Skip Headers
Oracle Transparent Gateway for IBM DRDA Installation and User's Guide
Release 9.2.0.1.0 for UNIX
Part Number A96194-02
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
A
Oracle DB2 Data Dictionary Views
This appendix includes the Oracle Transparent Gateway for IBM DRDA data dictionary views accessible to all users of an Oracle server.  Most views can be accessed by any user with SELECT privileges for DB2 catalog tables.
N/A is used in the following tables to mean that the column is not valid for the gateway.
This appendix contains the following sections:
Supported Views
The following is a list of Oracle data dictionary views which are supported by the gateway for DB2/OS390 and DB2/400 servers.  This release of the gateway does not have data dictionary view support for DB2/VM and DB2/UDB DRDA servers.
Data Dictionary View Tables
The remainder of this chapter contains tables describing data dictionary views.  In the following descriptions, all are supported for DB2/OS390 and DB2/400.
ALL_CATALOG
All tables, views, synonyms, and sequence accessible to the user:
column name description
OWNER
Owner of the object
TABLE_NAME
Name of the object
TABLE_TYPE
Type of object
ALL_COL_COMMENTS
Comments on columns of accessible tables and views:
OWNER
Owner of the object
TABLE_NAME
Object name
COLUMN_NAME
Column name
COMMENTS
Comments on column
ALL_CONS_COLUMNS
Information about accessible columns in constraint definitions:
OWNER
Owner of the constraint definition
CONSTRAINT_NAME
Name associated with the constraint definition
TABLE_NAME
Name associated with table with constraint definition
COLUMN_NAME
Name associated with column specified in the constraint definition
POSITION
Original position of column in definition
ALL_CONSTRAINTS
Constraint definitions on accessible tables:
OWNER
CONSTRAINT_NAME
CONSTRAINT_TYPE
Type of constraint definition
TABLE_NAME
SEARCH_CONDITION
Text of search condition for table check
R_OWNER
Owner of table used in referential constraint
R_CONSTRAINT_NAME
Name of unique constraint definition for referenced table
DELETE_RULE
Delete rule for referential constraint
STATUS
Status of constraint
DEFERRABLE
Whether the constraint is deferrable
DEFERRED
Whether the constraint was initially deferred
VALIDATED
Whether all data obeys the constraint
GENERATED
Whether the name of the constraint is user or system generated
BAD
Constraint specifies a century in an ambiguous manner
RELY
Whether an enabled constraint is enforced or unenforced
LAST_CHANGE
When the constraint was las enabled or disabled
ALL_INDEXES
Description of indexes on tables accessible to the user:
OWNER
Owner of the index
INDEX_NAME
Name of the index
INDEX_TYPE
Type of index
TABLE_OWNER
Owner of the indexed object
TABLE_NAME
Name of the indexed object
TABLE_TYPE
Type of the indexed object
UNIQUENESS
Uniqueness status of the index
TABLESPACE_NAME
Name of the tablespace containing the index
INI_TRANS
N/A
MAX_TRANS
N/A
INITIAL_EXTENT
N/A
NEXT_EXTENT
N/A
MIN_EXTENTS
N/A
MAX_EXTENTS
N/A
PCT_INCREASE
N/A
PCT_THRESHOLD
Threshold percentage of block space allowed per index entry
INCLUDE_COLUMN
Column ID of the last column to be included in index-organized table
FREELISTS
Number of process freelists allocated to this segment
FREELIST_GROUPS
Number of freelist groups allocated to this segment
PCT_FREE
N/A
LOGGING
Logging information
BLEVEL
Depth of the index from its root block to its leaf blocks.  A depth of 1 indicates that the root block and the leaf block are the same.
LEAF_BLOCKS
Number of leaf blocks in the index
DISTINCT_KEYS
Number of distinct indexed values.  For indexes that enforce UNIQUE and PRIMARY KEY constraints, this value is the same as the number of rows in the table.
AVG_LEAF_BLOCKS_PER
N/A
AVG_DATA_BLOCKS_PER
N/A
CLUSTERING_FACTOR
N/A
STATUS
State of the index: VALID
NUM_ROWS
Number of rows in the index
SAMPLE_SIZE
Size of the sample used to analyze the index
LAST_ANALYZED
Date on which this index was most recently analyzed
DEGREE
Number of threads per instance for scanning the index
INSTANCES
Number of instances across which the index is to be scanned
PARTITIONED
Whether this index is partitioned
TEMPORARY
Whether the index is on a temporary table
GENERATED
Whether the name of the index is system generated
BUFFER_POOL
Whether the index is a secondary object
ALL_IND_COLUMNS
column names description
INDEX_OWNER
Owner of the index
INDEX_NAME
Name of the index
TABLE_OWNER
Owner of the table or cluster
TABLE_NAME
Name of the table or cluster
COLUMN_NAME
Column name or attribute of object type column
COLUMN_POSITION
Position of column or attribute within the index
COLUMN_LENGTH
Indexed length of the column
ALL_OBJECTS
Objects accessible to the user:
OWNER
Owner of the object
OBJECT_NAME
Name of object
SUBOBJECT_NAME
Name of the subobject
OBJECT_ID
Object number of the object
DATA_OBJECT_ID
Dictionary object number of the segment that contains the object
OBJECT_TYPE
Type of object
CREATED
N/A
LAST_DDL_TIME
N/A
TIMESTAMP
N/A
STATUS
State of the object
TEMPORARY
Whether the object is temporary
GENERATED
Was the name of this object system generated?
ALL_SYNONYMS
All synonyms accessible to the user:
OWNER
Owner of the synonym
SYNONYM_NAME
Name of the synonym
TABLE_OWNER
Owner of the object referenced by the synonym
TABLE_NAME
Name of the object referenced by the synonym
DB_LINK
N/A
ALL_TABLES
Description of tables accessible to the user:
OWNER
Owner of the table
TABLE_NAME
Name of the table
TABLESPACE_NAME
Name of the tablespace containing the table
CLUSTER_NAME
N/A
IOT_NAME
Name of the index organized table
PCT_FREE
N/A
PCT_USED
N/A
INI_TRANS
N/A
MAX_TRANS
N/A
INITIAL_EXTENT
N/A
NEXT_EXTENT
N/A
MIN_EXTENTS
N/A
MAX_EXTENTS
N/A
PCT_INCREASE
N/A
FREELISTS
FREELIST_GROUPS
LOGGING
Logging attribute
BACKED_UP
N/A
NUM_ROWS
Number of rows in the table
BLOCKS
N/A
EMPTY_BLOCKS
N/A
AVG_SPACE
N/A
CHAIN_CNT
N/A
AVG_ROW_LEN
Average length of a row in the table in bytes
AVG_SPACE_FREELIST_BLOCKS
The average freespace of all blocks on a freelist
NUM_FREELIST_BLOCKS
The number of blocks on the freelist
DEGREE
The number of threads per instance for scanning the table
INSTANCES
The number of instances across which the table is to be scanned
CACHE
Whether the cluster is to be cached in the buffer cache
TABLE_LOCK
Whether table locking is enabled or disabled
SAMPLE_SIZE
Sample size used in analyzing this table
LAST_ANALYZED
Date on which this table was most recently analyzed
PARTITIONED
Indicates whether this table is partitioned
IOT_TYPE
If this is an index organized table
TEMPORARY
Can the current session only see data that it placed in this object itself?
NESTED
If the table is a nested table
BUFFER_POOL
The default buffer pool for the object
ALL_TAB_COLUMNS
Columns of all tables, views, and clusters accessible to the user:
OWNER
Owner of the table or view
TABLE_NAME
Table or view name
COLUMN_NAME
Column name
DATA_TYPE
Datatype of column
DATA_TYPE_MOD
Datatype modifier of the column
DATA_TYPE_OWNER
Owner of the datatype of the column
DATA_LENGTH
Maximum length of the column in bytes
DATA_PRECISION
N/A
DATA_SCALE
Digits to the right of decimal point in a number
NULLABLE
Does the column allow nulls?  Value is n if there is a NOT NULL constraint on the column or if the column is part of a PRIMARY key.
COLUMN_ID
Sequence number of the column as created
DEFAULT_LENGTH
N/A
DATA_DEFAULT
N/A
NUM_DISTINCT
Number of distinct values in each column of the table
LOW_VALUE
For tables with more than three rows, the second lowest and second highest values.  These statistics are expressed in hexadecimal notation for the internal representation of the first 32 bytes of the values.
HIGH_VALUE
N/A
DENSITY
N/A
NUM_NULLS
The number of nulls in the column
NUM_BUCKETS
The number of buckets in histogram for the column
LAST_ANALYZED
The date on which this column was most recently analyzed
SAMPLE_SIZE
The sample size used in analyzing this column
CHARACTER_SET_NAME
The name of the character set
CHAR_COL_DECL_LENGTH
The length of the character set
ALL_TAB_COMMENTS
Comments on tables and views accessible to the user:
OWNER
Owner of the object
TABLE_NAME
Name of the object
TABLE_TYPE
Type of object
COMMENTS
Comments on the object
ALL_USERS
Information about all users of the database:
USERNAME
Name of the user
USER_ID
N/A
CREATED
N/A
ALL_VIEWS
Text of views accessible to the user:
OWNER
Owner of the view
VIEW_NAME
Name of the view
TEXT_LENGTH
Length of the view text
TEXT
View text.  Only the first row of text is returned, even if multiple rows exist.
TYPE_TEXT_LENGTH
Length of the type clause of the typed view
TYPE_TEXT
Type clause of the typed view
OID_TEXT_LENGTH
Length of the WITH OID clause of the typed view
OID_TEXT
VIEW_TYPE_OWNER
Owner of the type of the view if the view is a typed view
VIEW_TYPE
Type of the view if the view is a typed view
COLUMN_PRIVILEGES
Grants on columns for which the user is the grantor, grantee, or owner, or PUBLIC is the grantee:
GRANTEE
Name of the user to whom access was granted
OWNER
Username of the object's owner
TABLE_NAME
Name of the object
COLUMN_NAME
Name of the column
GRANTOR
Name of the user who performed the grant
INSERT_PRIV
Permission to insert into the column
UPDATE_PRIV
Permission to update the column
REFERENCES_PRIV
Permission to reference the column
CREATED
Timestamp for the grant
DICTIONARY
List or data dictionary tables:
TABLE_NAME
Table name
COMMENTS
DUAL
DUMMY
A dummy column
TABLE_PRIVILEGES
Grants on objects for which the user is the grantor, grantee, or owner, or PUBLIC is the grantee:
GRANTEE
Name of the user to whom access is granted
OWNER
Owner of the object
TABLE_NAME
Name of the object
GRANTOR
SELECT_PRIV
Permission to select from an object
INSERT_PRIV
Permission to insert into an object
DELETE_PRIV
Permission to delete from an object
UPDATE_PRIV
Permission to update an object
REFERENCES_PRIV
N/A
ALTER_PRIV
Permission to alter an object
INDEX_PRIV
Permission to create or drop an index on an object
CREATED
USER_CATALOG
Tables, views, synonyms, and sequences owned by the use:
TABLE_NAME
Name of the object
TABLE_TYPE
Type of object
USER_COL_COMMENTS
Comments on columns of user's tables and views:
TABLE_NAME
Object name
COLUMN_NAME
Column name
COMMENTS
Comments on column
USER_CONSTRAINTS
Constraint definitions on user's tables:
OWNER
CONSTRAINT_NAME
CONSTRAINT_TYPE
TABLE_NAME
SEARCH_CONDITION
R_OWNER
R_CONSTRAINT_NAME
DELETE_RULE
STATUS
DEFERRABLE
DEFERRED
VALIDATED
GENERATED
BAD
LAST_CHANGE
USER_CONS_COLUMNS
Information about columns in constraint definitions owned by the user:
OWNER
CONSTRAINT_NAME
TABLE_NAME
COLUMN_NAME
POSITION
USER_INDEXES
Description of the user's own indexes:
INDEX_NAME
Name of the index
INDEX_TYPE
Type of index
TABLE_OWNER
TABLE_NAME
TABLE_TYPE
UNIQUENESS
TABLESPACE_NAME
INI_TRANS
N/A
MAX_TRANS
N/A
INITIAL_EXTENT
N/A
NEXT_EXTENT
N/A
MIN_EXTENTS
N/A
MAX_EXTENTS
N/A
PCT_INCREASE
N/A
PCT_THRESHOLD
INCLUDE_COLUMN
FREELISTS
FREELIST_GROUPS
PCT_FREE
N/A
LOGGING
Logging information
BLEVEL
Depth of the index from its root block to its leaf blocks.  A depth of 1 indicates that the root and leaf block are the same.
LEAF_BLOCKS
DISTINCT_KEYS
AVG_LEAF_BLOCKS_PER
N/A
AVG_DATA_BLOCKS_PER
N/A
CLUSTERING_FACTOR
N/A
STATUS
State of the indexes: VALID
NUM_ROWS
SAMPLE_SIZE
LAST_ANALYZED
DEGREE
INSTANCES
PARTITIONED
TEMPORARY
GENERATED
BUFFER_POOL
USER_OBJECTS
Objects owned by the user:
OBJECT_NAME
Name of object
SUBOBJECT_NAME
OBJECT_ID
DATA_OBJECT_ID
OBJECT_TYPE
Type of object
CREATED
N/A
LAST_DDL_TIME
N/A
TIMESTAMP
N/A
STATUS
State of the object: VALID
TEMPORARY
GENERATED
USER_SYNONYMS
The user's private synonyms:
SYNONYM_NAME
Name of the synonym
TABLE_OWNER
TABLE_NAME
DB_LINK
N/A
USER_TABLES
Description of the user's own tables:
TABLE_NAME
Name of the table
TABLESPACE_NAME
CLUSTER_NAME
N/A
IOT_NAME
PCT_FREE
N/A
PCT_USED
N/A
INI_TRANS
N/A
MAX_TRANS
N/A
INITIAL_EXTENT
N/A
NEXT_EXTENT
N/A
MIN_EXTENTS
N/A
MAX_EXTENTS
N/A
PCT_INCREASE
N/A
FREELISTS
FREELIST_GROUPS
LOGGING
Logging information
BACKED_UP
N/A
NUM_ROWS
BLOCKS
N/A
EMPTY_BLOCKS
N/A
AVG_SPACE
N/A
CHAIN_CNT
N/A
AVG_ROW_LEN
NUM_FREELIST_BLOCKS
DEGREE
INSTANCES
CACHE
TABLE_LOCK
SAMPLE_SIZE
LAST_ANALYZED
PARTITIONED
IOT_TYPE
TEMPORARY
NESTED
BUFFER_POOL
USER_TAB_COLUMNS
Columns of user's tables, views, and clusters:
TABLE_NAME
Table, view, or cluster name
COLUMN_NAME
Column name
DATA_TYPE
Datatype of column
DATA_TYPE_MOD
DATA_TYPE_OWNER
DATA_LENGTH
DATA_PRECISION
N/A
DATA_SCALE
NULLABLE
COLUMN_ID
DEFAULT_LENGTH
N/A
DATA_DEFAULT
N/A
NUM_DISTINCT
LOW_VALUE
HIGH_VALUE
N/A
DENSITY
N/A
NUM_NULLS
NUM_BUCKETS
LAST_ANALYZED
SAMPLE_SIZE
CHARACTER_SET_NAME
USER_TAB_COMMENTS
Comments on the tables and views owned by the user:
TABLE_NAME
Name of the object
TABLE_TYPE
Type of object
COMMENTS
USER_USERS
Information about the current user:
USERNAME
Name of the user
USER_ID
N/A
ACCOUNT_STATUS
Indicates if the account is locked, expired or unlocked
LOCK_DATE
Date the account was locked
EXPIRE_DATE
Date of expiration of the account
DEFAULT_TABLESPACE
N/A
TEMPORARY_TABLESPACE
N/A
CREATED
N/A
EXTERNAL_NAME
User external name
USER_VIEWS
Text of views owned by the user:
VIEW_NAME
Name of the view
TEXT_LENGTH
TEXT
First line of the view text
TYPE_TEXT_LENGTH
TYPE_TEXT
OID_TEXT_LENGTH
OID_TEXT
VIEW_TYPE_OWNER
VIEW_TYPE
Oracle
Copyright © 2001, 2002 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
