Skip Headers
Oracle9i Administrator's Reference
Release 1 (9.0.1) for UNIX Systems: AIX-Based Systems, Compaq Tru64 UNIX, HP 9000 Series HP-UX, Linux Intel and Sun SPARC Solaris
Part Number A90347-02
Go To Table Of Contents
Go To Index
Go to previous page Go to next page
Optimal Flexible Architecture
This appendix contains information on the Optimal Flexible Architecture (OFA) standard. The OFA standard is a set of configuration guidelines created to ensure fast, reliable Oracle databases that require little maintenance. This appendix contains the following sections:
Oracle Corporation recommends that you implement the OFA standard when you install and configure Oracle9i.
OFA is designed to:
Characteristics of an OFA-Compliant Database
This section describes characteristics of a database that complies with the OFA standard.
File System Organization
The file system is organized to enable easy administration for issues such as:
Distributed I/O Loads
I/O loads are distributed across enough disk drives to prevent performance bottlenecks.
Hardware Support
In most cases, investment in new hardware is not required to take advantage of the OFA standard.
Safeguards Against Drive Failures
By distributing applications across more than one drive, drive failures affect as few applications as possible.
Distribution of Home Directories
The following items can be distributed across more than one disk drive:
Integrity of Login Home Directories
You can add, move, or delete login home directories without having to revise programs that refer to them.
Independence of UNIX Directory Subtrees
Categories of files are separated into independent UNIX directory subtrees so that files in one category are minimally affected by operations on files in other categories.
Supports Concurrent Execution of Application Software
You can execute multiple versions of application software simultaneously, enabling you to test and use a new release of an application before abandoning the previous version. Transferring to a new version after an upgrade is simple for the administrator and transparent for the user.
Separates Administrative Information for Each Database
The ability to separate administrative information on one database from that of another ensures a reasonable structure for the organization and storage of administrative data.
Uses Consistent Database File Naming
Database files are named so that:
Separation of Tablespace Contents
Tablespace contents are separated to:
I/O Loads Tuned Across All Drives
I/O loads are tuned across all drives, including drives storing Oracle data in raw devices.
Additional Benefits of OFA for Oracle9i Real Application Clusters
For Oracle9i Real Application Clusters Installations:
Optimal Flexible Architecture Implemented on UNIX
This section describes the naming strategy recommended by the OFA standard.
Mount Points
This section describes the naming conventions for mount points.
Create Mount Points
An installation of Oracle9i requires at least two mount points: one for the software and at least one for the database files. To implement the OFA recommendations fully, Oracle9i requires at least four mount points: one for the software and at least three for database files.
Mount Point Syntax
Name all mount points using the syntax /pm, where p is a string constant and m is a unique fixed-length key (typically a two-digit number) used to distinguish each mount point. For example: /u01 and /u02, or /disk01 and /disk02.
Naming Mount Points for Very Large Databases (VLDBs)
If each disk drive contains database files from one application and there are enough drives for each database to prevent I/O bottlenecks, use the syntax /pm/q/dm for naming mount points. Table F-1 describes the variables used in this syntax.
Table F-1 Syntax for Naming Mount Points
Variable  Description
A mount point name
A string denoting that Oracle data is stored in this directory
The value of the initialization parameter DB_NAME (synonymous with the instance sid for single-instance databases)
For example, mount points named /u01/oradata/test and /u02/oradata/test allocate two drives for the Oracle test database.
Naming Directories
This section describes the naming conventions for OFA compliant directories.
Home Directory Syntax
Name home directories using the syntax /pm/h/u. Table F-2 describes the variables used in this syntax.
Table F-2 Syntax for Naming Home Directories
A mount point name
A standard directory name
The name of the owner of the directory
For example, /u01/app/oracle is the Oracle software owner home directory (also referred to as the Oracle base directory, the default directory used by the installer) and /u01/app/applmgr is an Oracle applications software owner home directory.
Placing home directories at the same level in the UNIX file system is advantageous because it allows the collection of applications owner login home directories on different mount points to be referred to using the single pattern matching string, /*/app/*.
Referring to Pathnames
Refer to explicit pathnames only in files designed specifically to store them, such as the password file, /etc/passwd, and the Oracle oratab file. Refer to group memberships only in the /etc/group file.
Software Directories
To help fulfill the OFA feature of simultaneously executing multiple versions of application software, store each version of the Oracle9i Server software in a directory matching the pattern /pm/h/u/product/v.
Table F-3 describes the variables used in this syntax.
Table F-3 Syntax for Naming Oracle9i Server Software Directories
A mount point name
The version of the software
For example, /u01/app/oracle/product/9.0.1 indicates the Oracle9i parent directory. Set the ORACLE_HOME environment variable to this directory.
Naming Subdirectories
To facilitate the organization of administrative data, Oracle Corporation recommends that you store database-specific administration files in subdirectories matching the pattern /h/admin/d/a/, where h is the Oracle software owner's home directory, d is the database name (DB_NAME), and a is a subdirectory for each of the database administration files. Table F-4 describes the database administration file subdirectories.
Table F-4 Subdirectories for Database Administration Files
Subdirectory  Description
Ad hoc SQL scripts for a particular database
Archived redo log files
Audit files
(Set the AUDIT_FILE_DEST initialization parameter to the adump directory. Clean out this subdirectory periodically.)
Background process trace files
Core dump files
Programs used to create the database
Database export files
Files recording the status and history of the database
Instance parameter files
User SQL trace files
For example, the adhoc subdirectory has the pathname /u01/app/oracle/admin/sab/adhoc/ if the adhoc subdirectory is part of the database named sab.
Naming Database Files
The following naming convention for database files ensures that they are easily identifiable:
File Type  File Naming Convention
Control files
Redo log files
The following table describes this syntax:
A mount point name described previously in this chapter
A string distinguishing Oracle data from all other files (usually named ORACLE or oradata)
An Oracle tablespace name
A two-digit string
Do not store files other than control files, redo log files, or datafiles associated with database d in the path /pm/q/d
Following this convention, you could produce, for example, a datafile with the name /u03/oradata/sab/system01.dbf, making it easy to see the database to which the file belongs.
Separate Segments With Different Requirements
Separate groups of segments with different lifespans, I/O request demands, and backup frequencies across different tablespaces.
Table F-5 describes the special tablespaces that the Database Configuration Assistant (DBCA) creates for each Oracle database. If you manually create a database, you must create the required tablespaces. These tablespaces are in addition to those required for application segments.
See Also:
For Information on creating tablespaces manually, see the Oracle9i Database Administrator's Guide.
Table F-5 Special Tablespaces
Tablespace  Required  Description
Data dictionary segments
Temporary segments
Rollback segments
Miscellaneous user segments
Index associated with data in the USERS tablespace
Repository for Oracle Enterprise Manager
Oracle interMedia segment
Creating these special tablespaces is effective because data dictionary segments are never dropped, and no other segments that can be dropped are allowed in the SYSTEM tablespace. Doing this ensures that the SYSTEM tablespace does not require a rebuild due to tablespace free-space fragmentation.
Because rollback segments are not stored in tablespaces holding applications data, the administrator is not blocked from taking an application's tablespace offline for maintenance. The segments are partitioned physically by type, and the administrator can record and predict data growth rates without using complicated tools.
Naming Tablespaces
Name tablespaces descriptively using a maximum of eight characters. Although Oracle9i tablespace names can be 30 characters long, portable UNIX filenames are restricted to 14 characters. The recommended standard for a datafile basename is tn.dbf, where t is a descriptive tablespace name and n is a two-digit string. Because the extension plus the two-digit string occupy a total of six characters, only eight characters remain for the tablespace name.
Descriptive names enable the datafile to be associated with the tablespace that uses it. For example, the names GLD and GLX might be used for the tablespaces storing General Ledger data and indices, respectively.
Do not embed reminders of the word "tablespace" in your tablespace names. Tablespaces are distinguishable by context, and names do not need to convey information on type.
Exploiting the OFA Structure for Oracle Files
Table F-6 describes the syntax used for identifying classes of files.
Table F-6 Directory Structure Syntax for Identifying Classes of Files
Directory Structure Syntax  Description
User data directories
User home directories
User application software directories
Oracle applications software subtrees
Oracle software subtrees
Oracle Server release 9.0.1 distribution files
sab database administrative subtrees
sab database archived log files
Oracle data directories
sab database files
sab database redo log files
OFA File Mapping
Table F-7 shows a hierarchical file mapping of a sample OFA-compliant database, including each file mount point, application, database, and tablespace. The filenames indicate the file type (control, log, or data).
Table F-7 Hierarchical File Mapping for OFA Installation
Directory  Description
Root mount point
User data mount point 1
Subtree for application software
Home for oracle software user
Subtree for database administration files
Subtree for support log files
admin subtree for db_name1 database
admin subtree for db_name2 database
Online documentation
Distribution files
Oracle home directory for release 8.1.6 instances
Oracle home directory for release 8.1.7 instances
Oracle home directory for release 9.0.1 instances
Home directory for a user
Subtree for Oracle data
Subtree for db_name1 database files
Subtree for db_name2 database files
User data mount point 2
Subtree for login home directories
User data mount point 3
File Mapping for a Multiple-Instance OFA Database
When using the Oracle9i Real Application Clusters, select one node to act as the Oracle administrative home for the cluster. The administrative home contains the administrative subtree. Create subdirectories for each instance accessing the database within the bdump, cdump, logbook, pfile, and udump directories of the ~/admin/d/ directory. Mount the admin directory for the administrative home as the admin directory for every instance. Table F-10 shows a sample directory structure.
Table F-8 Administrative Directory Structure for Dual-Instance Oracle9i Real Application Clusters
Directory Path  Description
Administrative directory for sab database
Directory for miscellaneous scripts
Log archive destination for all instances
Directory for background dump files
Background dump destination for inst1 instance
Background dump destination for inst2 instance
Directory for core dump files
Core dump destination for inst1 instance
Core dump destination for inst2 instance
Directory for creation scripts
SQL script to create inst database
Directory for exports
January 20, 2000 full export dump file
Directory for export parfiles
Directory for import parfiles
Directory for logbook entries
Directory for inst1 instance reports
V$PARAMETER report for inst1 instances
Directory for inst2 instances reports
V$PARAMETER report for inst2 instances
DBA_USERS report
Directory for instance parameter files
Directory for inst1 instance parameters
Instance parameters for inst1 instance
Directory for inst2 instance parameters
Instance parameters for inst2 instance
Directory for user dump files
User dump destination for inst1 instance
User dump destination for inst2 instance
Directory Structure
The following sections describe the directory structure for OFA compliant installations.
ORACLE Base Directory
The Oracle base directory is the root of the Oracle directory structure. When installing an OFA-compliant database using the Oracle Universal Installer, the default Oracle base directory is set to /pm/app/oracle. Table F-9 describes an Oracle base directory structure and content.
Table F-9 Oracle Base Directory Structure and Content
Administrative files
Subtree for local Oracle software
Oracle software
Oracle Home Directory
If you install an OFA-compliant Oracle Server, the Oracle home directory is /pm/app/oracle/product/release_number. Table F-10 describes the Oracle home directory structure and content. Under UNIX, the Oracle home directory contains the subdirectories described in Table F-10, as well as a subdirectory for each Oracle product installed.
Table F-10 Oracle Home Directory Structure and Content
Configuration Assistants
Binaries for all products
interMedia Text options
Initialization files
Installation-related files
Oracle product libraries
Java classes
Spatial options
Xerox Stemmer (for interMedia Text options)
Oracle Net Services files
Common files for all products
Data gatherer files
Core libraries
Data options
Oracle TRACE files
PL/SQL files
Precompiler files
Server files and libraries required for the database
SLAX parser files
SQL*Plus files
Examples of Product Subdirectories
Table F-11 shows examples of product subdirectories and their contents.
Table F-11 Examples of Product Subdirectories
admin, doc, install, lib, log, mesg
admin, demo, doc, install, lib, mesg
Contents of Product Subdirectories
Table F-12 describes the subdirectories contained in the rdbms and sqlplus product subdirectories.
Table F-12 Contents of Product Subdirectories
Administrative SQL and shell scripts (for example, catalog.sql, catexp.sql, and demo.sql
Special directories for other products
Resource files
Runtime terminal files
Demonstration scripts and datafiles
README files (for example, readmeunix.doc
Product installation scripts
Product Java classes
Product libraries and distributed make files
Trace files and log files (for example, orasrv.log and *.trc files)
U.S. message files and Multilingual Option (formerly National Language Support) message text and binary files (for example, oraus.msg and oraus.msb
File Naming Conventions in the admin Directory
Table F-13 shows the SQL scripts located in the rdbms/admin directory.
Table F-13 admin Directory, File Naming Conventions
File  Description
Creates catalog and data dictionary tables and views. The following files are run automatically during installation:
  • catalog.sql (for all installations)
  • catproc.sql (for all installations)
  • catclust.sql (for Oracle9i Real Application Clusters option installations)
  • catrep.sql (for all installations)
The catproc.sql file in turn runs the scripts for creating the standard PL/SQL packages, such as DBMS_SQL and DBMS_OUTPUT.
Downgrade scripts
Additional database packages
Upgrade scripts
Creates tables and views for database utilities
Filename Extensions
Table F-14 describes filename extensions.
Table F-14 Filename Extensions
Extension  Description
Object file libraries; Ada runtime libraries
Oracle audit file
X11 font description file
X11 bitmap file
C source file
SQL*Loader control file; Oracle Server control file
SQL*Loader datafile
Oracle Server tablespace file
Export file
ASCII text file
Shell script file for setting environment
C header file; also, sr.h is a SQL*Report Writer help file
Java class archive
UNIX manual page
Output of SQL*Plus scrip
Installation log files; Oracle Server redo log file
Make file
Multilingual Option message file (binary)
Multilingual Option message file (text)
Object module
Oracle configuration file
Installation prototype file
Pro*C source file
Pro*COBOL source file
Printer driver file
Bourne shell script file
SQL script file
SQL script file
Trace file
Uniform Terminal Definition file
Zip file
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Go To Index
