| Oracle9i Enterprise Edition Installation Guide Release 1 (9.0.1) for OS/390 Part Number A89900-01 |
This appendix provides information about the NEWDSRPT CLIST and Oracle default data sets. The following topics are included:
During installation, the NEWDSRPT CLIST is loaded into your Oracle ISPCLIB library. This CLIST produces a report, as a selected PDS member, listing the default library sizes for the data sets corresponding to the products you selected during installation.
When you run this CLIST, it prompts you for this information:
The CLIST writes the report to your selected member in the high-level oran.orav.DSPRT library. The output PDS must already exist for the CLIST to execute successfully. The output PDS can be FB or FBA and have a LRECL of 80 or 133.
TSO message File DSPRT not freed, is not allocated is an informational message and does not indicate an error condition.
If you choose to install all products on this tape, member DFLTLIST in the Oracle ISPSLIB library lists the target data sets that are created during the Oracle9i for OS/390 installation. It also provides the default space allocations, in tracks, for each data set.
Member SHIPLIST in the Oracle ISPSLIB library contains a list of all the Oracle product data sets that are shipped on this distribution tape with their respective space allocations. If you do not install all of the products on this tape, you can use this member to determine how your data set space allocations differ from the default list that is provided in member DFLTLIST.
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
