Oracle9i Enterprise Edition Messages Guide
Release 1 (9.0.1) for OS/390
Part Number A90089_02
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
8
Network Messages
This chapter describes the messages that are issued by the Oracle Network Service on OS/390. Error and warning messages are written to the system console. Informational messages are generally only written to the Oracle NETLOG DD.
The messages all begin with the prefix "MIN" followed by a 4-digit decimal number followed by a letter to identify the action and severity associated with each message. The final letter indicates one of the following:
E
Error. Action is required.
I
Information. Action is not required.
S
Severe error. Action is required. Oracle Net will probably terminate.
W
Warning. Action might be required.
The network messages are often created with character substitutions. In the messages below, %x represents some hexadecimal value, %d a decimal value, and %c a character value. The number of x's, d's, and c's after the % represent the precision of the expected value with the % counting as 1. For example %cccc means that a character value substitution with a length of five is expected.
To find the return code values for TCP/IP failures, refer to the IBM manual OS/390 Communications Server IP and SNA Codes, or its equivalent for your level of OS/390.
The following messages are described in this chapter:
Messages MIN0001 to MIN0901
MIN0001I networking service initializing
Cause: This message is a normal Oracle Net start up message.
MIN0002I networking service %ccccccc initialization complete
MIN0003E module MINMAIN is not in an APF-authorized library
Cause: Oracle Net must be executed from an APF authorized library.
Action: Authorize the library and restart Oracle Net.
MIN0004E unable to obtain storage for global vector
Cause: Not enough virtual storage is available to Oracle Net.
Action: Increase the Oracle Net region and restart.
MIN0005I global vector is at %xxxxxxx
MIN0006E failure executing ASEXT, R15 = %d, R0 = %d
Cause: This message is a critical error. Oracle Net will not function properly.
Action: The information displayed in the message should be reported to Oracle Support Services.
MIN0008E unable to obtain %dddd bytes of storage for %ccccccc
Cause: Insufficient storage space is available.
MIN0009E unable to obtain %dddd bytes of %ccc for %ccccccc, rc = %d
MIN0010E unable to attach subtask %ccccccc, ATTACH RC = %ddd
MIN0011E subtask %ccccccc abended with S%xx/U%ddd during initialization.
MIN0012E Invalid reply area on %ccccccc to subsystem %ccc
MIN0013E signon to subsystem %ccc rejected, RC = %ddd
MIN0014E signon to subsystem %ccc failed, RC = %ddd, RSN = %ddd,
INFO = %ddd
MIN0016I command service subtask initialized
MIN0017I message service subtask initialized
MIN0018I bind/unbind service subtask initialized
MIN0019W multiple TCP/IP tasks requested, none will be started
Cause: Only one TCP/IP protocol task may be active within Oracle Net.
Action: Correct the OSDI Oracle Net start parms.
MIN0020W Internal tracing will not be performed
Cause: There was not enough storage available for the internal trace table.
Action: This message is not a fatal error, but the Oracle Net region should be increased and Oracle Net restarted.
MIN0021E unable to start networking task, storage unavailable
Cause: Storage is unavailable.
MIN0022W Invalid service parameter %ccccccc ignored
Cause: The parameter shown from the service definition or alter is not recognized.
Action: This message may indicate that Oracle Net was started with a JES start command rather than an OSDI subsystem start command. The latter must be used
MIN0023W Invalid service parameter beginning with %ccccccc, ignored
Action: This message may indicate that Oracle Net was started with a JES start command rather than an OSDI subsystem start command. The latter must be used.
MIN0024I connected to WLM subsystem %cccc
MIN0025W WLM not active, connect failed RC=%xxxx RSN=%xxxxxxxx
Cause: Oracle Net will continue, but work will be scheduled into the Oracle server on preemptable SRB's instead of enclave SRB's and the work will not be managed by WLM.
MIN0026I timer service subtask initialized
MIN0091I timer service subtask terminated
MIN0092W WLM disconnect failed RC=%xxxx RSN=%xxxxxxxx
Cause: Oracle Net will continue to terminate, but a graceful termination of WLM services was not possible.
Action: None, Oracle Net will continue shutdown.
MIN0093I command service subtask terminated
Cause: This message is a normal Oracle Net termination message
MIN0094I message service subtask terminated
MIN0095I bind/unbind service subtask terminated
MIN0096E signoff from subsystem %ccc rejected, RC = %ddd
Cause: Oracle Net has been stopped but cannot properly remove itself from the OSDI subsystem.
Action: This message should be reported to Oracle Support Services.
MIN0097E signoff from subsystem %ccc failed, RC = %ddd, RSN = %ddd,
INFO = %ddd
MIN0098I networking service %ccccccc termination in progress
MIN0099I networking service termination complete
MIN0100W command ignored, shutdown in progress
Cause: Modify commands cannot be processed once Oracle Net receives a stop command. It may take several minutes for Oracle Net to shut down after the stop command has been received.
Action: Allow Oracle Net to continue its shutdown. Do not try to enter more commands.
MIN0101I task %ccccccc already active, START command ignored
Cause: A modify command is trying to start a protocol that is already active.
MIN0102I task %ccccccc not active, STOP command ignored
Cause: A modify command is trying to stop a protocol that is not yet active.
MIN0103E unrecognized command verb
Cause: A modify command has been entered, but it does not specify one of the support action verbs.
Action: Enter a corrected command.
MIN0104E unrecognized keyword in command
Cause: A modify command has been entered, but it does not specify a supported keyword for the provided verb.
MIN0105E unrecognized OSDI command %d
Cause: An OSDI command has been entered, but it does not specify an action verb supported by Oracle Net.
MIN0106E error retrieving OSDI command, RC = %d
Cause: An OSDI command has been entered for Oracle Net, but Oracle Net was unable to retrieve the actual command.
Action: Report this error to Oracle Support Services.
MIN0107E TCP/IP subtask %ccccccc already active, START command ignored
Cause: An attempt was made to start a second TCP/IP protocol task. This is not allowed.
Action: Stop the active protocol task before attempting another start.
MIN0108E Resource error while attempting display command.
Cause: A request was made to display the current active protocol connections, but resources are not available to do so without interfering with activity on those connections.
Action: Attempt the command again. If the error persists, contact Oracle Support Services.
MIN0200I CID Owner Protocol Address
Cause: This message is used to respond to a Oracle Net 'modify dis' (display) command to show active connections.
MIN0201I %xxxxxxx %ccccccc TCP %cccccccccccccc/%dddd
MIN0203I %ccccccc has %d Sub-tasks active, %d are protocol tasks ,
GV is at %xxxxxxx.
Cause: This message is used to respond to an OSDI 'DISPLAY name,L' command to show status.
MIN0204I SubTask Protocol @TCB Terminated?
Cause: This message is used to respond to an OSDI 'DISPLAY name,L' command to show status of an OSDI Net service.
MIN0205I %ccccccc %ccc %xxxxxxx %cc
MIN0206I Pool SP Size Free Total Reuses
Cause: This message is used to respond to a Oracle Net 'modify dis pool' command to show storage use.
MIN0207I %CCC %dd %dddd %ddddddddd %ddddddddd %ddddddddd
MIN0300E memory unavailable for new %ccc pool element
Cause: Oracle Net is short on storage. It will continue to operate, but may be unable to handle new work.
Action: Increase the Oracle Net region an restart.
MIN0303E unable to locate CBX for CID %xxxxxxx
Cause: Oracle Net has probably suffered corruption of control structures.
Action: A console dump of the address space should be taken, and Oracle Net restarted as soon as practical.
MIN0304S Internal error, CB and CBX specify different CIDs
MIN0305E unable to obtain buffer of size %dddd
MIN0306E bind request to subsystem %ccc rejected with RC = %d
Cause: A server to which a remote client is trying to connect is not available.
Action: Check the system log for 'MIS' messages to help determine why. If the reason for failure is not apparent, contact Oracle Support Services with the information for all MIN and MIS messages.
MIN0307E bind to service %ccccccc failed, RC = %d, RSN = %ddd,
I NFO = %ddd
Action: Check the system log for 'MIS' messages to help determine way. If the reason for failure is not apparent, contact Oracle Support Services with the information from all MIN and MIS messages.
MIN0308E unbind request to subsystem %ccc rejected with RC = %d
Cause: A server from which a remote client is trying to disconnect is not responding correctly.
Action: Check the system log for 'MIS' messages to help determine way. If the reason for failure is not apparent, contact Oracle Support Services with the information from all MIN and MIS messages. The protocol side of the connection will be terminated.
MIN0309E unbind to service %ccccccc failed, RC = %d, RSN = %ddd,
INFO = %ddd
Action: Check the system log for 'MIS' messages to help determine why. If the reason for failure is not apparent, contact Oracle Support Services with the information from all MIN and MIS messages. The protocol side of the connection will be terminated.
MIN0310W WLM enclave create failed RC=%xxxx RSN=%xxxxxxxx
protocol %ccc.
Cause: This message may be due to IBM imposed restrictions on the number of enclaves that may be created by a single address space.
Action: Oracle Net will continue, but work will be scheduled into the Oracle server for this connection on a preemptable SRB instead of an enclave SRB and the work will not be managed by WLM.
MIN0311W WLM enclave delete failed RC=%xxxx RSN=%xxxxxxxx
protocol %ccc.
Cause: Oracle Net was not able to delete an enclave, probably because a SRB was active when a client tried to force a disconnection.
Action: Processing will continue and the connection will be dropped.
MIN0700I HPNS INITAPI call performed. RC=%ddd, EC=%dddd
Cause: If the RC and EC are anything other than 0, then Oracle Net TCP/IP protocol will not function correctly. The RC and EC are return code and error number from an EZASMI TYPE=INITAPI macro call.
Action: Refer to the IBM manual OS/390 Communications Server IP and SNA Codes for an explanation of what the error number is from this EZASMI macro call. Generally this message indicates that there is a configuration error and the error number gives some indication of what that error is.
MIN0701E getclientid failed invoke. RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol cannot initialize correctly and will not function correctly. The RC and EC are return code and error number from an EZASMI TYPE=GETCLIENTID macro call.
Action: Refer to the IBM manual OS/390 Communications Server IP and SNA Codes for an explanation of what the error number is from this EZASMI macro call. Generally this message indicates that there is a configuration error. It should be reported to Oracle Support Services for assistance in determining the cause.
MIN0702E getclientid call failed. RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol cannot initialize correctly and will not function correctly. The RC and EC are return code and error number from the completion of an EZASMI TYPE=GETCLIENTID macro call.
MIN0703E gethostid failed invoke. RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol cannot obtain the default home internet address and will terminate. The RC and EC are return code and error number from an EZASMI TYPE=GETHOSTID macro call.
Action: Refer to the IBM manual OS/390 Communications Server IP and SNA Codes for an explanation of what the error number is from this EZASMI macro call. This message indicates that there is a configuration error. This message can be reported to Oracle Support Services for assistance in determining the cause.
MIN0704E gethostid failed invoke. RC=%ddd
Cause: The Oracle Net TCP/IP protocol cannot obtain the default home internet address and will terminate. The RC and EC are return code and error number from the completion of an EZASMI TYPE=GETHOSTID macro call.
Action: Refer to the IBM manual F1A1D100 CS:IP Application Programming Interface Guide in the return codes section (Appendix B) for an explanation of what the error number is from this EZASMI macro call. This message indicates that there is a configuration error. This message can be reported to Oracle Support Services for assistance in determining the cause.
MIN0705E gethostbyname attach failed. RC=%ddd
Cause: The Oracle Net TCP/IP protocol cannot attach the gethostbyname task and will terminate. The return code is the return code from an ATTACHX macro call.
Action: This message can be reported to Oracle Support Services for assistance in determining the cause.
MIN0706E Attach of HPNS kid task failed. RC=%ddd
Cause: The Oracle Net TCP/IP protocol cannot attach a kid task and will terminate. The return code is the return code from an ATTACHX macro call.
MIN0707E listen-socket failed invoke. RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol cannot obtain a socket descriptor from TCPIP and will terminate. The RC and EC are return code and error number from the call to an EZASMI TYPE=SOCKET macro call.
MIN0708E listen-socket call failed. RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol cannot obtain a socket descriptor from TCPIP and will terminate. The RC and EC are return code and error number from the completion from an EZASMI TYPE=SOCKET macro call.
MIN0709E bind socket failed invoke. RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol cannot bind to a port in TCPIP and will terminate. The RC and EC are return code and error number from the call to an EZASMI TYPE=BIND macro call.
MIN0710E bind socket call failed. RC=%ddd, EC=%dddd
Cause: The TCP/IP protocol cannot initialize correctly.
Action: Report this message to Oracle Support Services
MIN0711E listen failed invoke. Sckt=%dddd RC=%ddd, EC=%dddd
MIN0712E listen call failed. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol cannot listen on a port in TCPIP and will terminate. The RC and EC are return code and error number from the completion from an EZASMI TYPE=LISTEN macro call.
MIN0713I I am listening on port %dddd socket %dddd
Cause: This message is normal and indicates that Oracle Net is listening on port nnnn and will accept connection request on this port.
Action: None.
MIN0714E accept failed invoke. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol issued an accept connection request which failed and Oracle Net will terminate. The RC and EC are return code and error number from the call to an EZASMI TYPE=ACCEPT macro.
MIN0715W accept call failed. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol issued an accept connection request which failed to complete. Oracle Net attempts to correct this and will continue as far as it can. If it cannot correct the error then Oracle Net will terminate. The RC and EC are return code and error number from the completion from an EZASMI TYPE=ACCEPT macro call.
Action: Refer to the IBM manual F1A1D100 CS:IP Application Programming Interface Guide in the return codes section (Appendix B) for an explanation of what the error number is from this EZASMI macro call. This message indicates that there is possibly a network error. This message can be reported to Oracle Support Services for assistance in determining the cause.
MIN0716E givesocket failed invoke. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol issued a givesocket to hand off a connection to a Oracle Net kid. Oracle Net will continue; however, probably with reduced functionality. The RC and EC are return code and error number from the call to an EZASMI TYPE=GIVESOCKET macro.
Action: Refer to the IBM manual F1A1D100 CS:IP Application Programming Interface Guide in the return codes section (Appendix B) for an explanation of what the error number is from this EZASMI macro call. This message indicates that there is possibly a network or a configuration error (e.g.; not enough sockets defined). This message can be reported to Oracle Support Services for assistance in determining the cause.
MIN0717E givesocket call failed. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol issued an givesocket to hand off a connection to an Oracle Net kid which failed to complete. Oracle Net will continue; however, with reduced functionality. The RC and EC are return code and error number from the completion from an EZASMI TYPE=GIVESOCKET macro call.
MIN0718E close for given failed invoke. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol issued an close socket to close a connection which failed. Oracle Net will continue. The RC and EC are return code and error number from the call to an EZASMI TYPE=CLOSE macro.
Action: Refer to the IBM manual F1A1D100 CS:IP Application Programming Interface Guide in the return codes section (Appendix B) for an explanation of what the error number is from this EZASMI macro call. This message can be reported to Oracle Support Services for assistance in determining the cause.
MIN0719W close for given call failed. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol issued an close socket to close a connection which failed to complete. Oracle Net will continue. The RC and EC are return code and error number from the completion from an EZASMI TYPE=CLOSE macro call.
Action: Refer to the IBM manual F1A1D100 CS:IP Application Programming Interface Guide in the return codes section (Appendix B) for an explanation of what the error number is from this EZASMI macro call. This message should be reported to Oracle Support Services for assistance in determining the cause.
MIN0721I HPNS shut down, GoodBye.
Cause: This message is normal and indicates that the Oracle Net TCP/IP protocol has shutdown.
Action: None
MIN0722I HPNS Kid #%dd shut down.
Cause: This message is normal and indicates that one of the Kid slaves has shutdown.
Action: None
MIN0723I HPNS Gethostbyname subtask ended.
Cause: This message is normal and indicates that the Oracle Net gethostbyname subtask has shutdown.
Action: None
MIN0724I HPNS GHBY INITAPI call performed. RC=%ddd, EC=%dddd
Cause: If the RC and EC are anything other than 0 then Oracle Net TCP/IP protocol will not function correctly. This subtask performs all the name resolution for IP addresses (DNS). The RC and EC are return code and error number from an EZASMI TYPE=INITAPI macro call.
Action: Refer to the IBM manual F1A1D100 CS:IP Application Programming Interface Guide in the return codes section (Appendix B) for an explanation of what the error number is from this EZASMI macro call. This should be reported to Oracle Support Services for assistance if the return code and error number is anything other than 0.
MIN0725E gethostname failed invoke. RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol cannot obtain the default host name and will terminate. The RC and EC are return code and error number from a call to an EZASMI TYPE=GETHOSTNAME macro.
Action: Refer to the IBM manual F1A1D100 CS:IP Application Programming Interface Guide in the return codes section (Appendix B) for an explanation of what the error number is from this EZASMI macro call. This message indicates that there is a configuration error. It can be reported to Oracle Support Services for assistance in determining the cause.
MIN0726E gethostname failed invoke. RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol cannot obtain the default host name and will terminate. The RC and EC are return code and error number from the completion of a call to an EZASMI TYPE=GETHOSTNAME macro.
MIN0727E gethostbyname call failed. RC=%ddd
Cause: The Oracle Net TCP/IP protocol cannot obtain the resolve the default hostname obtained from the gethostname call and thus fails to initialize and will terminate. The RC and EC are return code and error number from the completion of a call to an EZASMI TYPE=GETHOSTBYNAME macro.
Action: Refer to the IBM manual F1A1D100 CS:IP Application Programming Interface Guide in the return codes section (Appendix B) for an explanation of what the error number is from this EZASMI macro call. This message indicates that there is a configuration error. It can be reported to Oracle Support Services for assistance in determining the cause. This may also indicate that IBM Language Environment is not available.
MIN0728I HPNS KID INITAPI call performed. RC=%ddd, EC=%dddd
Cause: If the RC and EC are anything other than 0 then Oracle Net TCP/IP protocol will not function correctly. This subtask performs all the work for IP connections and multiple subtasks (kids) are started. The RC and EC are return code and error number from an EZASMI TYPE=INITAPI macro call.
MIN0729E KID getclientid failed invoke. RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol issued an getclientid to initialize a Oracle Net kid which failed. Oracle Net will terminate. The RC and EC are return code and error number from the call to an EZASMI TYPE=GETCLIENTID macro.
Action: Refer to the IBM manual F1A1D100 CS:IP Application Programming Interface Guide in the return codes section (Appendix B) for an explanation of what the error number is from this EZASMI macro call. This should be reported to Oracle Support Services for assistance.
MIN0730E KID getclientid call failed. RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP protocol issued an getclientid to initialize a Oracle Net kid which failed to complete. Oracle Net will terminate. The RC and EC are return code and error number from the completion of the call to an EZASMI TYPE=GETCLIENTID macro.
MIN0731E takesocket failed invoke. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: The setup of a TCP/IP connection has failed. The Kid is trying to take connection request and has failed. Oracle Net will try to continue. The RC and EC are return code and error number from the call to an EZASMI TYPE=TAKESOCKET macro.
MIN0732E takesocket call failed. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: The setup of a TCP/IP connection has failed. The Kid is trying to take connection request and has failed. Oracle Net will try to continue. The RC and EC are return code and error number from the completion of a call to an EZASMI TYPE=TAKESOCKET macro.
MIN0733I Socket %ddd connected Subtask %ccc, IP %cccccccccccccc,
Port %dddd.
Cause: This message is a normal TCP/IP connection message for an inbound connection request to an OS/390 server from some remove TCP/IP client.
Action: None.
MIN0734E setsocket failed invoke. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: The setup of a TCP/IP connection has failed. The Kid is trying to set up the connection and has failed. Oracle Net will try to continue. The RC and EC are return code and error number from the call to an EZASMI TYPE=SETSOCKOPT macro.
MIN0735E setsocket call failed. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: The setup of a TCP/IP connection has failed. The Kid is trying to set up the connection and has failed. Oracle Net will try to continue. The RC and EC are return code and error number from the completion of a call to an EZASMI TYPE=SETSOCKOPT macro.
MIN0736E receive failed invoke. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: A TCP/IP connection has failed. The Kid is trying to receive some data and has failed. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the call to an EZASMI TYPE=RECV macro.
Action: Refer to the IBM manual F1A1D100 CS:IP Application Programming Interface Guide in the return codes section (Appendix B) for an explanation of what the error number is from this EZASMI macro call. This should be reported to Oracle Support Services for assistance; however, any error is most likely to be due to a network error.
MIN0737E receive call failed. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: A TCP/IP connection has failed. The Kid is trying to receive some data and has failed. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the completion of a call to an EZASMI TYPE=RECV macro.
MIN0738E send failed invoke. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: A TCP/IP connection has failed. The Kid is trying to send some data and has failed. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the call to an EZASMI TYPE=SEND macro.
Action: Refer to the IBM manual F1A1D100 CS:IP Application Programming Interface Guide in the return codes section (Appendix B) for an explanation of what the error number is from this EZASMI macro call. This should be reported to Oracle Support Services for assistance however, any error is most likely to be due to a network error.
MIN0739E send call failed. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: A TCP/IP connection has failed. The Kid is trying to send some data and has failed. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the completion of a call to an EZASMI TYPE=SEND macro.
MIN0740E close failed invoke. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: A TCP/IP connection has failed. The Kid is trying to close a connection and has failed. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the call to an EZASMI TYPE=CLOSE macro.
MIN0741E close call failed. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: A TCP/IP connection has failed. The Kid is trying to close a connection and has failed. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the completion of a call to an EZASMI TYPE=CLOSE macro.
MIN0742I Socket %ddd closed Subtask %ccc, IP %cccccccccccccc, Port %dddd.
Cause: This message is normal and indicates that a remote TCP/IP connection has closed.
Action: None
MIN0743E socket failed invoke. Sckt=%dddd RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP connection cannot obtain a socket descriptor from TCPIP. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the call to an EZASMI TYPE=SOCKET macro.
Action: Refer to the IBM manual F1A1D100 CS:IP Application Programming Interface Guide in the return codes section (Appendix B) for an explanation of what the error number is from this EZASMI macro call. This should be reported to Oracle Support Services for assistance; however, any error is most likely to be due to either a network or configuration error.
MIN0744E socket call failed. Subtask %ccc RC=%ddd, EC=%dddd
Cause: The Oracle Net TCP/IP connection cannot obtain a socket descriptor from TCPIP. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the completion of a call to an EZASMI TYPE=SOCKET macro.
MIN0745E connect failed invoke. Subtask %ccc Sckt=%ddd, RC=%ddd, EC=%dddd
Cause: The local client cannot establish a connection between a local TCP/IP socket and a remote socket. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the call to an EZASMI TYPE=CONNECT macro.
MIN0746E connect call failed. Subtask %ccc Sckt=%ddd, RC=%ddd, EC=%dddd
Cause: The local client cannot establish a connection between a local TCP/IP socket and a remote socket. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the completion of a call to an EZASMI TYPE=CONNECT macro.
MIN0747E getsockname failed invoke. Subtask %ccc Sckt=%ddd, RC=%ddd, EC=%dddd
Cause: The local client cannot establish a connection between a local TCP/IP socket and a remote socket. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the call to an EZASMI TYPE=GETSOCKNAME macro.
MIN0748E getsockname call failed. Subtask %ccc Sckt=%ddd, RC=%ddd, EC=%dddd
Cause: The local client cannot establish a connection between a local TCP/IP socket and a remote socket. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the completion of a call to an EZASMI TYPE=GETSOCKNAME macro.
MIN0749I Socket %ddd connected Subtask %ccc, IP %cccccccccccccc,
Port %dddd.
Cause: This message is a normal message issued when an outbound OS/390 client connects to a remote server via TCP/IP.
Action: None.
MIN0750E cancel recv failed invoke. Subtask %ccc Sckt=%ddd, RC=%ddd, EC=%dddd
Cause: The local client cannot close a connection between a local TCP/IP socket and a remote socket. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the call to an EZASMI TYPE=CANCEL macro.
MIN0751E cancel recv call failed. Subtask %ccc Sckt=%ddd, RC=%ddd, EC=%dddd
Cause: The local client cannot close a connection between a local TCP/IP socket and a remote socket. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the completion of a call to an EZASMI TYPE=CANCEL macro.
MIN0752E cancel accept failed invoke. Subtask %ccc Sckt=%ddd, RC=%ddd, EC=%dddd
Cause: The local socket cannot close a connection between a local TCP/IP socket and a remote socket. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the call to an EZASMI TYPE=CANCEL macro.
MIN0753E cancel accept call failed. Subtask %ccc Sckt=%ddd, RC=%ddd, EC=%dddd
Cause: The local socket cannot close a connection between a local TCP/IP socket and a remote socket. Oracle Net will try to continue though this connection will terminate. The RC and EC are return code and error number from the completion to a call to an EZASMI TYPE=CANCEL macro.
MIN0901S diagnostic dump failed for abend Ssss/Uuuuu, SDUMPX RC = rc, RSN = rs
Cause: The sdumpx macro has failed to complete for the system abend sss or the user abend uuuu.
Action: Refer to the MVS Programming: Authorized Assembler Services Reference macro SDUMPX for further information on return code rc and reason code rs and appropriate actions.
Oracle
Copyright © 2002 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
