Skip Headers
Oracle9i Clickstream Intelligence Data Model Reference
Release 2 (9.0.2)
Part Number A96129-01
HomeSolution Area
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
7
The Referrer Dimension
The Referrer dimension allows analysis on multiple levels. Information obtained from the domain name of the referrer can be used in high-level country/domain type reports. If the referrer URL is recognized as belonging to a search engine, then the URL can be parsed to obtain the keywords used in the search. (The Search Dimension holds these search keywords, which can give insight into what users are looking for when they come to the site.)
This chapter contains the following topics:
Referrer Dimension Hierarchies
The Referrer dimension contains the following hierarchies:
The sections that follow list all levels in each hierarchy, followed by a diagram that provides a graphical representation of the hierarchy.
The Referrer Campaign Hierarchy
This hierarchy contains the following levels, listed from top to bottom. For details about the attributes of each level, see Referrer Dimension Levels.
Figure 7-1 The Referrer Campaign Level Hierarchy
Text description of referrer.gif follows
The Referrer Category Hierarchy
Figure 7-2 The Referrer Category Level Hierarchy
Text description of referrea.gif follows
The Referrer Geography Hierarchy
Figure 7-3 Referrer Geography Level Hierarchy
Text description of referreb.gif follows
The Referrer Organization Hierarchy
Figure 7-4 Referrer Organization Level Hierarchy
Text description of referrec.gif follows
The Referrer dimension is comprised of the following levels. For each level, information about each attribute (column name) is provided in the following format:
levels are presented in descending order. In addition to the pre-defined attributes, each level contains five "generic" attributes that can be defined by the user.
CLK_L_CAMPAIGN
CLK_L_REF_CAT3
CLK_L_REF_CAT2
CLK_L_REF_CAT1
CLK_L_REGION
CLK_L_COUNTRY
CLK_L_DOMAIN_TYPE
CLK_L_DOMAIN
CLK_L_REF_SITE
CLK_L_REF_URL
Oracle
Copyright © 2002 Oracle Corporation.
All Rights Reserved.
HomeSolution Area
Contents
Go To Index
Index
