| Oracle9i Real Application Clusters Guard Configuration Guide Release 1 (9.0.1) for UNIX Systems: AIX-Based Systems, Compaq Tru64 UNIX, HP 9000 Series HP-UX and Sun SPARC Solaris Part Number A90458-02 |
The Oracle9i Real Application Clusters Guard directory structure depends on the type of installation you perform when installing the software. This appendix contains the following sections:
Oracle Corporation recommends the Optimal Flexible Architecture (OFA) standard for Oracle installations. The OFA standard is a set of configuration guidelines for efficient and reliable Oracle databases that require little maintenance.
OFA provides the following benefits:
To switch to the OFA standard, you must modify the directory structure and relocate the database files.
If the ORACLE_BASE environment variable is set during installation, an OFA installation is performed, and the PFS_HOME environment variable is set to $ORACLE_BASE/admin/db_name/pfs.
The following is the directory structure of a sample Oracle9i Real Application Clusters Guard OFA compliant installation on UNIX platforms:
$ORACLE_HOME $ORACLE_HOME/pfs $ORACLE_HOME/pfs/admin $ORACLE_HOME/pfs/admin/demo $ORACLE_HOME/pfs/bin $ORACLE_HOME/pfs/bin/oracle_up $ORACLE_HOME/pfs/bin/oracle_ping $ORACLE_HOME/pfs/bin/oracle_lsnr $ORACLE_HOME/pfs/bin/oracle_role $ORACLE_HOME/pfs/bin/pfs_watchdog $ORACLE_HOME/pfs/demo $ORACLE_HOME/pfs/doc $ORACLE_HOME/pfs/lib $ORACLE_HOME/pfs/lib/pfs_cluster $ORACLE_HOME/pfs/lib/pfs_internal $ORACLE_HOME/pfs/lib/pfs_oracle $ORACLE_HOME/pfs/mesg $ORACLE_HOME/pfs/qa $ORACLE_HOME/pfs/setup $ORACLE_HOME/pfs/setup/conf $ORACLE_HOME/pfs/setup/template $ORACLE_HOME/pfs/setup/template/include $ORACLE_HOME/pfs/setup/template/network $ORACLE_HOME/pfs/setup/template/packs $ORACLE_HOME/pfs/setup/template/pfile $ORACLE_HOME/pfs/setup/template/user $ORACLE_HOME/pfs/setup/output $ORACLE_HOME/pfs/setup/output/<ORACLE_SERVICE> $ORACLE_HOME/pfs/setup/output/<ORACLE_SERVICE>/packs $ORACLE_HOME/pfs/setup/output/<ORACLE_SERVICE>/include $ORACLE_HOME/pfs/setup/output/<ORACLE_SERVICE>/network $ORACLE_HOME/pfs/setup/output/<ORACLE_SERVICE>/pfile $ORACLE_HOME/pfs/sys $ORACLE_BASE/admin/ $ORACLE_BASE/admin/<db_name> $ORACLE_BASE/admin/<db_name>/dump $ORACLE_BASE/admin/<db_name>/dump/bdump $ORACLE_BASE/admin/<db_name>/dump/udump $ORACLE_BASE/admin/<db_name>/dump/cdump $ORACLE_BASE/admin/<db_name>/pfile $ORACLE_BASE/admin/<db_name>/dump/network $ORACLE_BASE/admin/<db_name>/dump/network/admin $ORACLE_BASE/admin/<db_name>/pfs $ORACLE_BASE/admin/<db_name>/pfs/include $ORACLE_BASE/admin/<db_name>/pfs/packs $ORACLE_BASE/admin/<db_name>/pfs/user $ORACLE_BASE/admin/<db_name>/pfs/pfsdump $ORACLE_BASE/admin/<db_name>/pfs/<ORACLE_SERVICE>.conf
If the ORACLE_BASE environment variable is not set during installation, a non-OFA installation is performed and the PFS_HOME environment variable is set to $ORACLE_HOME/pfs/db_name.
The following is the directory structure of a sample Oracle9i Real Application Clusters Guard non-OFA compliant installation on UNIX platforms:
$ORACLE_HOME $ORACLE_HOME/pfs $ORACLE_HOME/pfs/admin $ORACLE_HOME/pfs/admin/demo $ORACLE_HOME/pfs/bin $ORACLE_HOME/pfs/bin/oracle_up $ORACLE_HOME/pfs/bin/oracle_ping $ORACLE_HOME/pfs/bin/oracle_lsnr $ORACLE_HOME/pfs/bin/oracle_role $ORACLE_HOME/pfs/bin/pfs_watchdog $ORACLE_HOME/pfs/demo $ORACLE_HOME/pfs/doc $ORACLE_HOME/pfs/lib $ORACLE_HOME/pfs/lib/pfs_cluster $ORACLE_HOME/pfs/lib/pfs_internal $ORACLE_HOME/pfs/lib/pfs_oracle $ORACLE_HOME/pfs/mesg $ORACLE_HOME/pfs/qa $ORACLE_HOME/pfs/setup $ORACLE_HOME/pfs/setup/conf $ORACLE_HOME/pfs/setup/template $ORACLE_HOME/pfs/setup/template/include $ORACLE_HOME/pfs/setup/template/network $ORACLE_HOME/pfs/setup/template/packs $ORACLE_HOME/pfs/setup/template/pfile $ORACLE_HOME/pfs/setup/template/user $ORACLE_HOME/pfs/setup/output $ORACLE_HOME/pfs/setup/output/<ORACLE_SERVICE> $ORACLE_HOME/pfs/setup/output/<ORACLE_SERVICE>/packs $ORACLE_HOME/pfs/setup/output/<ORACLE_SERVICE>/include $ORACLE_HOME/pfs/setup/output/<ORACLE_SERVICE>/network $ORACLE_HOME/pfs/setup/output/<ORACLE_SERVICE>/pfile $ORACLE_HOME/pfs/sys $ORACLE_HOME/pfs/<db_name> $ORACLE_HOME/pfs/<db_name>/<ORACLE_SERVICE>.conf $ORACLE_HOME/pfs/<db_name>/pfile $ORACLE_HOME/pfs/<db_name>/include $ORACLE_HOME/pfs/<db_name>/packs $ORACLE_HOME/pfs/<db_name>/user $ORACLE_HOME/pfs/<db_name>/log
![]() Copyright © 2001 Oracle Corporation. All Rights Reserved. |
