Oracle8i Installation Guide
Release 3 (8.1.7) 64 Bit for Fujitsu Siemens ReliantUNIX
Part Number A89873-01
Library
Product
Index
Go to previous page Go to next page
A
Oracle8i Products
This appendix lists the products included with Oracle8i release 3 (8.1.7):
Oracle8i Enterprise Edition or Oracle8i Components
The following table alphabetically lists the components available with each installation type of the Oracle8i Enterprise Edition or Oracle8i top-level component.
Component  Typical  Minimal
Advanced Queueing
Yes
Yes
Advanced Replication
Yes
Yes
Net8 Client, includes:
Yes
Yes
  • Net8 Assistant
Yes
Yes
  • Net8 Configuration Assistant
Yes
Yes
  • Oracle Protocol Support
Yes
Yes
    Note: When Net8 Client is installed using the Typical or Minimal installation type, Oracle Protocol Support is automatically installed for the networking protocols detected. When Net8 Client is installed through the Custom installation type, you are prompted to select the additional networking protocols for which you want support. Protocol support for Named Pipes and TCP/IP is automatically installed and cannot be de-installed.
Net8 Server
Yes
Yes
Object Type Translator, includes:
Yes
Yes
  • Oracle INTYPE File Assistant
Yes
Yes
Oracle Advanced Security, includes:Foot 1
Yes
No
  1. Encryption and Integrity Support, includes:
Yes
No
  • DES40 Encryption
Yes
No
  • DES56 Encryption
Yes
No
  • 3DES_112 Encryption (2-key option)
Yes
No
  • 3DES_168 Integrity (3-key option)
Yes
No
  • RC4_40 Encryption
Yes
No
  • RC4_56 Encryption
Yes
No
  • RC4_128 Encryption
Yes
No
  • RC4_256 Integrity
Yes
No
  • SHA-1 Integrity
Yes
No
  • MD5 Integrity
Yes
No
  1. Thin JDBC Java-based Encryption Support, includes:
Yes
No
  • DES40 Encryption
Yes
No
  • DES56 Encryption
Yes
No
  • RC4_40 Encryption
Yes
No
  • RC4_56 Encryption
Yes
No
Yes
No
  • RC4_256 Integrity
Yes
No
  • SHA-1 Integrity
Yes
No
  • MD5 Integrity
Yes
No
  1. Authentication Support, includes:
Yes
No
  • Kerberos (with SSO support)
Yes
No
  • SSL (with X.509 version 3) (with SSO support)
Yes
No
    Note: Install Kerberos using the Custom installation Authentication Methods window.
  1. Enterprise User Security, includes:
Yes
Yes
  • Oracle Enterprise Login Assistant
Yes
Yes
  • Oracle Wallet Manager
    Note: Oracle Enterprise Login Assistant and Oracle Wallet Manager are features of Oracle Advanced Security and can be used only if you have purchased an Oracle Advanced Security license.
Yes
Yes
Oracle Call Interface
    Yes
    Yes
Oracle Connection Manager
No
No
Oracle Data Migration Assistant
Yes
Yes
Oracle Database Configuration Assistant
Yes
Yes
Oracle Enterprise Java Beans and CORBA Tools
Yes
Yes
Oracle Intelligent Agent, includes:
Yes
Yes
  • Data Collection Services
Yes
Yes
Oracle interMedia, includes:
Yes
No
  • Oracle interMedia Audio
Yes
No
  • Oracle interMedia Client Option
Yes
No
  • Oracle interMedia Image
Yes
No
  • Oracle interMedia Locator
Yes
No
  • Oracle interMedia Text
Yes
No
  • Oracle interMedia Video
Yes
No
Oracle JDBC Drivers, includes:
Yes
Yes
  • Oracle JDBC Thin Driver for JDK 1.1
Yes
Yes
  • Oracle JDBC Thin Driver for JDK 1.2
Yes
Yes
  • Oracle JDBC/OCI Driver for JDK 1.1
Yes
Yes
  • Oracle JDBC/OCI Driver for JDK 1.2
Yes
Yes
Oracle8i JVM, includes:
Yes
Yes
  • Java Virtual Machine
Yes
No
  • Oracle8i JVM Accelerator
Yes
No
  • Oracle Servlet Engine
Yes
No
Oracle Names
No
No
Oracle Parallel Server, includes: Foot 2
Yes
No
  • Oracle Parallel Server Management
Yes
No
    Note: Oracle Parallel Server is installed only if a cluster is detected.
Oracle Partitioning1
Yes
Yes
Oracle SNMP Agent
No
No
Oracle Spatial1
Yes
No
Oracle SQLJ, includes:
Yes
Yes
  • SQLJ Runtime
Yes
Yes
  • SQLJ Translator
Yes
Yes
Oracle Trace
Yes
Yes
Oracle Time Series1
Yes
No
Oracle Universal Installer, includes:
Yes
Yes
  • The Oracle version of Java Runtime Environment
Yes
Yes
Oracle Utilities, includes:
Yes
Yes
  • Database Verify Utility
Yes
Yes
  • Export
Yes
Yes
  • Import
Yes
Yes
  • Migration Utility
Yes
Yes
  • Recovery Manager
Yes
Yes
  • SQL*Loader
Yes
Yes
  • Server Manager
    Note: Server Manager will no longer be available after release 8.1.7.
Yes
Yes
Oracle Visual Information Retrieval1
Yes
No
Oracle Visual Information Retrieval Client1
Yes
No
Oracle XML Developer's Kit
Yes
Yes
Oracle XML SQL Utility
Yes
Yes
Oracle8i ServerFoot 3 (the Oracle8i database), includes:
Yes
Yes
  • Oracle Database Demonstrations
Yes
Yes
  • PL/SQL
Yes
Yes
  • PL/SQL Embedded Gateway
Yes
Yes
SQL*Plus
Yes
Yes
1 Oracle Advanced Security, Oracle Partitioning, Oracle Spatial, Oracle Time Series, Oracle Visual Information Retrieval, and Oracle Visual Information Retrieval Client are available with Oracle8i Enterprise Edition, but are not available with Oracle8i.
2 Oracle Parallel Server is available only with Oracle8i Enterprise Edition.
3 The type of Oracle8i Server depends upon the database type you purchased: Oracle8i Enterprise Edition or Oracle8i.
Oracle8i Client Components
The following table alphabetically lists the components available with each installation type of the Oracle8i Client top-level component.
  Oracle8i Client
Component  Administrator   Programmer   Application User
Advanced Queueing
Yes
Yes
Yes
Documentation for Fujitsu Siemens ReliantUNIX (online)
Yes
Yes
Yes
Yes
Yes
Yes
  • Net8 Assistant
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
    Note: When Net8 Client is installed through the Typical or Minimal installation type, Oracle Protocol Support is automatically installed for the networking protocols detected. When Net8 Client is installed through the Custom installation type, you are prompted to select the additional networking protocols for which you want support. Protocol support for Named Pipes and TCP/IP is automatically installed and cannot be de-installed.
Yes
Yes
No
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
Yes
  • DES40 Encryption
Yes
Yes
Yes
  • DES56 Encryption
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
  • RC4_40 Encryption
Yes
Yes
Yes
  • RC4_56 Encryption
Yes
Yes
Yes
Yes
Yes
Yes
  • RC4_256 Integrity
Yes
Yes
Yes
  • SHA-1 Integrity
Yes
Yes
Yes
  • MD5 Integrity
Yes
Yes
Yes
Yes
Yes
Yes
  • DES40 Encryption
Yes
Yes
Yes
  • DES56 Encryption
Yes
Yes
Yes
  • RC4_40 Encryption
Yes
Yes
Yes
  • RC4_56 Encryption
Yes
Yes
Yes
Yes
Yes
Yes
  • RC4_256 Integrity
Yes
Yes
Yes
  • SHA-1 Integrity
Yes
Yes
Yes
  • MD5 Integrity
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No
No
Yes
Yes
Yes
Yes
Yes
Yes
Oracle Java Tools and CORBA Tools, includes:
Yes
Yes
Yes
  • Enterprise Java Beans
Yes
Yes
Yes
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No
Oracle SQLJ
Yes
Yes
No
  • SQLJ Runtime
Yes
Yes
No
  • SQLJ Translator
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
  • Export
Yes
Yes
Yes
  • Import
Yes
Yes
Yes
  • Recovery Manager
Yes
Yes
No
  • SQL*Loader
Yes
Yes
Yes
  • TKPROF
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
PL/SQL
Yes
Yes
No
Pro*C/C++
No
Yes
No
Pro*COBOL 1.8.52
No
No
No
Pro*FORTRAN
No
No
No
SQLJ, includes
Yes
Yes
Yes
  • SQLJ Runtime
Yes
Yes
Yes
  • SQLJ Translator
Yes
Yes
Yes
SQL*Plus
Yes
Yes
Yes
1 Oracle Advanced Security is available only with Oracle8i Enterprise Edition.
Product Descriptions
Table A-1 provides descriptions and release numbers of the products available for installation. Some products listed are automatically installed with other products.
Table A-1 Product Descriptions
Product  Release  Description  Additional Information
Advanced Queueing
8.1.7
Provides support for the Advanced Queueing API.
Oracle8i Application Developer's Guide - Advanced Queueing
8.1.7
Provides support for the Advanced Replication API.
Oracle8i Replication
Assistant Common Files
(installed with Oracle assistants, such as Oracle Database Configuration Assistant and Net8 Assistant)
8.1.7
A collection of automatically installed files required by Oracle assistants. These files include:
  • BaliShare 1.0.8 (compressed)
  • DBUI 1.1.2
  • EWT 3.3.6 (compressed)
  • ICE Browser 4.06.6 (compressed)
  • Java Swing Components 1.1.1 (compressed)
  • Kodiak 1.1.2
  • Oracle Help for Java 3.1.3 (compressed)
  • SMUI 1.0.7
Not applicable
(installed with Oracle Intelligent Agent)
2.2
Works as an extension of Oracle Intelligent Agent to collect system performance data (for example, file I/O or CPU usage data) for Capacity Planner and Performance Manager, which are data-collecting applications in the Oracle Diagnostics Pack.
Oracle Enterprise Manager Administrator's Guide
Oracle Enterprise Manager Concepts Guide
Enterprise JavaBeans
8.1.7
An architecture used for developing transactional applications as distributed components in Java.
Oracle8i Enterprise JavaBeans and CORBA Developer's Guide
Java Runtime Environment (The Oracle version)
1.1.8_10
Required for running Java applications, such as Oracle Universal Installer. The Fujitsu Siemens ReliantUNIX JRE version 1.1.8 is the minimum standard Java platform for running Java programs.
Not applicable
Net8 Assistant
(Installed with Net8 Client)
8.1.7
Used by network administrators and DBAs to configure Net8.
Net8 Administrator's Guide
Net8 Client
8.1.7
Provides products that enable client connections to databases across a network. A client-side application sends a request to Net8 to be transported across the network to the server.
Net8 Client (and not Oracle Universal Installer) installs TCP/IP and Named Pipes.
8.1.7
Automatically started during installation to configure directory service access and Net8 client and server components. Net8 Configuration Assistant can also be run in stand-alone mode to configure Net8 after its installation.
Net8 Server
8.1.7
Provides products that allow the listener, using a protocol, to accept connections from client applications on the network.
Note: Net8 Server can be installed using any Oracle8i Client installation types.
Net8 clients communicate with Oracle servers using network service names. Net8 resolves network service names using the following naming methods:
  • Host Names
  • Local Names
  • Oracle Names
  • Directory Names
8.1.7
Used to create C-struct representations of Abstract Data Types (ADTs) that have been created and stored in an Oracle database. To take advantage of objects, run Object Type Translator against the database, and a header file is generated that includes the C-structs.
Oracle Call Interface Programmer's Guide
8.1.7
Oracle Advanced Security provides the following comprehensive suite of security services for Oracle8i:
This multicomponent product requires a separate license.
Oracle Advanced Security Administrator's Guide
Authentication support
8.1.7
Oracle Advanced Security provides strong authentication support using a variety of authentication modules.
Authorization support
8.1.7
Authorization solutions are provided with the enterprise role management functionality in Oracle Advanced Security.
Encryption and Integrity support
8.1.7
Oracle Advanced Security ensures data confidentiality during transmission using the encryption and data integrity types listed in the installable products tables. It enables a variety of public-key solutions, including native encryption, Secure Sockets Layer (SSL), X.509 certificates, passwords, smartcards, and biometrics.
Note: Recent changes in the United States Export Administration Regulations (EAR) have made it possible for Oracle Corporation to ship a single edition of Oracle Advanced Security worldwide. Oracle Advanced Security includes strong encryption for protocols into the Oracle database that were previously available only to the U.S. and Canadian markets.
Enterprise User Security support
8.1.7
Oracle Advanced Security integrates with Lightweight Directory Access Protocol (LDAP) directory services for centralized enterprise user management, enterprise role management, and single sign-on.
Single Sign On support
8.1.7
Oracle Advanced Security provides single sign-on to multiple accounts and applications using a single password. Strong authentication occurs transparently in subsequent connections. Kerberos and SSL-based single sign-on are supported.
8.1.7
An API for accessing an Oracle database from a C or C++ program.
8.1.7
Acts like a router through which client connection requests can either be sent to the next hop or directly to a server. Clients can take advantage of the connection concentration, Net8 access control, or multi-protocol support features configured on the Connection Manager.
8.1.7
Migrates existing Oracle7 databases (release 7.1.3.3.6 or later) to an Oracle8i database and upgrades Oracle8 databases to the current database release.
Oracle8i Migration
8.1.7
Automates the process of creating, modifying, and deleting an Oracle database.
Oracle8i Administrator's Guide
Oracle Documentation
8.1.7
Online version of Oracle8i documentation available in HTML and PDF format.
"Accessing Installed Documentation"
1.1
Enables single sign on, which implements a subset of the Wallet Manager for opening a user wallet and enabling applications to use it.
8.1.7
Monitors services on the managed node for registered events and scheduled jobs sent by the console.
Oracle Intelligent Agent User's Guide
Oracle interMedia
8.1.7
Enables file management in a variety of media, including text, audio, and video using a specific component of interMedia.
This multi-component product requires a separate license.
Oracle8i interMedia Text Reference
(installed with Oracle interMedia, formerly called Oracle Audio Cartridge)
8.1.7
Enables you to store, retrieve, and manage digitized audio data within an Oracle database.
Oracle8i interMedia Audio, Image, and Video User's Guide and Reference
(part of Oracle interMedia)
8.1.7
Provides an Oracle8i interMedia Audio, Image, and Video Java interface that lets you use client-side applications to manipulate and/or modify multimedia data stored in a network accessible database on the server.
Oracle interMedia Common Files
(installed with Oracle interMedia)
8.1.7
A set of files used by Oracle interMedia components.
Not applicable
(installed with Oracle interMedia, formerly called Oracle Image Cartridge)
8.1.7
Enables you to store, retrieve, and process two-dimensional, static bitmapped images. Images are stored efficiently using popular compression schemes in industry-standard desktop publishing image interchange formats.
Oracle interMedia Locator Service
8.1.7
Enables Oracle8i to support online internet-based geocoding facilities for locator applications and proximity queries.
Oracle8i interMedia Locator User's Guide and Reference
(installed with Oracle interMedia, formerly called Oracle ConText Cartridge)
8.1.7
Manages and search for text in the database as quickly and easily as any other type of data. Oracle interMedia Text also supports basic full-text searches in most languages supported by the Oracle database.
(installed with Oracle interMedia, formerly called Oracle Video Cartridge)
8.1.7
Enables you to store, retrieve, and manage digitized video data within an Oracle database.
Oracle Java Database Connectivity (JDBC) Drivers
8.1.7
A standard set of Java classes, specified by JavaSoft, that provides vendor-independent access to relational data using Java.
Oracle8i JDBC Developer's Guide and Reference
Oracle8i JVM Enterprise Edition
8.1.7
Provides the Oracle Java Virtual Machine, CORBA 2.0 Object Request Broker, embedded JDBC drivers, SQLJ translator, and an Enterprise JavaBeans transaction server.
Oracle8i Java Developer's Guide
8.1.7
Eliminates interpreter overhead by translating standard Java class files into specialized C source files. A platform-dependent C compiler then processes the C source files into native libraries, which can be loaded dynamically. The Oracle8i JVM Accelerator is portable to all operating systemand hardware platforms.
Oracle8i Java Stored Procedures Development Guide; Oracle8i Java Developer's Guide
Oracle8i JVM Servlet Container (JSC)
8.1.7
The Oracle8i JVM Servlet Container is a built-in web server running inside the database. It is a servlet runner that works with the Apache server and with Oracle8i JVM to enable distribution of Java Server Pages (JSPs) and to enable servlets to run directly on the database.
Oracle8i JVM Servlet Container User's Guide; Oracle8i Java Developer's Guide
Oracle Java Tools
8.1.7
Provides Java tools to build and deploy Java stored procedures, CORBA objects, and Enterprise JavaBeans with the Oracle Java Virtual Machine.
Oracle8i SQLJ Developer's Guide and Reference
Oracle Names
8.1.7
A distributed naming service developed for Oracle environments to help simplify the setup and administration of global, client/server computing networks. Oracle Names does this by establishing and maintaining an integrated system of Names servers. Oracle Names servers work like a directory service storing addresses for all the database services on a network and making them available to clients that want to make a connection.
Oracle Objects Functionality
8.1.7
Enables you to create and manipulate objects, and to integrate objects with standard relational functionality.
8.1.7
Enables multiple Oracle instances to share a single Oracle database.
This product requires a separate license.
Oracle8i Parallel Server Setup and Configuration
Oracle Partitioning
8.1.7
Provides more control in managing tables and indexes by directing all maintenance operations to individual partitions rather than to tables and index names.
Oracle PL/SQL Embedded Gateway
8.1.7
A Java module gateway that authenticates user roles and enables secured access to build and run PL/SQL procedures. These procedures can retrieve data from database tables and generate HTTP responses. It may be deployed in one of two ways:
  • mod_plsql: This module runs as a servlet on the HTTP Server middle tier. It creates "stateless" sessions, meaning information on requests is not maintained between client sessions.
  • mod_ose: This module runs as a servlet within the database. By resetting the default database activation descriptor (DAD) from the default "stateless" to "stateful," conventional database locking schemes are enabled and session states are maintained.
Oracle Internet Application Server Release: Using mod_plsql
Oracle8i Administrator's Reference release 3
8.1.7
A Web server built directly into the Oracle8i database. Oracle Servlet Engine includes an HTTP listener and the ability to distribute Java Server Pages (JSP's) and run servlets directly on the database.
Oracle Spatial
(formerly called Oracle Spatial Data Cartridge)
8.1.7
Oracle Spatial makes the storage, retrieval, and manipulation of spatial data easier and more intuitive to users.
Oracle8i Spatial User's Guide and Reference
Oracle Time Series
(formerly called Oracle8i Time Series Cartridge)
8.1.7
Stores and retrieves time-stamped data using object data types.
Oracle8i Time Series User's Guide
1.7.1.7.0
A Java-based application that lets you quickly install, update, and remove Oracle products.
Oracle Utilities
8.1.7
A suite of products used for database administration, including:
  • DBVERIFY
  • Export Utility
  • Import Utility
  • Migration Utility
  • OCOPY
  • ORADIM
  • Password UtilityRecovery Manager
  • Server Manager
  • SQL*Loader
  • TKPROF
Oracle8i Utilities
(formerly called Oracle8i Visual Information Retrieval)
8.1.7
Provides image storage, content-based retrieval, and format conversion capabilities through an object data type. This option is a building block for various imaging applications, rather than being an end-user application.
Oracle8i Visual Information Retrieval User's Guide and Reference
2.2
Generates a public-private key pair, creates a certificate request for submission to a certificate authority, and Installs and configures a trusted certificate for the identity.
Oracle8i Server
8.1.7
The database component of the Oracle8i Enterprise Edition or Oracle8i software
Getting to Know Oracle8i
8.1.7
This kit consists of a set of APIs for parsing and generating XML data. These interfaces have been written for Java, C, C++, and PL/SQL. This kit consists of the following components:
  • XML Parser for Java
  • XML Parser for C
  • XML Parser for C++
  • XML Parser for PL/SQL
  • XML Class Generator for Java
  • XML Class Generator for C++
  • XML Transviewer Beans
  • XSQL Servlet
Oracle8i Application Developer's Guide - XML
Oracle8i XML Reference
2.0
This utility is a set of Java classes and PL/SQL wrappers that permit queries to return result sets or objects wrapped in XML.
8.1.7
Enables users to use their browsers to run PL/SQL procedures stored in an Oracle database. The stored procedures can retrieve data from tables in the database, and generate HTTP responses to return to client browsers. The PL/SQL Embedded Gateway also includes the PL/SQL Web Toolkit--a set of PL/SQL packages that enables users to retrieve information on the HTTP request, specify values for HTTP headers, set cookies, and generate HTML pages.
Pro*C/C++
8.1.7
Takes SQL statements embedded in C and C++ programs and converts them to standard C code. When you precompile this code, the result is a C or C++ program that you can compile and use to build applications that access an Oracle database.
This product requires a separate license as a part of Oracle Programmer.
Pro*C/C++ Precompiler Programmer's Guide
Pro*COBOL
1.8.52
8.1.7
Takes SQL statements embedded in a COBOL program and converts them to standard COBOL code. When you precompile this code, the result is a COBOL program that you can compile and use to build applications that access an Oracle database.
Pro*COBOL Precompiler Programmer's Guide
Pro*FORTRAN
1.8.52
Takes SQL statements embedded in a FORTRAN program and converts them to standard FORTRAN code. When you precompile this code, the result is a FORTRAN program that you can compile and use to build applications that access an Oracle database.
Pro*Fortran Supplement to the Oracle Precompilers Guide
SQL*Plus
8.1.7
Command line interface that allows SQL and PL/SQL database languages to be used with an Oracle database
SQL*Plus User's Guide and Reference
SQLJ
8.1.7
A standard way to embed SQL statements in Java programs.
SQLJ Runtime
(installed with SQLJ)
8.1.7
A thin layer of pure Java code that runs above the JDBC driver. When Oracle SQLJ translates a SQLJ source code, embedded SQL commands in a Java application are replaced by calls to the SQLJ runtime.
SQLJ Translator
8.1.7
A preprocessor for Java programs that contain embedded SQL statements. Oracle SQLJ Translator converts the SQL statements to JDBC calls.
TCP/IP Protocol Support
8.1.7
Enables client/server conversation over a network using TCP/IP and Net8. This combination of Oracle products enables an Oracle application on a client to communicate with remote Oracle databases through TCP/IP (if the Oracle database is running on a host system that supports network communication using TCP/IP).
Multi-Threaded Server Support (MTS) is available in TCP/IP networks.
Connection Pooling is available only with MTS on TCP/IP networks.
XML Development Kit (The Oracle version)
(8.1.7)
Required for integrating and running XML applications with the database.
Not applicable
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Library
Product
Index
