| Oracle9i Enterprise Edition Installation Guide Release 1 (9.0.1) for OS/390 Part Number A89900-01 |
This appendix documents additional installation information that is referenced in the installation sections. The following topics are included:
Step 1 of the primary Oracle9i for OS/390 installation setup and initialization process creates the first of several OS/390 data sets. Later in the installation, you can specify the high-level and second-level data set name qualifiers that are used for subsequently created data sets. Refer to Appendix A, "Data Set Names and Space Allocations", for a list of the data sets and their default space allocations.
Oracle Corporation recommends that you use the same qualifiers for all of the installation-related data sets. At this time, you need to choose and use the qualifiers that were selected in "Installation Setup and Initialization" in Chapter 3.
While choosing qualifiers, remember the following requirements:
Using different qualifiers ensures that the products in the product set are maintained in separate libraries as required.
If you intend to use a new high-level qualifier for your Oracle data sets, then you must define an ALIAS before running the job that loads the installation JCL. If in doubt, ask your OS/390 systems programmer for assistance.
The following two rules concern the value that was entered for Target Data Set Name Qualifiers on panel OR@PRIM during the installation process:
Once entered, the first 8 characters become the initial value for the High Level Qualifier on panel ORINIP00, described in "Step 1: Modify Tape Unit and Library Index (Panel ORINIP00)".
Once entered, the 17 characters become the initial value for the Second Level Qualifier for item 2 on panel ORINIP00.
These two rules allow for Oracle data sets with high-level and second-level qualifiers, as in the following examples:
aaaaaaaa
aaaaaaaa.bbbbbbbb.cccccccc
aaaaaaaa.bb.cc.dd.ee.ff.gg
where the initial values on panel ORINIP00 are seen in these examples as:
aaaaaaaa |
aaaaaaaa |
bbbbbbbb.cccccccc |
aaaa |
bbbbbbbb.cccccccc |
aaaaaaaa |
bb.cc.dd.ee.ff.gg |
Options 1 through 5 on installation panel OR@INST are:
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
