Skip Headers
Oracle9i Installation Guide
Release 1 (9.0.1) for UNIX Systems: AIX-Based Systems, Compaq Tru64 UNIX, HP 9000 Series HP-UX, Linux Intel and Sun SPARC Solaris
Part Number A90346-04
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
C
Oracle Transparent Gateway
This chapter describes how to install the gateway software from the distribution CD-ROM. This chapter includes the following sections:
System Requirements for Oracle Transparent Gateway
Review your system's hardware and software to ensure that it meets requirements, and determine gateway configuration before you install the gateway. Gateway components can be located on one platform or distributed over several platforms.
Oracle Corporation supports the software configurations described in this section as long as the underlying system software products are supported by their respective vendors. Verify the latest support status with your system software vendors.
Use the installation worksheet provided for your configuration to ensure that you have all required information before beginning installation.
The following sections describe system requirements for gateway configuration, and provide worksheets to use during the installation:
Informix Gateway Requirements
Table C-1 describes the hardware and software requirements for an Informix gateway. Use it to ensure that your system meets requirements to create a gateway for the Oracle Transparent Gateway for Informix.
Table C-1 Informix Gateway Requirements
Hardware/ Software  Platform  Requirements
Processor
HP
An HP workstation running the required version of HP-UX.
Solaris
A Sun SPARC workstation running the required version of Solaris.
Memory
HP
26 MB of real memory is recommended to support the gateway. The total real memory requirement for the concurrent use of the gateway depends on these factors:
  • The SQL statement issued by the user.
  • The number of cursors currently opened against Informix.
  • The number of columns in the table being accessed.
Solaris
CD-ROM Drive
HP
An internal or external CD-ROM drive.
Solaris
Disk Space
HP
200 MB.
Solaris
200 MB.
Operating System
HP
HP version 11.
Solaris
Solaris version 2.6 (5.6), 7 (5.7) or 8 (5.8).
Oracle Database Server
HP
Oracle9i Enterprise Edition Server release 1 (9.0.1).
Oracle database server can reside on any supported platform.
Solaris
Oracle Networking
HP
On gateway machine:
  • Oracle Net Server release 9.0.1.
  • Oracle Adapter for Named Pipes or TCP/IP.
The following are required on the Oracle database server machine:
  • Oracle Net Client release 9.0.1.
Oracle Net products are included on the distribution CD-ROM.
Oracle Net or Oracle Net Client and the Oracle Adapter must be installed on the machine where the Oracle database server is installed. Oracle Net Server and the Oracle Adapter must be installed on the machine where the gateway is installed.
Solaris
On gateway machine:
Informix
HP
INFORMIX-OnLine, version 7.2, 7.3 or 7.4 and INFORMIX-ESQL/C are required. This version of the gateway does not support INFORMIX-SE.
Solaris
Ingres Gateway Requirements
Table C-2 describes the hardware and software requirements for an Ingres gateway. Use it to ensure that your system meets requirements to create a gateway for the Oracle Transparent Gateway for Ingres.
Table C-2 Ingres Gateway Requirements
Hardware/
Software
Processor
HP
A HP workstation running the required version of HP-UX.
Solaris
Memory
HP
  • The number of cursors currently opened against Ingres.
Solaris
CD-ROM Drive
HP
Solaris
Disk Space
HP
200 MB.
Solaris
200 MB.
Operating System
HP
HP version 11
Solaris
Solaris
HP
Solaris
Oracle Networking
HP
On gateway machine:
Solaris
On gateway machine:
Ingres
HP
Ingres II version 2.0.
Solaris
Sybase Gateway Requirements
Table C-3 describes the hardware and software requirements for a Sybase gateway. Use it to ensure that your system meets requirements to create a gateway for the Oracle Transparent Gateway for Sybase.
Table C-3 Sybase Gateway Requirements
Hardware/
Software
Processor
AIX
An IBM workstation running the required version of AIX.
HP
Solaris
Tru64
A Compaq Alpha workstation running the required version of Tru64 UNIX.
Memory
AIX
26 MB of real memory is recommended to support the gateway. The total memory requirement for the concurrent use of the gateway depends on these factors:
  • The number of cursors currently opened against Sybase.
HP
Solaris
Tru64
CD-ROM Drive
AIX
HP
Solaris
Tru64
Disk Space
AIX
200 MB.
HP
200 MB.
Solaris
200 MB.
Tru64
200 MB.
Operating System
AIX
AIX version 4.3.3
HP
HP version 11
Solaris
Solaris
Tru64
Tru64 version 5.0a or above.
AIX
HP
Solaris
Tru64
Oracle Networking
AIX
The following are required on the gateway machine:
The Oracle Net products are included on the Oracle9i distribution CD-ROM.
HP
Solaris
Tru64
AIX
Sybase Server or Client, version 11.9.2 or 12.0 is required. If Sybase Server is not on the same machine as the gateway, then the version of Sybase Open Library certified for your Sybase Server is required.
HP
Sybase Server or Client, version 11.9.2 or 12.0. If Sybase Server is not on the same machine as the gateway, then the version of Sybase Open Library certified for your Sybase Server is required.
Solaris
Tru64
Teradata Gateway Requirements
Table C-4 describes the hardware and software requirements for a Teradata gateway. Use it to ensure that your system meets requirements to create a gateway for the Oracle Transparent Gateway for Teradata.
Table C-4 Teradata Gateway Hardware Requirements
Hardware  Platform   Requirements
Processor
HP
Solaris
Memory
HP
  • The number of cursors currently opened against Teradata.
Solaris
CD-ROM Drive
HP
Solaris
Disk Space
HP
200 MB.
Solaris
200 MB.
Operating System
HP
HP version 11.
Solaris
HP
Solaris
Oracle Networking
HP
Solaris
Teradata
HP
Teradata V2R.03.00.02 or V2R.04.00.0115.
Solaris
NCR's Teradata ODBC Driver
HP
version 02.04.00.00.
Solaris
Tested Gateway Configurations
The following tables provide gateway configurations tested by Oracle Corporation at the time of this document release. Oracle continues to provide support for the most recent releases of Oracle and non-Oracle systems in a timely manner.
Table C-5 Tested Gateway Configurations
Database  Gateway and Operating System
Informix version 7.2
tg4ifmx version 9.0.1 running on Sun SPARC Solaris version 2.6 (5.6), 7 (5.7) or 8 (5.8).
tg4ifmx version 9.0.1 running on HP-UX 11.0
Informix version 7.3
tg4ifmx version 9.0.1 running on Solaris version 2.6 (5.6), 7 (5.7) or 8 (5.8).
tg4ifmx version 9.0.1 running on HP version 11.0
Informix version 7.4
tg4ingr version 9.0.1 running on Solaris version 2.6 (5.6), 7 (5.7) or 8 (5.8).
tg4ingr version 9.0.1 running on HP version 11.0
Sybase version 11.9.2
tg4sybs version 9.0.1 running on AIX version 4.3.3
tg4sybs version 9.0.1 running on HP version 11.0
tg4sybs version 9.0.1 running on Solaris version 2.6 (5.6), 7 (5.7) or 8 (5.8).
tg4sybs version 9.0.1 running on Tru64 version 5.1
Sybase version 12.0
Teradata V2R3.03.00.02
tg4tera version 9.0.1 running on Solaris version 2.6 (5.6), 7 (5.7) or 8 (5.8) through NCR's ODBC Driver for Teradata V02.04.00.00
tg4tera version 9.0.1 running on HP version 11.0 through NCR's ODBC Driver for Teradata V02.04.00.00
Teradata V2R04.03.00.15
See Also:
Oracle Corporation continually updates supported gateway configurations. For the latest supported configuration information, either contact Oracle Support Services or visit the following web site:
http://www.oracle.com/gateways
Gateway Installation Worksheets
Select the worksheet appropriate for your system in one of the following tables, and use the values you enter as a reference during the configuration process:
Informix Worksheet
Enter your system values in the following Table C-6 to prepare for an Informix gateway configuration.
Table C-6 Informix Installation Worksheet
Description   Value
Oracle database server machine name
Oracle database server platform (OS and its version number)
$ORACLE_HOME of Oracle database server (full path name)
Gateway machine name
Gateway machine platform (OS and its version number)
$ORACLE_HOME of the gateway (full path name)
Informix client library location (full path name)
Name of the Informix server to which the gateway will connect
Name of the Informix database to which the gateway will connect
Ingres Worksheet
Enter your system values in the following Table C-7 to prepare for an Ingres gateway configuration.
Table C-7 Ingres Installation Worksheet
Description   Value
Ingres net/server installed location (full path name)
Name of the Ingres virtual node that will be used to access a remote, networked Ingres server
Name of the Ingres database to which the gateway will connect
Sybase Worksheet
Enter your system values in the following Table C-8 to prepare for a Sybase gateway configuration.
Table C-8  Sybase Installation Worksheet
Description  Value
Name of the Sybase Adaptive Server to which the gateway will connect
Teradata Worksheet
Enter your system values in the following Table C-9 to prepare for a Teradata gateway configuration.
Table C-9 Teradata Installation Worksheet
Description  Value
Version of the Teradata Server to which the gateway will connect .
ODBC Data Source Name (DSN) to be used by the gateway.
Directory where the NCR ODBC Driver for Teradata is installed.
Installing Oracle Transparent Gateway
Use the following procedures and tables to install Oracle Transparent Gateway.
Mounting Transparent Gateway from the CD-ROM
Install the gateway software from the CD-ROM as follows:
  1. Start the Oracle Universal Installer.
    Complete instructions for mounting and running the Oracle Universal Installer are not presented here. Review Chapter 3, "Installation" to find complete mounting and starting instructions for your platform. As a gateway is installed using Custom Installation, note in particular "Oracle9i Database Custom Installation
  2. Install the gateway by responding to installation prompts as indicated for your platform in "Installation Prompts for Transparent Gateway".
The Oracle Universal Installer screens and the sequence in which they appear depend on your platform. Select the installation prompt section that corresponds to the e gateway will connect.
Installation Prompts for Informix Gateway
Use Table C-10, "Installation Prompts and Responses for Informix" as a guide during your gateway installation. Follow the instructions in the Response column for each entry in the Screen column. When you have completed the responses, follow the instructions in the "Completing Informix Gateway Installation" section.
Table C-10 Installation Prompts and Responses for Informix
Screen  Response
Informix Client Library Path: The complete path where the Informix client library is installed.
In the Informix Client Library Path text box, enter the location of your Informix client library files. Specify full paths with directory names not exceeding 32 alphanumeric characters.
When you have entered these names, click the Next button.
When the Summary screen appears, click Install.
Verify that the installation was successful after the Oracle Universal Installer confirms that the installation has been completed. Check the contents of the installActions.log file located in the orainventory_location/logs/ directory.
Installation Prompts for Ingres Gateway
Use Table C-11, "Installation Prompts and Responses for Ingres" as a guide during the installation. Follow the instructions in the Response column for each entry in the Screen column. When you have completed the responses, follow the instructions in the "Completing Ingres Gateway Installation" section.
Table C-11 Installation Prompts and Responses for Ingres
Screen  Response
Ingres II installation: ANSI/ISO entry SQL-92 database standard.
Indicate if your Ingres database is compliant with the ANSI/ISO-92 Entry SQL database standard.
Click the Yes radio button if your Ingres database complies with this standard.
Click the No radio button if your Ingres database does not comply with this standard.
When you have selected the option that describes your Ingres installation, click the Next button
Installation Prompts for Sybase Gateway
Use Table C-12, " Installation Prompts and Responses for Sybase" as a guide during the installation. Follow the instructions in the Response column for each entry in the Screen column. When you have completed the responses, follow the instructions in the "Completing Sybase Gateway Installation" section.
Table C-12  Installation Prompts and Responses for Sybase
Screen  Response
Sybase Path: The complete path where Sybase is installed.
In the Sybase path text box, type the complete directory path where the Sybase software is installed. The gateway will connect to this database.
When you have entered this path, click the Next button.
Sybase Server and Database Names: Names of the SYBASE server and the SYBASE database.
In the Sybase Server text box, type the name of the Sybase server. The gateway will connect to this server.
In the Sybase Database text box, type the name of the Sybase database. The gateway will connect to this database.
Installation Prompts for Teradata Gateway
Use Table C-13, " Installation Prompts and Responses for Teradata" as a guide during the installation. Follow the instructions in the Response column for each entry in the Screen column. When you have completed the responses, follow the instructions in the "Completing Teradata Gateway Installation" section.
Table C-13  Installation Prompts and Responses for Teradata
Screen  Response
ODBC Data Source name that will be used by the gateway
Enter the Open Database Connectivity (ODBC) data source name (DSN) for the Teradata database to which the gateway will connect.
The DSN is defined in the odbc.ini file.
Removing Oracle Transparent Gateway
Remove the gateway as follows:
  2. Click the De-install Products button on the Welcome window or the Installed Products ... button available on any Oracle Universal Installer window. The Inventory window appears and displays a list of installed products.
  3. Click to select the gateway product in the Inventory window and click Remove.
    Only the files that were copied into the Oracle home directory during the gateway installation are automatically removed. You must manually remove all other related files.
Oracle
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
