.getNumberOfColors())); update TVID set vid = obj where N = 1; COMMIT; END; /
setNumberOfColors(knownNumberOfColors RETURN INTEGER);
Sets the value of the numberOfColors attribute of the video object.
A known number of colors.
None.
NULL_INPUT_VALUE
This exception is raised if you call the setNumberOfColors( ) method and the value for the knownNumberOfColors parameter is NULL.
setNumberOfFrames(knownNumberOfFrames RETURN INTEGER);
Sets the value of the numberOfFrames attribute of the video object.
A known number of frames.
None.
NULL_INPUT_VALUE
This exception is raised if you call the setNumberOfFrames( ) method and the value for the knownNumberOfFrames parameter is NULL.
setComments IN BOOLEAN);
Reads the video data to get the values of the object attributes and then stores them in the object. For the known attributes that ORDVideo understands, it sets the properties for these attributes, which include: format, frame size, frame resolution, frame rate, video duration, number of frames, compression type, number of colors, and bit rate. It populates the comments field of the object with a rich set of format and application properties in XML form if the value of the setComments parameter is TRUE.
If the value is TRUE, then the comments field of the object is populated with a rich set of format and application properties of the video object in XML form, identical to what is provided by the interMedia Annotator utility; otherwise, if the value is FALSE, the comments field of the object remains unpopulated. The default value is FALSE.
If the property cannot be extracted from the media source, then the respective attribute is set to NULL.
If the format is set to NULL, then the setProperties( ) method uses the default format plug-in; otherwise, it uses your user-defined format plug-in.
None.
This exception is raised if you call the setProperties( ) method and the video plug-in raises an exception when calling this method.
Set the property information for known video attributes:
DECLARE obj ORDSYS.ORDVideo; ctx RAW(4000) :=NULL; BEGIN select vid into obj from TVID where N =1 for update; obj.setProperties(ctx,FALSE); update TVID set vid = obj where N = 1; COMMIT; EXCEPTION WHEN OTHERS THEN DBMS_OUTPUT.put_line('exception raised'); END; /
setVideoDuration(knownVideoDuration RETURN INTEGER);
Sets the value of the videoDuration attribute of the video object.
A known video duration.
None.
NULL_INPUT_VALUE
This exception is raised if you call the setVideoDuration( ) method and the value for the knownVideoDuration parameter is NULL.
This section presents reference information on the packages or PL/SQL plug-ins provided. Table 9-1 describes the PL/SQL plug-in packages provided in the ORDPLUGINS schema.
Section 9.4.1 describes the ORDPLUGINS.ORDX_DEFAULT_VIDEO package, the methods supported, and the level of support. Note that the methods supported and the level of support for the other PL/SQL plug-in packages described in Table 9-1 are identical for all plug-in packages, therefore, refer to Section 9.4.1.
Use the following provided ORDPLUGINS.ORDX_DEFAULT_VIDEO package as a guide in developing your own ORDPLUGINS.ORDX_<format>_VIDEO video format package. This package sets the mimeType field in the setProperties( ) method with a MIME type value that is dependent on the file format.
CREATE OR REPLACE PACKAGE ORDX_DEFAULT_VIDEO authid current_user AS --VIDEO ATTRIBUTES ACCESSORS FUNCTION getFormat(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN VARCHAR2; FUNCTION getAttribute(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo, name IN VARCHAR2) RETURN VARCHAR2; PROCEDURE getFrameSize(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo, width OUT INTEGER, height OUT INTEGER); FUNCTION getFrameResolution(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN INTEGER; FUNCTION getFrameRate(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN INTEGER; FUNCTION getVideoDuration(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN INTEGER; FUNCTION getNumberOfFrames(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN INTEGER; FUNCTION getCompressionType(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN VARCHAR2; FUNCTION getNumberOfColors(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN INTEGER; FUNCTION getBitRate(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN INTEGER; PROCEDURE setProperties(ctx IN OUT RAW, obj IN OUT NOCOPY ORDSYS.ORDVideo, setComments IN NUMBER := 0); FUNCTION checkProperties(ctx IN OUT RAW,obj IN ORDSYS.ORDVideo) RETURN NUMBER; -- must return name=value; name=value; ... pairs PROCEDURE getAllAttributes(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo, attributes IN OUT NOCOPY CLOB); -- VIDEO PROCESSING METHODS FUNCTION processCommand( ctx IN OUT RAW, obj IN OUT NOCOPY ORDSYS.ORDVideo, cmd IN VARCHAR2, arguments IN VARCHAR2, result OUT RAW) RETURN RAW; PRAGMA RESTRICT_REFERENCES(getFormat, WNDS, WNPS, RNDS, RNPS); PRAGMA RESTRICT_REFERENCES(getAttribute, WNDS, WNPS, RNDS, RNPS); PRAGMA RESTRICT_REFERENCES(getFrameSize, WNDS, WNPS, RNDS, RNPS); PRAGMA RESTRICT_REFERENCES(getFrameResolution, WNDS, WNPS, RNDS, RNPS); PRAGMA RESTRICT_REFERENCES(getFrameRate, WNDS, WNPS, RNDS, RNPS); PRAGMA RESTRICT_REFERENCES(getVideoDuration, WNDS, WNPS, RNDS, RNPS); PRAGMA RESTRICT_REFERENCES(getNumberOfFrames, WNDS, WNPS, RNDS, RNPS); PRAGMA RESTRICT_REFERENCES(getCompressionType, WNDS, WNPS, RNDS, RNPS); PRAGMA RESTRICT_REFERENCES(getNumberOfColors, WNDS, WNPS, RNDS, RNPS); PRAGMA RESTRICT_REFERENCES(getBitRate, WNDS, WNPS, RNDS, RNPS); END; /
Table 9-2 shows the methods supported in the ORDPLUGINS.ORDX_DEFAULT_VIDEO package and the exceptions raised if you call a method that is not supported.
Extending interMedia to support a new video data format consists of four steps:
Section 3.4.12 briefly describes how to extend interMedia to support a new video data format and describes the interface. A package body listing is provided in Example 9-1 to assist you in this operation. Add your variables to the places that say "--Your variables go here" and add your code to the places that say "--Your code goes here".
See Section F.4 for more information on installing your own video format plug-in and running the sample scripts provided.
CREATE OR REPLACE PACKAGE BODY ORDX_MY_VIDEO AS --VIDEO ATTRIBUTES ACCESSORS FUNCTION getFormat(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN VARCHAR2 IS --Your variables go here BEGIN --Your code goes here END; FUNCTION getAttribute(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo, name IN VARCHAR2) RETURN VARCHAR2 IS --Your variables go here BEGIN --Your code goes here END; PROCEDURE getFrameSize(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo, width OUT INTEGER, height OUT INTEGER) IS --Your variables go here BEGIN --Your code goes here END; FUNCTION getFrameResolution(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN INTEGER IS --Your variables go here BEGIN --Your code goes here END; FUNCTION getFrameRate(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN INTEGER IS --Your variables go here BEGIN --Your code goes here END; FUNCTION getVideoDuration(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN INTEGER IS --Your variables go here BEGIN --Your code goes here END; FUNCTION getNumberOfFrames(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN INTEGER IS --Your variables go here BEGIN --Your code goes here END; FUNCTION getCompressionType(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN VARCHAR2 IS --Your variables go here BEGIN --Your code goes here END; FUNCTION getNumberOfColors(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN INTEGER IS --Your variables go here BEGIN --Your code goes here END; FUNCTION getBitRate(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN INTEGER IS --Your variables go here BEGIN --Your code goes here END; PROCEDURE setProperties(ctx IN OUT RAW, obj IN OUT NOCOPY ORDSYS.ORDVideo, setComments IN NUMBER :=0) IS --Your variables go here BEGIN --Your code goes here END; FUNCTION checkProperties(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo) RETURN NUMBER IS IS --Your variables go here BEGIN --Your code goes here END; PROCEDURE getAllAttributes(ctx IN OUT RAW, obj IN ORDSYS.ORDVideo, attributes IN OUT NOCOPY CLOB) IS --Your variables go here BEGIN --Your code goes here END; -- VIDEO PROCESSING METHODS FUNCTION processCommand( ctx IN OUT RAW, obj IN OUT NOCOPY ORDSYS.ORDVideo, cmd IN VARCHAR2, arguments IN VARCHAR2, result OUT RAW) RETURN RAW IS --Your variables go here BEGIN --Your code goes here END; END; / show errors;
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
