Skip Headers
Oracle9i Clickstream Intelligence Data Model Reference
Release 2 (9.0.2)
Part Number A96129-01
HomeSolution Area
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
2
The Agent Dimension
The Agent dimension contains attributes that are derived from the "User Agent" string found in many Web server log files. User agents are typically Web browsers, but other agents such as Web spiders may also access sites.
This chapter contains the following topics:
Agent Dimension Hierarchies
The Agent dimension contains the following hierarchies:
The sections that follow list all levels in each hierarchy, followed by a diagram that provides a graphical representation of the hierarchy.
The Agent Client Software Hierarchy
This hierarchy contains the following levels, listed from top to bottom. For details about the attributes of each level, see Agent Dimension Levels.
The Agent Operating System Hierarchy
Figure 2-1 The Agent Client Software and Agent Operating System Level Hierarchies
Text description of agent-h.gif follows
The Agent dimension is comprised of the following levels. For each level, information about each attribute (column name) is provided in the following format:
levels are presented in descending order. In addition to the pre-defined attributes, each level contains five "generic" attributes that can be defined by the user.
CLK_L_CLIENT_TYPE
CLK_L_CLIENT
CLK_L_CLIENT_VERSION
CLK_L_PLATFORM
CLK_L_OPERATING_SYSTEM
CLK_L_AGENT
Oracle
Copyright © 2002 Oracle Corporation.
All Rights Reserved.
HomeSolution Area
Contents
Go To Index
Index
