Oracle Spatial User's Guide and Reference
Release 9.0.1
Part Number A88805-01
Library
Product
Contents
Index
Go to previous page Go to next page
15
Linear Referencing Functions
The MDSYS.SDO_LRS package contains functions that create, modify, query, and convert linear referencing elements. These functions do not change the state of the database.
Most Oracle LRS interfaces are functions. Any that are procedures, such as DEFINE_GEOM_SEGMENT, are identified as such. (Functions return a value; procedures do not return a value.)
The word functions is often used to refer to LRS interfaces (both functions and procedures) collectively.
To use the functions in this chapter, you must understand the linear referencing system (LRS) concepts and techniques described in Chapter 6.
Table 15-1 lists functions related to creating and editing geometric segments.
Table 15-1 Functions for Creating and Editing Geometric Segments
Function  Description
SDO_LRS.DEFINE_GEOM_SEGMENT (procedure)
Defines a geometric segment.
SDO_LRS.REDEFINE_GEOM_SEGMENT (procedure)
Populates the measures of all shape points of a geometric segment based on the start and end measures, overriding any previously assigned measures between the start point and end point.
SDO_LRS.CLIP_GEOM_SEGMENT
Clips a geometric segment (synonym of SDO_LRS.DYNAMIC_SEGMENT).
Clips a geometric segment (synonym of SDO_LRS.CLIP_GEOM_SEGMENT).
SDO_LRS.CONCATENATE_GEOM_SEGMENTS
Concatenates two geometric segments into one segment.
SDO_LRS.OFFSET_GEOM_SEGMENT
Returns the geometric segment at a specified offset from a geometric segment.
SDO_LRS.SCALE_GEOM_SEGMENT
Scales a geometric segment.
SDO_LRS.SPLIT_GEOM_SEGMENT (procedure)
Splits a geometric segment into two segments.
SDO_LRS.REVERSE_MEASURE
Returns a new geometric segment by reversing the original geometric segment.
SDO_LRS.TRANSLATE_MEASURE
Returns a new geometric segment by translating the original geometric segment (that is, shifting the start and end measures by a specified value).
SDO_LRS.REVERSE_GEOMETRY
Returns a new geometric segment by reversing the measure values and the direction of the original geometric segment.
Table 15-2 lists functions related to querying geometric segments.
Table 15-2 Functions for Querying Geometric Segments
SDO_LRS.VALID_GEOM_SEGMENT
Checks if a geometric segment is valid.
SDO_LRS.VALID_LRS_PT
Checks if an LRS point is valid.
SDO_LRS.VALID_MEASURE
Checks if a measure falls within the measure range of a geometric segment.
SDO_LRS.CONNECTED_GEOM_SEGMENTS
Checks if two geometric segments are connected.
SDO_LRS.GEOM_SEGMENT_LENGTH
Returns the length of a geometric segment.
SDO_LRS.GEOM_SEGMENT_START_PT
Returns the start point of a geometric segment.
SDO_LRS.GEOM_SEGMENT_END_PT
Returns the end point of a geometric segment.
SDO_LRS.GEOM_SEGMENT_START_MEASURE
Returns the start measure of a geometric segment.
SDO_LRS.GEOM_SEGMENT_END_MEASURE
Returns the end measure of a geometric segment.
SDO_LRS.GET_MEASURE
Returns the measure of an LRS point.
SDO_LRS.MEASURE_RANGE
Returns the measure range of a geometric segment, that is, the difference between the start measure and end measure.
SDO_LRS.MEASURE_TO_PERCENTAGE
Returns the percentage (0 to 100) that a specified measure is of the measure range of a geometric segment.
SDO_LRS.PERCENTAGE_TO_MEASURE
Returns the measure value of a specified percentage (0 to 100) of the measure range of a geometric segment.
SDO_LRS.LOCATE_PT
Finds the location of a point described by a measure and an offset on a geometric segment.
SDO_LRS.PROJECT_PT
Returns the projection point of a point on a geometric segment.
SDO_LRS.FIND_LRS_DIM_POS
Returns the position of the measure dimension within the SDO_DIM_ARRAY structure for a specified SDO_GEOMETRY column.
SDO_LRS.FIND_MEASURE
Returns the measure of the closest point on a segment to a specified projection point.
Table 15-3 lists functions related to converting geometric segments.
Table 15-3 Functions for Converting Geometric Segments
SDO_LRS.CONVERT_TO_LRS_DIM_ARRAY
Converts a standard dimensional array to a Linear Referencing System dimensional array by creating a measure dimension.
SDO_LRS.CONVERT_TO_LRS_GEOM
Converts a standard SDO_GEOMETRY line string to a Linear Referencing System geometric segment by adding measure information.
SDO_LRS.CONVERT_TO_LRS_LAYER
Converts all geometry objects in a column of type SDO_GEOMETRY from standard line string geometries without measure information to Linear Referencing System geometric segments with measure information, and updates the metadata.
SDO_LRS.CONVERT_TO_STD_DIM_ARRAY
Converts a Linear Referencing System dimensional array to a standard dimensional array by removing the measure dimension.
SDO_LRS.CONVERT_TO_STD_GEOM
Converts a Linear Referencing System geometric segment to a standard SDO_GEOMETRY line string by removing measure information.
SDO_LRS.CONVERT_TO_STD_LAYER
Converts all geometry objects in a column of type SDO_GEOMETRY from Linear Referencing System geometric segments with measure information to standard line string geometries without measure information, and updates the metadata.
For more information about conversion functions, see Section 6.5.10.
The rest of this chapter provides reference information on the functions, listed in alphabetical order.
Format
SDO_LRS.CLIP_GEOM_SEGMENT(
or
Description
Returns the geometry object resulting from a clip operation on a geometric segment.
SDO_LRS.CLIP_GEOM_SEGMENT and SDO_LRS.DYNAMIC_SEGMENT are synonyms: both functions have the same parameters, behavior, and return value.
Parameters
geom_segment
Cartographic representation of a linear feature.
dim_array
Dimensional information array corresponding to geom_segment, usually selected from one of the xxx_SDO_GEOM_METADATA views.
start_measure
Start measure of the geometric segment.
end_measure
End measure of the geometric segment.
Usage Notes
An exception is raised if geom_segment, start_measure, or end_measure is invalid.
start_measure and end_measure can be any points on the geometric segment. They do not have to be in any specific order. For example, start_measure and end_measure can be 5 and 10, respectively, or 10 and 5, respectively.
The direction and measures of the resulting geometric segment are preserved (that is, they reflect the original segment).
The _3D format of this function (SDO_LRS.CLIP_GEOM_SEGMENT_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
For more information about clipping geometric segments, see Section 6.5.3.
Examples
The following example clips the geometric segment representing Route 1, returning the segment from measures 5 through 10. (This example uses the definitions from the example in Section 6.6.)
SELECT  SDO_LRS.CLIP_GEOM_SEGMENT(route_geometry, 5, 10)
  FROM lrs_routes WHERE route_id = 1;
SDO_LRS.CLIP_GEOM_SEGMENT(ROUTE_GEOMETRY,5,10)(SDO_GTYPE, SDO_SRID, SDO_POINT(X,
SDO_GEOMETRY(3302, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 2, 1), SDO_ORDINATE_ARRAY(
5, 4, 5, 8, 4, 8, 10, 4, 10))
Format
SDO_LRS.CONCATENATE_GEOM_SEGMENTS(
or
Description
Returns the geometry object resulting from the concatenation of two geometric segments.
Parameters
geom_segment_1
First geometric segment to be concatenated.
dim_array_1
Dimensional information array corresponding to geom_segment_1, usually selected from one of the xxx_SDO_GEOM_METADATA views.
geom_segment_2
Second geometric segment to be concatenated.
dim_array_2
Dimensional information array corresponding to geom_segment_2, usually selected from one of the xxx_SDO_GEOM_METADATA views.
tolerance
Tolerance value (see Section 1.5.5).
Usage Notes
An exception is raised if geom_segment_1 or geom_segment_2 has an invalid geometry type or dimensionality, or if geom_segment_1 and geom_segment_2 are based on different coordinate systems.
The direction of the first geometric segment is preserved, and all measures of the second segment are shifted so that its start measure is the same as the end measure of the first segment.
The _3D format of this function (SDO_LRS.CONCATENATE_GEOM_SEGMENTS_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
For more information about concatenating geometric segments, see Section 6.5.5
Examples
The following example defines the geometric segment, splits it into two segments, then concatenates those segments. (This example uses the definitions from the example in Section 6.6. The definitions of result_geom_1, result_geom_2, and result_geom_3 are displayed in Example 6-4.)
DECLARE
geom_segment MDSYS.SDO_GEOMETRY;
line_string MDSYS.SDO_GEOMETRY;
dim_array MDSYS.SDO_DIM_ARRAY;
result_geom_1 MDSYS.SDO_GEOMETRY;
result_geom_2 MDSYS.SDO_GEOMETRY;
result_geom_3 MDSYS.SDO_GEOMETRY;
BEGIN
SELECT a.route_geometry into geom_segment FROM lrs_routes a
  WHERE a.route_name = 'Route1';
SELECT m.diminfo into dim_array from
  user_sdo_geom_metadata m
  WHERE m.table_name = 'LRS_ROUTES' AND m.column_name = 'ROUTE_GEOMETRY';
-- Define the LRS segment for Route1.
SDO_LRS.DEFINE_GEOM_SEGMENT (geom_segment,
  dim_array,
  0,    -- Zero starting measure: LRS segment starts at start of route.
  27);  -- End of LRS segment is at measure 27.
SELECT a.route_geometry INTO line_string FROM lrs_routes a
-- Split Route1 into two segments.
SDO_LRS.SPLIT_GEOM_SEGMENT(line_string,dim_array,5,result_geom_1,result_geom_2);
-- Concatenate the segments that were just split.
result_geom_3 := SDO_LRS.CONCATENATE_GEOM_SEGMENTS(result_geom_1, dim_array,
result_geom_2, dim_array);
-- Insert geometries into table, to display later.
INSERT INTO lrs_routes VALUES(
  11,
  'result_geom_1',
  result_geom_1
  12,
  'result_geom_2',
  result_geom_2
  13,
  'result_geom_3',
  result_geom_3
END;
Format
SDO_LRS.CONNECTED_GEOM_SEGMENTS(
or
Description
Checks if two geometric segments are spatially connected.
Parameters
geom_segment_1
First of two geometric segments to be checked.
dim_array_1
geom_segment_2
Second of two geometric segments to be checked.
dim_array_2
tolerance
Usage Notes
This function returns TRUE if the geometric segments are spatially connected and FALSE if the geometric segments are not spatially connected.
The _3D format of this function (SDO_LRS.CONNECTED_GEOM_SEGMENTS_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example checks if two geometric segments (results of a previous split operation) are spatially connected.
-- Are result_geom_1 and result_geom2 connected?
SELECT  SDO_LRS.CONNECTED_GEOM_SEGMENTS(a.route_geometry,
           b.route_geometry, 0.005)
  FROM lrs_routes a, lrs_routes b
  WHERE a.route_id = 11 AND b.route_id = 12;
SDO_LRS.CONNECTED_GEOM_SEGMENTS(A.ROUTE_GEOMETRY,B.ROUTE_GEOMETRY,0.005)
TRUE
Format
SDO_LRS.CONVERT_TO_LRS_DIM_ARRAY(
Description
Parameters
dim_array
Dimensional information array corresponding to the layer (column of geometries) to be converted, usually selected from one of the xxx_SDO_GEOM_METADATA views.
dim_name
Name of the measure dimension (M, if not otherwise specified).
dim_pos
Position of the measure dimension (the last SDO_DIM_ELEMENT object position in the SDO_DIM_ARRAY, if not otherwise specified).
lower_bound
Lower bound (SDO_LB value in the SDO_DIM_ELEMENT definition) of the ordinate in the measure dimension.
upper_bound
Upper bound (SDO_UB value in the SDO_DIM_ELEMENT definition) of the ordinate in the measure dimension.
tolerance
Usage Notes
This function converts a standard dimensional array to a Linear Referencing System dimensional array by creating a measure dimension. Specifically, it adds an SDO_DIM_ELEMENT object at the end of the current SDO_DIM_ELEMENT objects in the SDO_DIM_ARRAY for the diminfo (unless another dim_pos is specified), and sets the SDO_DIMNAME value in this added SDO_DIM_ELEMENT to M (unless another dim_name is specified). It sets the other values in the added SDO_DIM_ELEMENT according to the values if the upper_bound, lower_bound, and tolerance parameter values.
If dim_array already contains dimensional information, the dim_array is returned.
The _3D format of this function (SDO_LRS.CONVERT_TO_LRS_DIM_ARRAY_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example converts the dimensional array for the LRS_ROUTES table to Linear Referencing System format. (This example uses the definitions from the example in Section 6.6.)
SELECT SDO_LRS.CONVERT_TO_LRS_DIM_ARRAY(m.diminfo)
   FROM user_sdo_geom_metadata m
SDO_LRS.CONVERT_TO_LRS_DIM_ARRAY(M.DIMINFO)(SDO_DIMNAME, SDO_LB, SDO_UB, SDO_TOL
SDO_DIM_ARRAY(SDO_DIM_ELEMENT('X', 0, 20, .005), SDO_DIM_ELEMENT('Y', 0, 20, .00
5), SDO_DIM_ELEMENT('M', 0, 20, .005))
Format
SDO_LRS.CONVERT_TO_LRS_GEOM(
Description
Parameters
standard_geom
Line string geometry that does not contain measure information.
dim_array
Dimensional information array corresponding to standard_geom, usually selected from one of the xxx_SDO_GEOM_METADATA views.
m_pos
Position of the measure dimension. If specified, must be 3 or 4. By default, the measure dimension is the last dimension in the SDO_DIM_ARRAY.
start_measure
Distance measured from the start point of a geometric segment to the start point of the linear feature. The default is 0.
end_measure
Distance measured from the end point of a geometric segment to the start point of the linear feature. The default is the cartographic length (for example, 75 if the cartographic length is 75 miles and the unit of measure is miles).
Usage Notes
This function returns a Linear Referencing System geometric segment with measure information, with measure information provided for all shape points.
An exception is raised if standard_geom has an invalid geometry type or dimensionality, if m_pos is less than 3 or greater than 4, or if start_measure or end_measure is out of range.
The _3D format of this function (SDO_LRS.CONVERT_TO_LRS_GEOM_3D) is available; however, the m_pos parameter is not available for SDO_LRS.CONVERT_TO_LRS_GEOM_3D. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example converts the geometric segment representing Route 1 to Linear Referencing System format. (This example uses the definitions from the example in Section 6.6.)
SELECT SDO_LRS.CONVERT_TO_LRS_GEOM(a.route_geometry, m.diminfo)
  FROM lrs_routes a, user_sdo_geom_metadata m
    AND a.route_id = 1;
SDO_LRS.CONVERT_TO_LRS_GEOM(A.ROUTE_GEOMETRY,M.DIMINFO)(SDO_GTYPE, SDO_SRID, SDO
SDO_GEOMETRY(3002, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 2, 1), SDO_ORDINATE_ARRAY(
2, 2, 0, 2, 4, 2, 8, 4, 8, 12, 4, 12, 12, 10, NULL, 8, 10, 22, 5, 14, 27))
Format
SDO_LRS.CONVERT_TO_LRS_LAYER(
or
Description
Converts all geometry objects in a column of type SDO_GEOMETRY (that is, converts a layer) from standard line string geometries without measure information to Linear Referencing System geometric segments with measure information, and updates the metadata in the USER_SDO_GEOM_METADATA view.
Parameters
table_name
Table containing the column with the SDO_GEOMETRY objects.
column_name
Column in table_name containing the SDO_GEOMETRY objects.
dim_name
Name of the measure dimension. If this parameter is null, M is assumed.
dim_pos
Position of the measure dimension within the SDO_DIM_ARRAY structure for the specified SDO_GEOMETRY column. If this parameter is null, the number corresponding to the last position is assumed.
lower_bound
upper_bound
tolerance
Usage Notes
This function returns TRUE if the conversion was successful or if the layer already contains measure information, and the function returns an exception if the conversion was not successful.
An exception is raised if the existing dimensional information for the table is invalid.
The measure values are assigned based on a start measure of zero and an end measure of the cartographic length.
If a spatial index already exists on column_name, you must delete (drop) the index before converting the layer and create a new index after converting the layer. For information about deleting and creating indexes, see the DROP INDEX and CREATE INDEX statements in Chapter 9.
The _3D format of this function (SDO_LRS.CONVERT_TO_LRS_LAYER_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example converts the geometric segments in the ROUTE_GEOMETRY column of the LRS_ROUTES table to Linear Referencing System format. (This example uses the definitions from the example in Section 6.6.) The SELECT statement shows that dimensional information has been added (that is, SDO_DIM_ELEMENT('M', NULL, NULL, NULL) included in the definition).
BEGIN
  IF (SDO_LRS.CONVERT_TO_LRS_LAYER('LRS_ROUTES', 'ROUTE_GEOMETRY') =  'TRUE')
     THEN
       DBMS_OUTPUT.PUT_LINE('Conversion from STD_LAYER to LRS_LAYER succeeded');
     ELSE
       DBMS_OUTPUT.PUT_LINE('Conversion from STD_LAYER to LRS_LAYER failed');
  END IF;
END;
PL/SQL procedure successfully completed.
SQL> SELECT diminfo FROM user_sdo_geom_metadata WHERE table_name = 'LRS_ROUTES'
AND column_name = 'ROUTE_GEOMETRY';
DIMINFO(SDO_DIMNAME, SDO_LB, SDO_UB, SDO_TOLERANCE)
5), SDO_DIM_ELEMENT('M', NULL, NULL, NULL))
Format
SDO_LRS.CONVERT_TO_STD_DIM_ARRAY(
Description
Parameters
dim_array
m_pos
Usage Notes
This function converts a Linear Referencing System dimensional array to a standard dimensional array by removing the measure dimension. Specifically, it removes the SDO_DIM_ELEMENT object at the end of the current SDO_DIM_ELEMENT objects in the SDO_DIM_ARRAY for the diminfo.
An exception is raised if m_pos is invalid (less than 3 or greater than 4).
If dim_array is already a standard dimensional array (that is, does not contain dimensional information), the dim_array is returned.
The _3D format of this function (SDO_LRS.CONVERT_TO_STD_DIM_ARRAY_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example converts the dimensional array for the LRS_ROUTES table to standard format. (This example uses the definitions from the example in Section 6.6.)
SELECT SDO_LRS.CONVERT_TO_STD_DIM_ARRAY(m.diminfo)
SDO_LRS.CONVERT_TO_STD_DIM_ARRAY(M.DIMINFO)(SDO_DIMNAME, SDO_LB, SDO_UB, SDO_TOL
5))
Format
SDO_LRS.CONVERT_TO_STD_GEOM(
Description
Parameters
lrs_geom
Linear Referencing System geometry that contains measure information.
dim_array
Dimensional information array corresponding to lrs_geom, usually selected from one of the xxx_SDO_GEOM_METADATA views.
Usage Notes
This function returns an SDO_GEOMETRY object in which all measure information is removed.
The _3D format of this function (SDO_LRS.CONVERT_TO_STD_GEOM_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example converts the geometric segment representing Route 1 to standard format. (This example uses the definitions from the example in Section 6.6.)
SELECT SDO_LRS.CONVERT_TO_STD_GEOM(a.route_geometry, m.diminfo)
    AND a.route_id = 1;
SDO_LRS.CONVERT_TO_STD_GEOM(A.ROUTE_GEOMETRY,M.DIMINFO)(SDO_GTYPE, SDO_SRID, SDO
SDO_GEOMETRY(2002, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 2, 1), SDO_ORDINATE_ARRAY(
2, 2, 2, 4, 8, 4, 12, 4, 12, 10, 8, 10, 5, 14))
Format
SDO_LRS.CONVERT_TO_STD_LAYER(
Description
Converts all geometry objects in a column of type SDO_GEOMETRY (that is, converts a layer) from Linear Referencing System geometric segments with measure information to standard line string geometries without measure information, and updates the metadata in the USER_SDO_GEOM_METADATA view.
Parameters
table_name
column_name
Usage Notes
This function returns TRUE if the conversion was successful or if the layer already is a standard layer (that is, contains geometries without measure information), and the function returns an exception if the conversion was not successful.
An exception is raised if the conversion failed.
The _3D format of this function (SDO_LRS.CONVERT_TO_STD_LAYER_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example converts the geometric segments in the ROUTE_GEOMETRY column of the LRS_ROUTES table to standard format. (This example uses the definitions from the example in Section 6.6.) The SELECT statement shows that dimensional information has been removed (that is, no SDO_DIM_ELEMENT('M', NULL, NULL, NULL) included in the definition).
BEGIN
  IF (SDO_LRS.CONVERT_TO_STD_LAYER('LRS_ROUTES', 'ROUTE_GEOMETRY') =  'TRUE')
     THEN
       DBMS_OUTPUT.PUT_LINE('Conversion from LRS_LAYER to STD_LAYER succeeded');
     ELSE
       DBMS_OUTPUT.PUT_LINE('Conversion from LRS_LAYER to STD_LAYER failed');
  END IF;
END;
   WHERE table_name = 'LRS_ROUTES' AND column_name = 'ROUTE_GEOMETRY';
5))
Format
SDO_LRS.DEFINE_GEOM_SEGMENT(
or
Description
Defines a geometric segment by assigning start and end measures to a geometric segment, and assigns values to any null measures. (This is a procedure, not a function.)
Parameters
geom_segment
dim_array
start_measure
Distance measured from the start point of a geometric segment to the start point of the linear feature. The default is the existing value (if any) in the measure dimension; otherwise, the default is 0.
end_measure
Distance measured from the end point of a geometric segment to the start point of the linear feature. The default is the existing value (if any) in the measure dimension; otherwise, the default is the cartographic length of the segment.
Usage Notes
An exception is raised if geom_segment has an invalid geometry type or dimensionality, or if start_measure or end_measure is out of range.
All unassigned measures of the geometric segment will be populated automatically.
To store the resulting geometric segment (geom_segment) in the database, you must execute and UPDATE or INSERT statement, as appropriate.
The _3D format of this procedure (SDO_LRS.DEFINE_GEOM_SEGMENT_3D) is available. For information about _3D formats of LRS functions and procedures, see Section 6.4.
For more information about defining a geometric segment, see Section 6.5.1
Examples
DECLARE
BEGIN
-- Define the LRS segment for Route1. This will populate any null measures.
  dim_array,
-- Update and insert geometries into table, to display later.
UPDATE lrs_routes a SET a.route_geometry = geom_segment
   WHERE a.route_id = 1;
  11,
  'result_geom_1',
  result_geom_1
  12,
  'result_geom_2',
  result_geom_2
  13,
  'result_geom_3',
  result_geom_3
END;
Format
SDO_LRS.DYNAMIC_SEGMENT(
or
Description
Parameters
geom_segment
dim_array
start_measure
end_measure
Usage Notes
The direction and measures of the resulting geometric segment are preserved.
For more information about clipping a geometric segment, see Section 6.5.3
Examples
SELECT  SDO_LRS.DYNAMIC_SEGMENT(route_geometry, 5, 10)
SDO_LRS.DYNAMIC_SEGMENT(ROUTE_GEOMETRY,5,10)(SDO_GTYPE, SDO_SRID, SDO_POINT(X, Y
Format
SDO_LRS.FIND_LRS_DIM_POS(
Description
Parameters
table_name
column_name
Usage Notes
None.
Examples
The following example returns the position of the measure dimension within the SDO_DIM_ARRAY structure for geometries in the ROUTE_GEOMETRY column of the LRS_ROUTES table. (This example uses the definitions from the example in Section 6.6.)
SELECT SDO_LRS.FIND_LRS_DIM_POS('LRS_ROUTES', 'ROUTE_GEOMETRY') FROM DUAL;
SDO_LRS.FIND_LRS_DIM_POS('LRS_ROUTES','ROUTE_GEOMETRY')
                                                      3
Format
SDO_LRS.FIND_MEASURE(
or
Description
Parameters
geom_segment
Cartographic representation of a linear feature. This function returns the measure of the point on this segment that is closest to the projection point.
dim_array
point
Projection point. This function returns the measure of the point on geom_segment that is closest to the projection point.
Usage Notes
This function returns the measure of the point on geom_segment that is closest to the projection point. For example, if the projection point represents a shopping mall, the function could be used to find how far from the start of the highway is the point on the highway that is closest to the shopping mall.
An exception is raised if geom_segment_1 or geom_segment_2 has an invalid geometry type or dimensionality, or if geom_segment and point are based on different coordinate systems.
The _3D format of this function (SDO_LRS.FIND_MEASURE_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example finds the measure for the point on the geometric segment representing Route 1 that is closest to the point (10, 7). (This example uses the definitions from the example in Section 6.6.)
-- Find measure for point on segment closest to 10,7
-- Should return 15 (for point 12,7)
SELECT  SDO_LRS.FIND_MEASURE(a.route_geometry, m.diminfo,
  MDSYS.SDO_GEOMETRY(3001, NULL, NULL,
     MDSYS.SDO_ELEM_INFO_ARRAY(1, 1, 1),
     MDSYS.SDO_ORDINATE_ARRAY(10, 7, NULL)) )
   AND a.route_id = 1;
SDO_LRS.FIND_MEASURE(A.ROUTE_GEOMETRY,M.DIMINFO,MDSYS.SDO_GEOMETRY(3001,NULL,NUL
        15
Format
SDO_LRS.GEOM_SEGMENT_END_MEASURE(
Description
Parameters
geom_segment
Geometric segment whose end measure is to be returned.
dim_array
Usage Notes
This function returns the end measure of geom_segment.
An exception is raised if geom_segment has an invalid geometry type or dimensionality.
The _3D format of this function (SDO_LRS.GEOM_SEGMENT_END_MEASURE_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example returns the end measure of the geometric segment representing Route 1. (This example uses the definitions from the example in Section 6.6.)
SELECT  SDO_LRS.GEOM_SEGMENT_END_MEASURE(route_geometry)
SDO_LRS.GEOM_SEGMENT_END_MEASURE(ROUTE_GEOMETRY)
                                              27
Format
SDO_LRS.GEOM_SEGMENT_END_PT(
Description
Parameters
geom_segment
Geometric segment whose end point is to be returned.
dim_array
Usage Notes
This function returns the end point of geom_segment.
The _3D format of this function (SDO_LRS.GEOM_SEGMENT_END_PT_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example returns the end point of the geometric segment representing Route 1. (This example uses the definitions from the example in Section 6.6.)
SELECT  SDO_LRS.GEOM_SEGMENT_END_PT(route_geometry)
SDO_LRS.GEOM_SEGMENT_END_PT(ROUTE_GEOMETRY)(SDO_GTYPE, SDO_SRID, SDO_POINT(X, Y,
SDO_GEOMETRY(3301, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 1, 1), SDO_ORDINATE_ARRAY(
5, 14, 27))
Format
SDO_LRS.GEOM_SEGMENT_LENGTH(
Description
Parameters
geom_segment
Geometric segment whose length is to be calculated.
dim_array
Usage Notes
This function returns the length of geom_segment. The length is the geometric length, which is not the same as the total of the measure unit values. To determine how long a segment is in terms of measure units, subtract the result of an SDO_LRS.GEOM_SEGMENT_START_MEASURE operation from the result of an SDO_LRS.GEOM_SEGMENT_END_MEASURE operation.
SDO_LRS.GEOM_SEGMENT_LENGTH is an alias of the SDO_GEOM.SDO_LENGTH Spatial function.
The _3D format of this function (SDO_LRS.GEOM_SEGMENT_LENGTH_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example returns the length of the geometric segment representing Route 1. (This example uses the definitions from the example in Section 6.6.)
SELECT  SDO_LRS.GEOM_SEGMENT_LENGTH(route_geometry)
SDO_LRS.GEOM_SEGMENT_LENGTH(ROUTE_GEOMETRY)
                                         27
Format
SDO_LRS.GEOM_SEGMENT_START_MEASURE(
Description
Parameters
geom_segment
Geometric segment whose start measure is to be returned.
dim_array
Usage Notes
This function returns the start measure of geom_segment.
The _3D format of this function (SDO_LRS.GEOM_SEGMENT_START_MEASURE_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example returns the start measure of the geometric segment representing Route 1. (This example uses the definitions from the example in Section 6.6.)
SELECT  SDO_LRS.GEOM_SEGMENT_START_MEASURE(route_geometry)
SDO_LRS.GEOM_SEGMENT_START_MEASURE(ROUTE_GEOMETRY)
                                                 0
Format
SDO_LRS.GEOM_SEGMENT_START_PT(
Description
Parameters
geom_segment
Geometric segment whose start point is to be returned.
dim_array
Usage Notes
This function returns the start point of geom_segment.
The _3D format of this function (SDO_LRS.GEOM_SEGMENT_START_PT_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example returns the start point of the geometric segment representing Route 1. (This example uses the definitions from the example in Section 6.6.)
SELECT  SDO_LRS.GEOM_SEGMENT_START_PT(route_geometry)
SDO_LRS.GEOM_SEGMENT_START_PT(ROUTE_GEOMETRY)(SDO_GTYPE, SDO_SRID, SDO_POINT(X,
2, 2, 0))
SDO_LRS.GET_MEASURE
Format
SDO_LRS.GET_MEASURE(
Description
Parameters
point
Point whose measure is to be returned.
dim_array
Dimensional information array corresponding to point, usually selected from one of the xxx_SDO_GEOM_METADATA views.
Usage Notes
This function returns the measure of an LRS point.
If point is not valid, an "invalid LRS point" exception is raised.
Contrast this function with SDO_LRS.PROJECT_PT, which accepts as input a point that is not necessarily on the geometric segment, but which returns a point that is on the geometric segment, as opposed to a measure value. As the following example shows, the SDO_LRS.GET_MEASURE function can be used to return the measure of the projected point returned by SDO_LRS.PROJECT_PT.
The _3D format of this function (SDO_LRS.GET_MEASURE_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example returns the measure of a projected point. In this case, the point resulting from the projection is 9 units from the start of the segment.
SQL> SELECT SDO_LRS.GET_MEASURE(
   SDO_LRS.PROJECT_PT(a.route_geometry, m.diminfo,
       MDSYS.SDO_ORDINATE_ARRAY(9, 3, NULL)) ),
   m.diminfo )
       AND a.route_id = 1;
SDO_LRS.GET_MEASURE(SDO_LRS.PROJECT_PT(A.ROUTE_GEOMETRY,M.DIMINFO,MDSYS.SDO_GEOM
        9
SDO_LRS.IS_GEOM_SEGMENT_DEFINED
Format
SDO_LRS.IS_GEOM_SEGMENT_DEFINED(
Description
Checks if an LRS segment is defined correctly.
Parameters
geom_segment
Geometric segment to be checked.
dim_array
Usage Notes
This function returns TRUE if geom_segment is defined correctly and FALSE if geom_segment is not defined correctly.
The start and end measures of geom_segment must be defined (cannot be null), and any measures assigned must be in an ascending or descending order along the segment direction.
The _3D format of this function (SDO_LRS.IS_GEOM_SEGMENT_DEFINED_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
See also the SDO_LRS.VALID_GEOM_SEGMENT function.
Examples
The following example checks if the geometric segment representing Route 1 is defined. (This example uses the definitions from the example in Section 6.6.)
SELECT  SDO_LRS.IS_GEOM_SEGMENT_DEFINED(route_geometry)
SDO_LRS.IS_GEOM_SEGMENT_DEFINED(ROUTE_GEOMETRY)
TRUE
SDO_LRS.IS_MEASURE_DECREASING
Format
SDO_LRS.IS_MEASURE_DECREASING(
Description
Checks if the measure values along an LRS segment are decreasing (that is, descending in numerical value).
Parameters
geom_segment
dim_array
Usage Notes
This function returns TRUE if the measure values along an LRS segment are decreasing and FALSE if the measure values along an LRS segment are not decreasing.
The start and end measures of geom_segment must be defined (cannot be null).
The _3D format of this function (SDO_LRS.IS_MEASURE_DECREASING_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
See also the SDO_LRS.IS_MEASURE_INCREASING function.
Examples
The following example checks if the measure values along the geometric segment representing Route 1 are decreasing. (This example uses the definitions from the example in Section 6.6.)
SELECT SDO_LRS.IS_MEASURE_DECREASING(a.route_geometry, m.diminfo)
   AND a.route_id = 1;
SDO_LRS.IS_MEASURE_DECREASING(A.ROUTE_GEOMETRY,M.DIMINFO)
FALSE
Format
SDO_LRS.IS_MEASURE_INCREASING(
Description
Checks if the measure values along an LRS segment are increasing (that is, ascending in numerical value).
Parameters
geom_segment
dim_array
Usage Notes
This function returns TRUE if the measure values along an LRS segment are increasing and FALSE if the measure values along an LRS segment are not increasing.
The _3D format of this function (SDO_LRS.IS_MEASURE_INCREASING_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
See also the SDO_LRS.IS_MEASURE_DECREASING function.
Examples
The following example checks if the measure values along the geometric segment representing Route 1 are increasing. (This example uses the definitions from the example in Section 6.6.)
SELECT SDO_LRS.IS_MEASURE_INCREASING(a.route_geometry, m.diminfo)
   AND a.route_id = 1;
SDO_LRS.IS_MEASURE_INCREASING(A.ROUTE_GEOMETRY,M.DIMINFO)
TRUE
SDO_LRS.LOCATE_PT
Format
SDO_LRS.LOCATE_PT(
or
SDO_LRS.LOCATE_PT(
Description
Returns the point located at a specified distance from the start of a geometric segment.
Parameters
geom_segment
Geometric segment to be checked to see if it falls within the measure range of measure.
dim_array
measure
Distance to measure from the start point of geom_segment.
offset
Distance to measure perpendicularly from the point that is located at measure units from the start point of geom_segment. The default is 0 (that is, the point is on geom_segment).
Usage Notes
This function returns the referenced point.
The unit of measurement for offset is the same as for the coordinate system associated with geom_segment. For geodetic data, the default unit of measurement is meters.
With geodetic data using the WGS 84 coordinate system, this function can be used to return the longitude and latitude coordinates of any point on or offset from the segment.
An exception is raised if geom_segment has an invalid geometry type or dimensionality, or if the location is out of range.
The _3D format of this function (SDO_LRS.LOCATE_PT_3D) is available; however, the offset parameter is not available for SDO_LRS.LOCATE_PT_3D. For information about _3D formats of LRS functions, see Section 6.4.
For more information about locating a point on a geometric segment, see Section 6.5.8.
Examples
The following example returns the point at measure 9 and on (that is, offset 0) the geometric segment representing Route 1. (This example uses the definitions from the example in Section 6.6.)
SELECT  SDO_LRS.LOCATE_PT(route_geometry, 9, 0)
SDO_LRS.LOCATE_PT(ROUTE_GEOMETRY,9,0)(SDO_GTYPE, SDO_SRID, SDO_POINT(X, Y, Z), S
9, 4, 9))
Format
SDO_LRS.MEASURE_RANGE(
Description
Parameters
geom_segment
dim_array
Usage Notes
This function subtracts the start measure of geom_segment from the end measure of geom_segment.
The _3D format of this function (SDO_LRS.MEASURE_RANGE_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example returns the measure range of the geometric segment representing Route 1. (This example uses the definitions from the example in Section 6.6.)
SELECT SDO_LRS.MEASURE_RANGE(route_geometry)
SDO_LRS.MEASURE_RANGE(ROUTE_GEOMETRY)
                                   27
Format
SDO_LRS.MEASURE_TO_PERCENTAGE(
or
Description
Parameters
geom_segment
dim_array
measure
Measure value. This function returns the percentage that this measure value is of the measure range.
Usage Notes
This function returns a number (0 to 100) that is the percentage of the measure range that the specified measure represents. (The measure range is the end measure minus the start measure.) For example, if the measure range of geom_segment is 50 and measure is 20, the function returns 40 (because 20/50 = 40%).
This function performs the reverse of the SDO_LRS.PERCENTAGE_TO_MEASURE function, which returns the measure that corresponds to a percentage value.
An exception is raised if geom_segment or measure is invalid.
Examples
The following example returns the percentage that 5 is of the measure range of geometric segment representing Route 1. (This example uses the definitions from the example in Section 6.6.) The measure range of this segment is 27, and 5 is approximately 18.5 percent of 27.
SELECT SDO_LRS.MEASURE_TO_PERCENTAGE(a.route_geometry, m.diminfo, 5)
    AND a.route_id = 1;
SDO_LRS.MEASURE_TO_PERCENTAGE(A.ROUTE_GEOMETRY,M.DIMINFO,5)
                                                 18.5185185
Format
SDO_LRS.OFFSET_GEOM_SEGMENT(
or
or
Description
Parameters
geom_segment
dim_array
start_measure
Start measure of geom_segment at which to start the offset operation.
end_measure
End measure of geom_segment at which to start the offset operation.
offset
Distance to measure perpendicularly from the points along geom_segment. Positive offset values are to the left of geom_segment; negative offset values are to the right of geom_segment.
tolerance
unit
Unit of measurement specification: a quoted string with one or both of the following keywords:
For example: 'unit=km arc_tolerance=0.05'
If the input geometry is geodetic data, this parameter is required, and arc_tolerance must be specified. If the input geometry is Cartesian or projected data, arc_tolerance has no effect and should not be specified.
If this parameter is not specified for a Cartesian or projected geometry, or if the arc_tolerance keyword is specified for a geodetic geometry but the unit keyword is not specified, the unit of measurement associated with the data is assumed.
Usage Notes
The geometry type of geom_segment must be line or multiline. For example, it cannot be a polygon.
Examples
The following example returns the geometric segment 2 distance units to the left (positive offset 2) of the segment from measures 5 through 10 of Route 1. (This example uses the definitions from the example in Section 6.6.)
-- Create a segment offset 2 to the left from measures 5 through 10.
-- First, display the original segment; then, offset.
SELECT a.route_geometry FROM lrs_routes a WHERE a.route_id = 1;
ROUTE_GEOMETRY(SDO_GTYPE, SDO_SRID, SDO_POINT(X, Y, Z), SDO_ELEM_INFO, SDO_ORDIN
2, 2, 0, 2, 4, 2, 8, 4, 8, 12, 4, 12, 12, 10, 18, 8, 10, 22, 5, 14, 27))
SELECT  SDO_LRS.OFFSET_GEOM_SEGMENT(a.route_geometry, m.diminfo, 5, 10, 2)
      AND a.route_id = 1;
SDO_LRS.OFFSET_GEOM_SEGMENT(A.ROUTE_GEOMETRY,M.DIMINFO,5,10,2)(SDO_GTYPE, SDO_SR
5, 6, 5, 10, 6, 10))
Note in SDO_ORDINATE_ARRAY of the returned segment that the Y values (6) are
2 greater than the Y values (4) of the relevant part of the original segment.
Format
SDO_LRS.PERCENTAGE_TO_MEASURE(
or
Description
Parameters
geom_segment
dim_array
percentage
Percentage value. Must be from 0 to 100. This function returns the measure value corresponding to this percentage of the measure range.
Usage Notes
This function returns the measure value corresponding to this percentage of the measure range. (The measure range is the end measure minus the start measure.) For example, if the measure range of geom_segment is 50 and percentage is 40, the function returns 20 (because 40% of 50 = 20).
This function performs the reverse of the SDO_LRS.MEASURE_TO_PERCENTAGE function, which returns the percentage value that corresponds to a measure.
An exception is raised if geom_segment has an invalid geometry type or dimensionality, or if percentage is less than 0 or greater than 100.
Examples
The following example returns the measure that is 50 percent of the measure range of geometric segment representing Route 1. (This example uses the definitions from the example in Section 6.6.) The measure range of this segment is 27, and 50 percent of 17 is 13.5.
SELECT SDO_LRS.PERCENTAGE_TO_MEASURE(a.route_geometry, m.diminfo, 50)
    AND a.route_id = 1;
SDO_LRS.PERCENTAGE_TO_MEASURE(A.ROUTE_GEOMETRY,M.DIMINFO,50)
                                                        13.5
SDO_LRS.PROJECT_PT
Format
SDO_LRS.PROJECT_PT(
or
SDO_LRS.PROJECT_PT(
Description
Parameters
geom_segment
dim_array
point
Point to be projected.
point_dim_array
Usage Notes
This function returns the projection point (including its measure) of a specified point (point). The projection point is on the geometric segment.
If multiple projection points exist, the first projection point encountered from the start point is returned.
An exception is raised if geom_segment or point has an invalid geometry type or dimensionality, or if geom_segment and point are based on different coordinate systems.
The _3D format of this function (SDO_LRS.PROJECT_PT_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
For more information about projecting a point onto a geometric segment, see Section 6.5.9.
Examples
The following example returns the point (9,4,9) on the geometric segment representing Route 1 that is closest to the specified point (9,3,NULL). (This example uses the definitions from the example in Section 6.6.)
-- Point 9,3,NULL is off the road; should return 9,4,9
SELECT  SDO_LRS.PROJECT_PT(route_geometry,
  MDSYS.SDO_GEOMETRY(3301, NULL, NULL,
SDO_LRS.PROJECT_PT(ROUTE_GEOMETRY,MDSYS.SDO_GEOMETRY(3301,NULL,NULL,MDSYS.SDO_EL
9, 4, 9))
Format
SDO_LRS.REDEFINE_GEOM_SEGMENT(
or
Description
Populates the measures of all shape points based on the start and end measures of a geometric segment, overriding any previously assigned measures between the start point and end point.
Parameters
geom_segment
dim_array
start_measure
end_measure
Usage Notes
The _3D format of this procedure (SDO_LRS.REDEFINE_GEOM_SEGMENT_3D) is available. For information about _3D formats of LRS functions and procedures, see Section 6.4.
For more information about redefining a geometric segment, see Section 6.5.2.
Examples
The following example redefines a geometric segment, effectively converting miles to kilometers in the measure values. (This example uses the definitions from the example in Section 6.6.)
-- First, display the original segment; then, redefine.
-- Redefine geom segment to "convert" miles to kilometers.
DECLARE
BEGIN
-- "Convert" mile measures to kilometers (27 * 1.609 = 43.443).
SDO_LRS.REDEFINE_GEOM_SEGMENT (geom_segment,
  dim_array,
   43.443);  -- End of LRS segment. 27 miles = 43.443 kilometers.
END;
-- Display the redefined segment, with all measures "converted".
2, 2, 0, 2, 4, 3.218, 8, 4, 12.872, 12, 4, 19.308, 12, 10, 28.962, 8, 10, 35.398
, 5, 14, 43.443))
SDO_LRS.RESET_MEASURE
Format
SDO_LRS.RESET_MEASURE(
Description
Sets all measures of a geometric segment, including the start and end measures, to null values, overriding any previously assigned measures.
Parameters
geom_segment
dim_array
Usage Notes
Examples
The following example sets all measures of a geometric segment to null values. (This example uses the definitions from the example in Section 6.6.)
-- Reset geom segment measures.
DECLARE
BEGIN
SDO_LRS.RESET_MEASURE (geom_segment);
END;
-- Display the segment, with all measures set to null.
2, 2, NULL, 2, 4, NULL, 8, 4, NULL, 12, 4, NULL, 12, 10, NULL, 8, 10, NULL, 5, 1
4, NULL))
Format
SDO_LRS.REVERSE_GEOMETRY(
Description
Parameters
geom_segment
dim_array
Usage Notes
This function:
Compare this function with SDO_LRS.REVERSE_MEASURE, which reverses only the measure values (not the direction) of a geometric segment.
An exception is raised if geom_segment has an invalid geometry type or dimensionality. The geometry type must be a line or multiline, and the dimensionality must be 3 (two dimensions plus the measure dimension).
The _3D format of this function (SDO_LRS.REVERSE_GEOMETRY_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example reverses the measure values and the direction of the geometric segment representing route 1. (This example uses the definitions from the example in Section 6.6.)
-- Reverse direction and measures (for example, to prepare for
-- concatenating with another road)
-- First, display the original segment; then, reverse.
SELECT  SDO_LRS.REVERSE_GEOMETRY(a.route_geometry, m.diminfo)
      AND a.route_id = 1;
SDO_LRS.REVERSE_GEOMETRY(A.ROUTE_GEOMETRY,M.DIMINFO)(SDO_GTYPE, SDO_SRID, SDO_PO
5, 14, 27, 8, 10, 22, 12, 10, 18, 12, 4, 12, 8, 4, 8, 2, 4, 2, 2, 2, 0))
Note in the returned segment that the M values (measures) now go in descending order from 27 to 0, and the segment start and end points have the opposite X and Y values as in the original segment (5,14 and 2,2 here, as opposed to 2,2 and 5,14 in the original).
Format
SDO_LRS.REVERSE_MEASURE(
Description
Returns a new geometric segment by reversing the measure values, but not the direction, of the original geometric segment.
Parameters
geom_segment
dim_array
Usage Notes
This function:
Compare this function with SDO_LRS.REVERSE_GEOMETRY, which reverses both the direction and the measure values of a geometric segment.
The _3D format of this function (SDO_LRS.REVERSE_MEASURE_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
The behavior of the SDO_LRS.REVERSE_MEASURE function changed between Release 8.1.7 and the current release. In Release 8.1.7, REVERSE_MEASURE reversed both the measures and the segment direction. However, if you want to have this same behavior with the current release, you must use the SDO_LRS.REVERSE_GEOMETRY function.
Examples
The following example reverses the measure values of the geometric segment representing route 1, but does not affect the direction. (This example uses the definitions from the example in Section 6.6.)
SELECT SDO_LRS.REVERSE_MEASURE(a.route_geometry, m.diminfo)
    AND a.route_id = 1;
SDO_LRS.REVERSE_MEASURE(A.ROUTE_GEOMETRY,M.DIMINFO)(SDO_GTYPE, SDO_SRID, SDO_POI
2, 2, 27, 2, 4, 25, 8, 4, 19, 12, 4, 15, 12, 10, 9, 8, 10, 5, 5, 14, 0))
Note in the returned segment that the M values (measures) now go in descending order from 27 to 0, but the segment start and end points have the same X and Y values as in the original segment (2,2 and 5,14).
Format
SDO_LRS.SCALE_GEOM_SEGMENT(
or
Description
Returns the geometry object resulting from the scaling of a geometric segment.
Parameters
geom_segment
Geometric segment to be scaled.
dim_array
start_measure
Start measure of the scaled geometric segment.
end_measure
End measure of the scaled geometric segment.
shift_measure
Shift measure of the scaled geometric segment.
Usage Notes
This function performs a general scaling operation to the geometric segment. The new start and end measures are assigned, and all measures are populated by a linear mapping between old and new start and end measures. The shift measure is applied to the segment after scaling.
This general-purpose function has been deprecated and will not be supported in a future release of Spatial. You should instead use other functions for specific purposes, as described in Table 15-4
Table 15-4 lists some common tasks and the suggested functions to use instead of SCALE_GEOM_SEGMENT.
Table 15-4 Functions to Use Instead of SCALE_GEOM_SEGMENT
Task  Suggested Function
Shift all measures by a specified amount (for example, to accommodate new construction at the start of a road that causes the original start point to be n measure units beyond the new start point).
Reverse the direction of a segment (for example, to allow one road segment to be concatenated with another coming from the opposite direction, because both segments to be concatenated must have the same direction).
Scale the measure information without performing a shift (for example, to change the measures from miles to kilometers).
For more information about scaling a geometric segment, see Section 6.5.6.
Examples
The following examples illustrate some SCALE_GEOM_ELEMENT uses. (These examples use the definitions from the example in Section 6.6.)
-- Shift by 5 (for example, 5-mile segment added before original start)
SELECT  SDO_LRS.SCALE_GEOM_SEGMENT(a.route_geometry, m.diminfo, 0, 27, 5)
      AND a.route_id = 1;
SDO_LRS.SCALE_GEOM_SEGMENT(A.ROUTE_GEOMETRY,M.DIMINFO,0,27,5)(SDO_GTYPE, SDO_SRI
2, 2, 5, 2, 4, 7, 8, 4, 13, 12, 4, 17, 12, 10, 23, 8, 10, 27, 5, 14, 32))
SELECT  SDO_LRS.SCALE_GEOM_SEGMENT(route_geometry, 0, 43.443, 0)
SDO_LRS.SCALE_GEOM_SEGMENT(ROUTE_GEOMETRY,0,43.443,0)(SDO_GTYPE, SDO_SRID, SDO_P
, 5, 14, 43.443))
SDO_LRS.SET_PT_MEASURE
Format
SDO_LRS.SET_PT_MEASURE(
or
or
or
Description
Sets the measure value of a specified point.
Parameters
geom_segment
Geometric segment containing the point.
dim_array
Dimensional information array corresponding to geom_segment (in the second format) or point (in the fourth format), usually selected from one of the xxx_SDO_GEOM_METADATA views.
point
Point for which the measure value is to be set.
pt_dim_array
Dimensional information array corresponding to point (in the second format), usually selected from one of the xxx_SDO_GEOM_METADATA views.
measure
Measure value to be assigned to the specified point.
Usage Notes
The function returns TRUE if the measure value was successfully set, and FALSE if the measure value was not set.
If both geom_segment and point are specified, the behavior of the procedure depends on whether or not point is a shape point on geom_segment:
The _3D format of this function (SDO_LRS.SET_PT_MEASURE_3D) is available; however, only the formats that include the geom_segment parameter are available for SDO_LRS.SET_PT_MEASURE_3D. For information about _3D formats of LRS functions, see Section 6.4.
An exception is raised if geom_segment or point is invalid.
Examples
The following example sets the measure value of point (8,10) to 20. (This example uses the definitions from the example in Section 6.6.)
-- Set the measure value of point 8,10 to 20 (originally 22).
DECLARE
result VARCHAR2(32);
BEGIN
result := SDO_LRS.SET_PT_MEASURE (geom_segment,
     MDSYS.SDO_ORDINATE_ARRAY(8, 10, 22)),
  20);
-- Display the result.
DBMS_OUTPUT.PUT_LINE('Returned value = ' || result);
END;
Returned value = TRUE
Format
or
Description
Splits a geometric segment into two geometric segments. (This is a procedure, not a function.)
Parameters
geom_segment
Geometric segment to be split.
dim_array
split_measure
Distance measured from the start point of a geometric segment to the split point.
segment_1
First geometric segment: from the start point of geom_segment to the split point.
segment_2
Second geometric segment: from the split point to the end point of geom_segment.
Usage Notes
An exception is raised if geom_segment or split_measure is invalid.
The directions and measures of the resulting geometric segments are preserved.
The _3D format of this procedure (SDO_LRS.SPLIT_GEOM_SEGMENT_3D) is available. For information about _3D formats of LRS functions and procedures, see Section 6.4.
For more information about splitting a geometric segment, see Section 6.5.4.
Examples
DECLARE
BEGIN
  dim_array,
  11,
  'result_geom_1',
  result_geom_1
  12,
  'result_geom_2',
  result_geom_2
  13,
  'result_geom_3',
  result_geom_3
END;
Format
SDO_LRS.TRANSLATE_MEASURE(
or
Description
Parameters
geom_segment
dim_array
translate_m
Usage Notes
This function adds translate_m to the start and end measures of geom_segment. For example, if geom_segment has a start measure of 50 and an end measure of 100, and if translate_m is 10, the returned geometric segment has a start measure of 60 and an end measure of 110, as shown in Figure 15-1.
Figure 15-1 Translating a Geometric Segment
Illustration of translating a geometric segment. In this case, 10 is added to the start and end measures.
The _3D format of this function (SDO_LRS.TRANSLATE_MEASURE_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example translates (shifts) by 10 the geometric segment representing Route 1. (This example uses the definitions from the example in Section 6.6.)
SELECT SDO_LRS.TRANSLATE_MEASURE(a.route_geometry, m.diminfo, 10)
    AND a.route_id = 1;
SDO_LRS.TRANSLATE_MEASURE(A.ROUTE_GEOMETRY,M.DIMINFO,10)(SDO_GTYPE, SDO_SRID, SD
2, 2, 10, 2, 4, 12, 8, 4, 18, 12, 4, 22, 12, 10, 28, 8, 10, 32, 5, 14, 37))
Format
SDO_LRS.VALID_GEOM_SEGMENT(
Description
Checks if a geometry object is a valid geometric segment.
Parameters
geom_segment
Geometric segment to be checked for validity.
dim_array
Usage Notes
This function returns TRUE if geom_segment is valid and FALSE if geom_segment is not valid.
Measure information is assumed to be stored in the last element of the SDO_DIM_ARRAY in the Oracle Spatial metadata.
This function only checks for geometry type and number of dimensions of the geometric segment. To further validate measure information, use the IS_GEOM_SEGMENT_DEFINED function.
The _3D format of this function (SDO_LRS.VALID_GEOM_SEGMENT_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example checks if the geometric segment representing Route 1 is valid. (This example uses the definitions from the example in Section 6.6.)
SELECT  SDO_LRS.VALID_GEOM_SEGMENT(route_geometry)
SDO_LRS.VALID_GEOM_SEGMENT(ROUTE_GEOMETRY)
TRUE
Format
SDO_LRS.VALID_LRS_PT(
Description
Parameters
point
Point to be checked for validity.
dim_array
Usage Notes
This function returns TRUE if point is valid and FALSE if point is not valid.
This function checks if point is a point with measure information, and it checks for the geometry type and number of dimensions for the point geometry.
Ordinate information needs to be stored in SDO_ELEM_INFO_ARRAY and SDO_ORDINATE_ARRAY. The SDO_POINT field in the SDO_GEOMETRY definition of the point should not be used for LRS points, because SDO_POINT supports the definition of only three attributes (X, Y, Z).
The _3D format of this function (SDO_LRS.VALID_LRS_PT_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example checks if point (9,3,NULL) is a valid LRS point. (This example uses the definitions from the example in Section 6.6.)
SELECT  SDO_LRS.VALID_LRS_PT(
       MDSYS.SDO_ORDINATE_ARRAY(9, 3, NULL)),
    m.diminfo)
      AND a.route_id = 1;
SDO_LRS.VALID_LRS_PT(MDSYS.SDO_GEOMETRY(3001,NULL,NULL,MDSYS.SDO_ELEM_INFO_ARRAY
TRUE
Format
SDO_LRS.VALID_MEASURE(
or
Description
Parameters
geom_segment
dim_array
measure
Geometric segment to be checked to see if geom_segment falls within its measure range.
Usage Notes
This function returns TRUE if measure falls within the measure range of geom_segment and FALSE if measure does not fall within the measure range of geom_segment.
The _3D format of this function (SDO_LRS.VALID_MEASURE_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example checks if 50 is a valid measure on the Route 1 segment. The function returns FALSE because the measure range for that segment is 0 to 27. For example, if the route is 27 miles long and there is a mile marker at one-mile intervals, there is no 50-mile marker because the last marker is the 27-mile marker. (This example uses the definitions from the example in Section 6.6.)
SELECT  SDO_LRS.VALID_MEASURE(route_geometry, 50)
SDO_LRS.VALID_MEASURE(ROUTE_GEOMETRY,50)
FALSE
SDO_LRS.VALIDATE_LRS_GEOMETRY
Format
SDO_LRS.VALIDATE_LRS_GEOMETRY(
Description
Checks if an LRS geometry is valid.
Parameters
geom_segment
dim_array
Usage Notes
This function returns TRUE if geom_segment is valid and one of the following error codes if geom_segment is not valid:
The _3D format of this function (SDO_LRS.VALIDATE_LRS_GEOMETRY_3D) is available. For information about _3D formats of LRS functions, see Section 6.4.
Examples
The following example checks if the Route 1 segment is a valid LRS geometry. (This example uses the definitions from the example in Section 6.6.)
SELECT SDO_LRS.VALIDATE_LRS_GEOMETRY(a.route_geometry, m.diminfo)
   AND a.route_id = 1;
SDO_LRS.VALIDATE_LRS_GEOMETRY(A.ROUTE_GEOMETRY,M.DIMINFO)
TRUE
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Library
Product
Contents
Index
