Oracle Spatial User's Guide and Reference
Release 9.0.1
Part Number A88805-01
Library
Product
Contents
Index
Go to previous page Go to next page
9
SQL Statements for Indexing
This chapter describes the statements used when working with the spatial object data type. The statements are listed in Table 9-1.
Table 9-1 Spatial Index Creation and Usage Statements
Statement  Description
ALTER INDEX
Alters a spatial index on a column of type MDSYS.SDO_GEOMETRY.
ALTER INDEX REBUILD
Rebuilds a spatial index on a column of type MDSYS.SDO_GEOMETRY.
ALTER INDEX RENAME TO
Changes the name of a spatial index on a column of type MDSYS.SDO_GEOMETRY.
CREATE INDEX
Creates a spatial index on a column of type MDSYS.SDO_GEOMETRY.
DROP INDEX
Deletes a spatial index on a column of type MDSYS.SDO_GEOMETRY
This chapter focuses on using these SQL statements with spatial indexes. For complete reference information about any statement, see the Oracle9i SQL Reference.
ALTER INDEX
Purpose
Alters specific parameters for a spatial index or rebuilds a spatial index.
Syntax
ALTER INDEX [schema.]index PARAMETERS (`index_params [physical_storage_params]' );
Keywords and Parameters
INDEX_PARAMS
Allows you to change the characteristics of the spatial index, and the type (fixed or hybrid) of a quadtree index.
Keyword
Description
add_index
Specifies the name of the new index table to add.
Data type is VARCHAR2.
delete_index
Specifies the name of the index table to delete. You can only delete index tables that were created with the ALTER INDEX add_index statement. The primary index table cannot be deleted with this parameter. To delete the primary index table, use the DROP INDEX statement.
sdo_commit_interval
Specifies the number of underlying table rows that are processed between commit intervals for the index data. (Quadtree indexes only.) The default behavior commits the index data only after all rows in the underlying table have been processed. See the Usage Notes for further details.
Data type is NUMBER.
sdo_indx_dims
Specifies the number of dimensions to be indexed. (R-tree indexes only.) For example, a value of 2 causes the first 2 dimensions to be indexed. Must be less than or equal to the number of actual dimensions (number of SDO_DIM_ELEMENT instances in the dimensional array that describes the geometry objects in the column).
Data type is NUMBER. Default = number of actual dimensions.
sdo_level
Specifies the desired fixed-size tiling level. (Quadtree indexes only.)
sdo_numtiles
Specifies the number of variable-sized tiles to be used in tessellating an object. (Quadtree indexes only.)
sdo_rtr_pctfree
Specifies the minimum percentage of slots in each index tree node to be left empty when the index is created. Slots that are left empty can be filled later when new data is inserted into the table. (R-tree indexes only.) The value can range from 0 to 50. The default value is best for most applications; however, a value of 0 is recommended if no updates will be performed to the geometry column.
Data type is NUMBER. Default = 10.
PHYSICAL_STORAGE_PARAMS
Determines the storage parameters used for altering the spatial index data table. A spatial index data table is a standard Oracle table with a prescribed format. Not all physical storage parameters that are allowed in the STORAGE clause of a CREATE TABLE statement are supported. The following is a list of the supported subset.
Keyword
Description
tablespace
Specifies the tablespace in which the index data table is created. This parameter is the same as TABLESPACE in the STORAGE clause of a CREATE TABLE statement.
initial
Is the same as INITIAL in the STORAGE clause of a CREATE TABLE statement.
next
Is the same as NEXT in the STORAGE clause of a CREATE TABLE statement.
minextents
Is the same as MINEXTENTS in the STORAGE clause of a CREATE TABLE statement.
maxextents
Is the same as MAXEXTENTS in the STORAGE clause of a CREATE TABLE statement.
pctincrease
Is the same as PCTINCREASE in the STORAGE clause of a CREATE TABLE statement.
btree_initial
Is the same as INITIAL in the STORAGE clause of a CREATE INDEX statement in the case of a standard B-tree index. (Quadtree indexes only.)
btree_next
Is the same as NEXT in the STORAGE clause of a CREATE INDEX statement in the case of a standard B-tree index. (Quadtree indexes only.)
btree_pctincrease
Is the same as PCTINCREASE in the STORAGE clause of a CREATE INDEX statement in the case of a standard B-tree index. (Quadtree indexes only.)
Prerequisites
Usage Notes
This statement is used to change the parameters of an existing index. This is the only way you can add or build multiple indexes on the same column.
See the Usage Notes for the CREATE INDEX statement for usage information about many of the available parameters.
Examples
The following example adds a new index table named FIXED_INDEX$ to the index named QTREE.
ALTER INDEX qtree PARAMETERS ('add_index=fixed_index$
                               sdo_level=8
                               initial=100M
                               next=1M
                               pctincrease=0
                               btree_initial=5M
                               btree_next=1M
                               btree_pctincrease=0');
The following example modifies the tablespace and the SDO_LEVEL value for partition IP2 of the spatial index named BGI.
ALTER INDEX bgi MODIFY PARTITION ip2
   PAREMETERS ('tablespace=SYSTEM sdo_level=4');
Related Topics
ALTER INDEX REBUILD
Syntax
ALTER INDEX [schema.]index REBUILD
[PARAMETERS (`rebuild_params [physical_storage_params]' ) ] ;
ALTER INDEX [schema.]index REBUILD PARTITION partition
Purpose
Rebuilds a spatial index or a specified partition of a partitioned index.
REBUILD_PARAMS
Specifies in a command string the index parameters to use in rebuilding the spatial index.
Keyword
Description
layer_gtype
Checks to ensure that all geometries are of a specified geometry type. The value must be from the Geometry Type column of Table 2-1 in Section 2.2.1. In addition, for a quadtree index specifying POINT, allows for optimized processing of point data.
rebuild_index
Specifies the name of the spatial index table to be rebuilt.
sdo_commit_interval
sdo_indx_dims
sdo_level
sdo_numtiles
sdo_rtr_pctfree
Determines the storage parameters used for rebuilding the spatial index data table. A spatial index data table is a regular Oracle table with a prescribed format. Not all physical storage parameters that are allowed in the STORAGE clause of a CREATE TABLE statement are supported. The following is a list of the supported subset.
Keyword
Description
tablespace
Specifies the tablespace in which the index data table is created. Same as TABLESPACE in the STORAGE clause of a CREATE TABLE statement.
initial
next
minextents
maxextents
pctincrease
btree_initial
btree_next
btree_pctincrease
Prerequisites
Usage Notes
An ALTER INDEX REBUILD `rebuild_params' statement rebuilds the index using supplied parameters. Spatial index creation involves creating and inserting index data, for each row in the underlying table column being spatially indexed, into a table with a prescribed format. The default, or normal, operation is that all rows in the underlying table are processed before the insertion of index data is committed. This requires adequate rollback segment space.
You may choose to commit index data after every n rows of the underlying table have been processed. This is done by specifying SDO_COMMIT_INTERVAL = n. The potential complication is that, if there is an error during index rebuild and if periodic commit operations have taken place, then the spatial index will be in an inconsistent state. The only recovery option is to use DROP INDEX (possibly with the FORCE option) and CREATE INDEX statements after ensuring that the various tablespaces are the required size and any other error conditions have been removed.
This statement does not use any previous parameters from the index creation. All parameters should be specified for the index you want to rebuild.
For more information about using the layer_gtype keyword to constrain data in a layer to a geometry type, see Section 4.1.4.
With a partitioned spatial index, you must use a separate ALTER INDEX REBUILD statement for each partition to be rebuilt.
See also the Usage Notes for the CREATE INDEX statement for usage information about many of the available parameters.
Examples
The following example rebuilds OLDINDEX with an SDO_LEVEL value of 12.
ALTER INDEX oldindex REBUILD PARAMETERS('sdo_level=12');
Related Topics
Syntax
ALTER INDEX [schema.]index RENAME TO <new_index_name>;
ALTER INDEX [schema.]index PARTITION partition RENAME TO <new_partition_name>;
Purpose
Alters the name of a spatial index or a partition of a spatial index.
new_index_name
Specifies the new name of the index.
new_partition_name
Specifies the new name of the partition.
Prerequisites
Usage Notes
None.
Examples
The following example renames OLDINDEX to NEWINDEX.
ALTER INDEX oldindex RENAME TO newindex;
Related Topics
CREATE INDEX
Syntax
CREATE INDEX [schema.]<index_name> ON [schema.]<tableName> (column)
INDEXTYPE IS MDSYS.SPATIAL_INDEX
[PARAMETERS `index_params [physical_storage_params]']);
Purpose
INDEX_PARAMS
Determine the type (R-tree or quadtree; and for quadtree, fixed or hybrid) and the characteristics of the spatial index.
Keyword
Description
geodetic
For a quadtree index, 'geodetic=FALSE' allows geodetic data to be built on geodetic data, but with restrictions. (FALSE is the only acceptable value for this keyword.) Do not use this keyword with an R-tree index. See the Usage Notes for further details.
layer_gtype
sdo_commit_interval
sdo_indx_dims
sdo_level
sdo_numtiles
sdo_rtr_pctfree
Determines the storage parameters used for creating the spatial index data table. A spatial index data table is a regular Oracle table with a prescribed format. Not all physical_storage_params that are allowed in the STORAGE clause of a CREATE TABLE statement are supported. The following is a list of the supported subset.
Keyword
Description
tablespace
initial
next
minextents
maxextents
pctincrease
btree_initial
btree_next
btree_pctincrease
Prerequisites
Usage Notes
For information about R-tree and quadtree indexes, see Section 1.7.
By default, an R-tree index is created if the index_params string does not contain the sdo_level keyword or if the sdo_level value is zero (0). If the index_params string contains the sdo_level keyword with a non-zero value, a quadtree index is created. Some keywords apply only to R-tree or quadtree indexes, as noted in the Keywords and Parameters section.
Before you create an R-tree index, be sure that the rollback segment size and the SORT_AREA_SIZE parameter value are adequate, as described in Section 4.1.1.
For a quadtree index, the index_params string must contain either sdo_level or both sdo_level and sdo_numtiles, and any values specified for these parameters must be valid.
With an R-tree index on linear referencing system (LRS) data, the sdo_indx_dims parameter must be used and must specify the number of dimensions minus one, so as not to index the measure dimension. For example, if the dimensions are X, Y, and M, specify sdo_indx_dims=2 to index only the X and Y dimensions, and not the measure (M) dimension. (The LRS data model, including the measure dimension, is explained in Section 6.2.)
A partitioned spatial index can be created on a partitioned table. See Section 4.1.6 for more information about partitioned spatial indexes, including benefits and restrictions.
Other options available for regular indexes (such as ASC and DESC) are not applicable for spatial indexes.
Default values for quadtree indexing:
The sdo_level value must be greater than zero.
If an sdo_numtiles value is specified, it might be overridden by the indexing algorithm.
Interpretation of sdo_level and sdo_numtiles value combinations (quadtree indexing) is shown in Table 9-2.
Table 9-2 SDO_LEVEL and SDO_NUMTILES Combinations
SDO_LEVEL  SDO_NUMTILES  Action
Not specified or 0
Not specified or 0
R-tree index.
>= 1
Not specified or 0
Fixed indexing (indexing with fixed-size tiles).
>= 1
>= 1
Hybrid indexing with fixed-size and variable-sized tiles. The SDO_LEVEL column defines the fixed tile size. The SDO_NUMTILES column defines the number of variable tiles to generate per geometry.
Not specified or 0
>= 1
Not supported (error).
If a tablespace name is provided in the parameters clause, the user (underlying table owner) must have appropriate privileges for that tablespace.
The 'geodetic=FALSE' parameter allows you to bypass the restriction that a quadtree index cannot be used with geodetic data. However, using this parameter is not recommended, because much of the Oracle Spatial geodetic support will be disabled, and some Spatial operations that use the quadtree index with geodetic data will not work correctly or will return less accurate results. This parameter should only be used if you cannot yet reindex the data with an R-tree index and if the results using the quadtree index are acceptable.
If you are creating a function-based spatial index, the number of parameters must not exceed 32. For information about using function-based spatial indexes, see Section 8.2.
To determine if a CREATE INDEX statement for a spatial index has failed, check to see if the DOMIDX_OPSTATUS column in the USER_INDEXES view is set to FAILED. Note that this is different from the case of regular indexes, where you check to see if the STATUS column in the USER_INDEXES view is set to FAILED.
If the CREATE INDEX statement fails because of an invalid geometry, the ROWID of the failed geometry is returned in an error message along with the reason for the failure.
If the CREATE INDEX statement fails for any reason, then the DROP INDEX statement must be used to clean up the partially built index and associated metadata. If DROP INDEX does not work, add the FORCE parameter and try again.
Examples
The following example creates a spatial R-tree index named COLA_SPATIAL_IDX. (An R-tree index is created by default if no quadtree-specific parameters are specified.)
CREATE INDEX cola_spatial_idx ON cola_markets(shape)
   INDEXTYPE IS MDSYS.SPATIAL_INDEX;
The following example creates a spatial quadtree index named QTREE.
CREATE INDEX qtree ON POLY_4PT(geometry)
  PARAMETERS('sdo_level=6
    sdo_commit_interval=500 tablespace=system initial=10K
    next=10K pctincrease=10 minextents=10 maxextents=20');
The following example creates a spatial quadtree index named BG06075 with two partitions, named IP1 and IP2.
CREATE INDEX BGI ON BG06075(geometry)
    PARAMETERS ('tablespace=SYSTEM sdo_level=6') LOCAL
    (PARTITION IP1 PARAMETERS ('tablespace=SYSTEM sdo_level=6'),
     PARTITION IP2 PARAMETERS ('tablespace=TBS_3 sdo_level=6'));
Related Topics
DROP INDEX
Syntax
DROP INDEX [schema.]index [FORCE];
Purpose
Deletes a spatial index.
FORCE
Causes the spatial index to be deleted from the system tables even if the index is marked in-progress or some other error condition occurs.
Prerequisites
You must have EXECUTE privileges on the index type and its implementation type.
Usage Notes
Use DROP INDEX indexname FORCE to clean up after a failure in the CREATE INDEX statement.
Examples
The following example deletes a spatial quadtree index named OLDINDEX and forces the deletion to be performed even if the index is marked in-process or an error occurs.
DROP INDEX oldindex FORCE;
Related Topics
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Library
Product
Contents
Index
