Skip Headers
Oracle9i Reports Tutorial
Release 9.0
Part Number A90900-01
HomeSolution Area
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
5
Reviewing the Source Code for the Report Block
Estimated completion time: 5 minutes
In Chapter 4, "Creating a Report Block for the Web Report", you added a report block to a JSP-based Web report. This chapter reviews the source code added for the report block.
5.1 View the Web source in Reports Builder
To view the Web source:
5.1.1 Review the Header tag and body
  1. In the Web Source view, locate the <!-- Header --> line.
    This HTML code indicates a comment line that helps you locate the report heading information in the file.
  2. Locate the <th> and <tr> tags, which should look something like this:
    <tr>
       <th class="OraTotalText"> &nbsp; </th>
       <th <rw:headers id="HFSumSALARYPerReport" src...>
    </tr>
5.1.2 Review the rw:foreach tag and body
The rw:foreach tag loops across a group. The layout is repeated for each instance of the specified group.
  1. In the Web Source view, locate the <rw:foreach> JSP tag and find this line:
    <rw:foreach id="R_G_EMPLOYEE_ID_1" src="G_EMPLOYEE_ID">
    Here, R_G_EMPLOYEEID is a unique identifier for this loop and G_EMPLOYEE_ID is the data model group on which the loop repeats.
  2. Notice that the </tbody> tag that closes the table follows the closing </rw:foreach> tag, shown here:
         td <rw:headers id=HFEMPLOYEEID1" src...>
       </tr>
      </rw:foreach>
    </tbody>
5.2 Verify your JSP code
If you've gone through this chapter and still aren't sure whether your JSP is correct, open the file we've provided, called empreva.jsp. This file is located in your examples directory.
5.3 Summary
Congratulations! You have finished reviewing the source code for the report block you added in Chapter 4, "Creating a Report Block for the Web Report". Continue to Chapter 6, "Creating a Graph for the Web Report" to add a graph to your Web report.
Oracle
Copyright © 2002 Oracle Corporation.
All Rights Reserved.
HomeSolution Area
Contents
Go To Index
Index
