Oracle9i Enterprise Edition Messages Guide
Release 1 (9.0.1) for OS/390
Part Number A90089_02
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
5
OS/390-Specific Oracle Database Messages
This chapter documents the Oracle database server error codes unique to Oracle9i for OS/390. These errors are returned to applications and to Oracle tools and utilities that are accessing an Oracle server running on OS/390. The manner in which these error codes are displayed depends on the application, the tool, or the utility and where and how it is run. These errors are displayed with the prefix "ORA-."
The following messages are described in this chapter:
Messages ORA-04100 to ORA-04157
ORA-04100 system name buffer too small
Cause: The buffer that was supplied on a call to retrieve the system name was not large enough for the name.
Action: Report this error to Oracle Support Services.
ORA-04101 OS/390 implementation layer error
Cause: The OS/390-specific Oracle implementation layer reported an error. This message should be accompanied by additional messages, including a numeric error ID and possible system function name, return or abend code, and so forth. The error ID can be found in Chapter 5, "OS/390-Specific Oracle Database Messages".
Action: Respond as indicated for the specific error ID.
ORA-04103 database file access method I/O error
Cause: An I/O request to a database file was unsuccessful. The file types that can receive this error include tablespace, control, online log, archive log, disk backups, and other files that use VSAM linear organization and are accessed with Media Manager. This message should be accompanied by additional messages identifying the file name and/or type and numeric return and reason codes identifying the specific error.
Action: This error can result from pre allocating a file and then specifying the file to an Oracle function with an explicit file size that is greater than the actual (pre allocated) size. If this is the case, the size specified to Oracle must not exceed the actual space allocated to the file: either re-allocate the file with more space, specify a smaller size to Oracle, or omit the explicit size completely when specifying the file to Oracle. If the problem does not appear to be related to file size discrepancies, then it probably stems from an internal (software) error or hardware failure. If you have received no other indication of hardware problem (such as system log messages or errors recorded in SYS1.LOGREC), then this error should be reported to Oracle Support Services.
ORA-04104 process terminating with open database file(s)
Cause: An Oracle session attempted to terminate database file activity with one or more files still open.
ORA-04105 invalid database file logical block size
Cause: An attempt was made to create or initialize a file with a logical block size other than 4096, 8192, 16384, or 32768 bytes.
Action: If a value other than those listed was specified, then remove the parameter or change it to one of the listed values. Otherwise, report this error to Oracle Support Services.
ORA-04107 database file close attempted with active I/O
Cause: Oracle attempted to logically close a database file while I/O requests for the file were still active.
ORA-04108 database file access structure error
Cause: An internal consistency check of the memory structures that are used to access a database file failed. This generally indicates a software problem, not a problem in the database file itself.
ORA-04109 file name buffer too small
Cause: An internal memory area that is used to hold the name of a file is too small for a particular file name.
ORA-04110 archive log name buffer too small
Cause: An internal memory area that is used to hold the name of an archive log is too small for a particular file name.
ORA-04111 unable to allocate memory for process global area
Cause: During Oracle session initialization, a request for virtual memory in the server address space for the process global area (PGA) failed.
Action: Either increase the region size available to the Oracle server (REGION parameter on the JCL EXEC statement of the server JCL procedure) or increase the number of server address spaces (MAXAS parameter of the Oracle subsystem DEFINE SERVICE command).
ORA-04112 server executable name could not be determined
Cause: During Oracle session initialization, an attempt to retrieve the database server program (load module) name failed.
ORA-04113 client executable name could not be determined
Cause: During Oracle session initialization, an attempt to retrieve the client's program name failed.
ORA-04114 database file opened for input was found to be empty
Cause: Oracle attempted to open a database file for input, but the file was found to be empty (the high-used RBA stored in the ICF catalog structure is zero).
Action: If this error does not appear to result from a user error (such as accidentally deleting and redefining a database file), then it should be reported to Oracle Support Services.
ORA-04115 database file identification block is invalid or unreadable
Cause: When opening a database file, the self-identifying block (CI 0) in the file did not contain the correct information, or the block could not be read due to an I/O error or other failure.
Action: If this occurs when adding a file to the database, make sure that the file name is not that of an existing (non-Oracle) VSAM object. Otherwise, report this error to Oracle Support Services.
ORA-04116 unable to allocate memory for database file validation buffer
Cause: When opening a database file, an attempt to allocate server region memory for a buffer for the file's self-identifying block failed.
Action: Either increase the region size available to the Oracle server (REGION parameter on the JCL EXEC statement of the server JCL procedure) or increase the number of serve address spaces (MAXAS parameter of the Oracle subsystem DEFINE SERVICE command).
ORA-04117 improper database file I/O request
Cause: An improper request (such as a write to a file that was opened for input only) was issued for a database file.
ORA-04118 invalid database file type code
Cause: A request to create, access, or delete a database file passed an unknown internal file type code.
ORA-04119 message file read request error
Cause: A request to read a product message file specified an incorrect file offset or length.
ORA-04120 message file name buffer too small
Cause: An internal memory area that is used to hold a message file name was too small for a particular name.
ORA-04121 message file name invalid
Cause: An internally-generated message file name was invalid.
ORA-04122 invalid connect authorization type
Cause: During database logon processing, a call was made to the connection authority checking routine with an unknown connection type code.
ORA-04123 invalid parameter to sltln
Cause: The SLTLN name translation routine was called with invalid arguments. The input or output strings were either NULL or 0 length.
ORA-04124 sltln output buffer overflow
Cause: The SLTLN name translation routine was called with an output buffer that was too short for the input name.
ORA-04125 skgm out of memory
Cause: Out of memory.
Action: Consult the trace file for details.
ORA-04126 skgm shared memory realm does not exist
Cause: Unable to locate shared memory realm.
ORA-04127 slkhst could not perform host operation
Cause: Operating system call failed.
ORA-04128 sllfop open error; could not open file
Cause: Open call returned an error.
Action: Ensure that the file exists.
ORA-04129 sllfop invalid processing option, incorrect format
Cause: Processing option passed is of incorrect format.
ORA-04130 sllfop filestat error
Cause: Possible bad data passed to filestat.
ORA-04131 sllfop invalid recordsize
Cause: Input record size was larger than user specified record size.
ORA-04132 sllfop no memory for read buffer
Cause: Allocation of read buffer failed.
ORA-04133 sllfrb no memory for internal structure
Cause: Allocation of memory for internal structure failed.
ORA-04134 sllfsk skip option not supported
Cause: Skip option not supported with linked-in loader.
ORA-04135 sllfsk end of logical record
Cause: While attempting to read the length portion of a varying length field, the end of the logical record was reached.
ORA-04136 sllfcf bad close
Cause: Close call returned an error.
ORA-04137 sllfrd bad read
Cause: Read call returned an error.
ORA-04138 soamon connection error
Cause: Connection error.
ORA-04139 internal name translation length error
Cause: The length of a name to be translated is invalid.
ORA-04140 internal name translation buffer too small
Cause: An internal buffer for translating logical names was too small for the result.
ORA-04141 invalid backup device internal structure
Cause: The internal data structure which describes an RMAN channel failed a validity test.
ORA-04142 backup file still open on device being released
Cause: RMAN attempted to release or start a new operation on a channel that still has a file open or a proxy operation in progress.
ORA-04143 channel not allocated for I/O
Cause: RMAN attempted to open a backup file or start a proxy operation on a channel that was allocated for maintenance activity only.
ORA-04144 invalid data block length for backup file
Cause: Oracle supplied an invalid data block length on a request to create a backup.
ORA-04145 invalid request for asynchronous I/O
Cause: A backup I/O request specified an unsupported mode of operation.
ORA-04146 invalid backup file internal structure
Cause: The internal data structure which describes a backup file failed a validity test.
ORA-04147 proxy backup/restore operation sequence error
Cause: Internal function calls related to RMAN proxy backup or restore were made in the wrong sequence.
ORA-04148 insufficient server virtual memory for proxy operation
Cause: Virtual memory for an internal data structure related to RMAN proxy backup or restore could not be allocated. This can happen if the target server address space is very low on virtual memory.
Action: Start a new RMAN session in the target server and retry the proxy operation. If the problem persists, report the error to Oracle Support Services.
ORA-04149 invalid backup channel device type
Cause: An invalid TYPE was specified on an RMAN ALLOCATE CHANNEL command.
Action: For an OS/390 OSDI server, TYPE must be either DISK or "EDM0".
ORA-04150 invalid backup channel device name
Cause: An invalid NAME was specified on an RMAN ALLOCATE CHANNEL command.
Action: No device names are supported for OS/390 servers. Remove the name from the ALLOCATE CHANNEL command and make sure that you have specified a valid TYPE.
ORA-04151 invalid destination for Oracle-Managed File
Cause: One of the parameters DB_CREATE_FILE_DEST or DB_CREATE_ONLINE_LOG_DEST_n has been specified with a value that is unacceptable on OS/390.
Action: Correct the parameter value and retry the STARTUP or ALTER SYSTEM request that received the error.
ORA-04152 invalid characters in file path name
Cause: The characters '..' were found in a file path name. This is not allowed.
Action: Correct the file path name and retry.
ORA-04153 invalid normalized file name length
Cause: The length of a normalized file name either exceeds the length of the caller's buffer or the allowed maximum.
ORA-04154 invalid generated file name length
Cause: The length of a generated file name exceeds the length of the caller's buffer.
ORA-04155 invalid tablespace name for OMF name generation
Cause: The tablespace name that would be used as part of name generation for an Oracle-managed tablespace file is invalid.
ORA-04156 invalid Oracle-managed filename template
Cause: A filename template used for generating an Oracle- managed file name does not contain the expected substitution marker.
ORA-04157 alert log access is not available
Cause: This error arises normally when a function attempts to access (read) the instance alert log, which is not supported on OS/390.
Action: None.
Oracle
Copyright © 2002 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
